paths.hpp
2 // Copyright 2011-2012,2015 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <boost/filesystem.hpp>
12 #include <string>
13 #include <vector>
14
15 namespace fs = boost::filesystem;
16
17 namespace uhd {
18
20 //
21 // This is a directory where temporary files can be written. The path is
22 // chosen as follows:
23 // - If the UHD_TMP_PATH environment variable is set, its value is returned.
24 // - Otherwise, OS-specific defaults are used to determine the temporary
25 // directory.
26 UHD_API std::string get_tmp_path(void);
27
29 //
30 // This is the path to the directory containing the UHD library (e.g.,
31 // libuhd.so or uhd.dll).
32 UHD_API std::string get_lib_path(void);
33
35 //
36 // This path is typically identical with the installation prefix, but can be
37 // overridden with the UHD_PKG_PATH environment variable.
38 //
39 // This path is "calculated" by identifying the path to the UHD library and
40 // returning the parent directory of the library path.
41 UHD_API std::string get_pkg_path(void);
42
43
45 //
46 // This path is typically identical with get_pkg_path()/share/uhd, but can be
47 // overridden with the UHD_PKG_DATA_PATH environment variable.
48 //
49 // This path is where UHD stores data files that are not part of the library
50 // itself, such as images, RFNoC YAML files, and calibration data.
51 UHD_API std::string get_pkg_data_path(void);
52
54 UHD_API std::string get_cal_data_path(void);
55
57 //
58 // This is a list of paths UHD will use to find additional modules to load at
59 // runtime.
60 UHD_API std::vector<fs::path> get_module_paths(void);
61
79 UHD_API std::string get_images_dir(const std::string& search_paths);
80
93 UHD_API std::string find_image_path(
94  const std::string& image_name, const std::string& search_paths = "");
95
102 UHD_API std::string find_utility(const std::string& name);
103
109 UHD_API std::string print_utility_error(
110  const std::string& name, const std::string& args = "");
111 } // namespace uhd
uhd::get_tmp_path
Get a string representing the system's temporary directory.
config.hpp
UHD_API
Definition: config.h:87
uhd::find_image_path
UHD_API std::string find_image_path(const std::string &image_name, const std::string &search_paths="")
uhd::get_pkg_path
Get a string representing the system's pkg directory.
uhd
Definition: build_info.hpp:12
uhd::get_pkg_data_path
Get a string representing the system's package data directory ("share")
uhd::print_utility_error
UHD_API std::string print_utility_error(const std::string &name, const std::string &args="")
uhd::get_lib_path
Get a string representing the system's library directory.
uhd::get_module_paths
UHD_API std::vector< fs::path > get_module_paths(void)
Get UHD library paths.
uhd::find_utility
UHD_API std::string find_utility(const std::string &name)
uhd::get_cal_data_path
Get a string representing the location of the calibration database.
uhd::get_images_dir
UHD_API std::string get_images_dir(const std::string &search_paths)
