    Version: 4.8.0.0
   19 #include <boost/units/detail/utility.hpp>
   23 namespace uhd {
namespace rfnoc {
   34                             public std::enable_shared_from_this<rfnoc_graph>
   40     using sptr = std::shared_ptr<rfnoc_graph>;
   79     virtual std::vector<block_id_t> find_blocks(
   80         const std::string& block_id_hint)
const = 0;
   85     std::vector<block_id_t>
find_blocks(
 const
   87         std::vector<block_id_t> all_block_ids = find_blocks(block_id_hint);
   88         std::vector<block_id_t> filt_block_ids;
   89         for (
size_t i = 0; i < all_block_ids.size(); i++) {
   90             if (has_block<T>(all_block_ids[i])) {
   91                 filt_block_ids.push_back(all_block_ids[i]);
   94         return filt_block_ids;
  103     virtual bool has_block(
const block_id_t& block_id)
const = 0;
  110     template <
typename T>
  113         return has_block(block_id)
  114                && bool(std::dynamic_pointer_cast<T>(get_block(block_id)));
  141     template <
typename T>
  144         std::shared_ptr<T> blk = std::dynamic_pointer_cast<T>(get_block(block_id));
  149                 std::string(
"This device does not have a block of type ")
  150                 + boost::units::detail::demangle(
typeid(T).name())
  166     virtual bool is_connectable(
const block_id_t& src_blk,
  169         size_t dst_port) = 0;
  190     virtual void connect(
  194         bool is_back_edge =
false) = 0;
  224     virtual void connect(
  243     virtual void disconnect(
  246         size_t dst_port) = 0;
  257     virtual void disconnect(
const std::string& streamer_id) = 0;
  269     virtual void disconnect(
const std::string& streamer_id,
size_t port) = 0;
  280     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_from_src(
  281         const block_id_t& src_blk,
size_t src_port) = 0;
  292     virtual std::vector<uhd::transport::adapter_id_t> enumerate_adapters_to_dst(
  293         const block_id_t& dst_blk,
  304     virtual std::vector<graph_edge_t> enumerate_static_connections()
const = 0;
  313     virtual std::vector<graph_edge_t> enumerate_active_connections() = 0;
  322     virtual void commit() = 0;
  337     virtual std::string to_dot() = 0;
  379     virtual size_t get_num_mboards()
const = 0;
  390     virtual std::shared_ptr<mb_controller> get_mb_controller(
  391         const size_t mb_index = 0) = 0;
  427     virtual bool synchronize_devices(
  434     virtual chdr_w_t get_chdr_width(
const = 0;
Definition: block_id.hpp:39
std::vector< block_id_t > find_blocks(const std::string &block_id_hint) const
Definition: rfnoc_graph.hpp:85
Definition: exception.hpp:59
string release
Definition: conf.py:29
Definition: stream.hpp:172
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:278
std::string to_string() const
Return a string like this: "0/FFT#1" (includes all components, if set)
Definition: config.h:87
Definition: property_tree.hpp:224
bool has_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:111
virtual ~rfnoc_graph()
Definition: rfnoc_graph.hpp:42
Definition: build_info.hpp:12
Definition: time_spec.hpp:28
size_t adapter_id_t
Host transport adapter ID.
Definition: adapter_id.hpp:17
Definition: rfnoc_graph.hpp:33
Definition: stream.hpp:50
std::shared_ptr< rfnoc_graph > sptr
Definition: rfnoc_graph.hpp:40
Definition: noc_block_base.hpp:48
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
std::shared_ptr< T > get_block(const block_id_t &block_id) const
Definition: rfnoc_graph.hpp:142
