    Version: 4.8.0.0
   39     typedef std::shared_ptr<i2c_iface>
sptr;
   51     virtual void write_i2c(uint16_t addr,
const byte_vector_t& buf) = 0;
   59     virtual byte_vector_t read_i2c(uint16_t addr,
size_t num_bytes) = 0;
   67     virtual void write_eeprom(uint16_t addr, uint16_t offset,
const byte_vector_t& buf);
   76     virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset,
size_t num_bytes);
   89     enum edge_t { EDGE_RISE =
'r', EDGE_FALL =
'f' };
  125     typedef std::shared_ptr<spi_iface>
sptr;
  138     virtual uint32_t transact_spi(
int which_slave,
  152     virtual uint32_t read_spi(
  153         int which_slave,
const spi_config_t& config, uint32_t data,
size_t num_bits);
  162     virtual void write_spi(
  163         int which_slave,
size_t num_bits);
  172     typedef std::shared_ptr<uart_iface>
sptr;
  180     virtual void write_uart(
const std::string& buf) = 0;
  187     virtual std::string read_uart(
double timeout) = 0;
edge_t
Definition: serial.hpp:89
Definition: config.h:87
std::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:39
std::shared_ptr< uart_iface > sptr
Definition: serial.hpp:172
Definition: byte_vector.hpp:21
Definition: build_info.hpp:12
Definition: serial.hpp:169
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:92
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:95
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:101
Definition: serial.hpp:36
Definition: serial.hpp:83
Definition: serial.hpp:122
std::shared_ptr< spi_iface > sptr
Definition: serial.hpp:125
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:98
