    Version: 4.8.0.0
   22 struct async_metadata_t;
  172     typedef std::shared_ptr<rx_streamer>
sptr;
  177     virtual size_t get_num_channels(
void)
const = 0;
  180     virtual size_t get_max_num_samps(
void)
const = 0;
  243         const size_t nsamps_per_buff,
  245         const double timeout  = 0.1,
  246         const bool one_packet =
false) = 0;
  259     virtual void issue_stream_cmd(
const stream_cmd_t& stream_cmd) = 0;
  266     virtual void post_input_action(
  267         const std::shared_ptr<uhd::rfnoc::action_info>& action,
const size_t port) = 0;
  278     typedef std::shared_ptr<tx_streamer>
sptr;
  283     virtual size_t get_num_channels(
void)
const = 0;
  286     virtual size_t get_max_num_samps(
void)
const = 0;
  320         const size_t nsamps_per_buff,
  322         const double timeout = 0.1) = 0;
  330     virtual bool recv_async_msg(
  338     virtual void post_output_action(
  339         const std::shared_ptr<uhd::rfnoc::action_info>& action,
Definition: stream.hpp:169
Definition: stream.hpp:275
ref_vector< const void * > buffs_type
Typedef for a pointer to a single, or a collection of send buffers.
Definition: stream.hpp:289
Definition: stream.hpp:172
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:278
Definition: config.h:87
std::vector< size_t > channels
Definition: stream.hpp:161
stream_args_t(const std::string &cpu="", const std::string &otw="")
Convenience constructor for streamer args.
Definition: stream.hpp:53
device_addr_t args
Definition: stream.hpp:132
std::string cpu_format
Definition: stream.hpp:75
std::string otw_format
Definition: stream.hpp:95
Definition: build_info.hpp:12
ref_vector< void * > buffs_type
Typedef for a pointer to a single, or a collection of recv buffers.
Definition: stream.hpp:183
Definition: stream_cmd.hpp:39
Definition: stream.hpp:50
Definition: ref_vector.hpp:21
