    Version: 4.8.0.0
   11 #include <type_traits>
   38     range_t(
double start,
double stop,
double step = 0);
   41     double start(
void)
const;
   44     double stop(
void)
const;
   47     double step(
void)
const;
   50     std::string to_pp_string(
void)
const;
   59     double _start, _stop, _step;
   76     template <
typename InputIterator>
   78         : std::vector<
range_t>(first, last)
   84         static_assert(!std::is_integral<
typename std::decay<InputIterator>::type>::value,
   85             "You can't pass integers to meta_range_t's constructor!");
   95     meta_range_t(
double start,
double stop,
double step = 0);
   98     double start(
void)
const;
  101     double stop(
void)
const;
  104     double step(
void)
const;
  112     double clip(
double value,
bool clip_step =
false)
const;
  127     std::string to_pp_string(
void)
const;
UHD_API bool operator==(const time_spec_t &, const time_spec_t &)
Definition: config.h:87
Definition: build_info.hpp:12
UHD_INLINE T clip(const T &val, const T &bound1, const T &bound2)
Definition: algorithm.hpp:81
meta_range_t freq_range_t
Definition: ranges.hpp:131
Definition: ranges.hpp:21
meta_range_t gain_range_t
Definition: ranges.hpp:130
Definition: fp_compare_delta.ipp:71
