This application note describes the use of the board-mounted GPS Disciplined OCXO, as used with the USRP X300/X310. For information regarding the GPSDO that is compatible with the USRP N2xx or E1xx, please see Internal GPSDO (USRP-N2x0/E1X0 Models).
Phase noise:
| Offset | OCXO Phase noise power |
| 1Hz | -75dBc/Hz |
| 10Hz | -110dBc/Hz |
| 100Hz | -132dBc/Hz |
| 1kHz | -142dBc/Hz |
| 10kHz | -145dBc/Hz |
| 100kHz | -150dBc/Hz |
Antenna Types:
To install the GPSDO, you must insert it into the slot on the board near the 10 MHz Reference SMA. Keep in mind that the two sides of the GPSDO have a different number of pins. When inserting the GPSDO, make sure to press down firmly and evenly. When turning on the USRP X3x0 device, a green LED should illuminate on the GPSDO. This signifies that the unit has successfully been placed.
If a GPSDO is detected at startup, the USRP will have gpsdo clock and time source options.
Select these by using UHD's clock and time source APIs:
That will lock the reference clock to the disciplined 10MHz oscillator, and will make the USRP listen for time signal pulses coming from the GPSDO.
However, you will still need to explicitly set the device time on such a PPS edge, using the set_time_next_pps() or set_time_unknown_pps() calls.
The returned value will be the current epoch time, in seconds since January 1, 1970. This value is readily converted into human-readable format using the time.h library in C, std::chrono in C++, etc.
If you want to set the device time to GPS time, the following procedure makes sure you don't encounter timing problems while doing so:
usrp->get_time_last_pps() until a change is seen, and then sleep 200ms to allow new time data coming from the GPSDO to propagate through the system, to set the time,
usrp->get_time_last_pps() until a change is seen and sleep 200ms (allow NMEA string to propagate),usrp->get_time_last_pps() and usrp->get_mboard_sensor("gps_time") return the same time.Other information can be fetched as well. You can query the lock status with the gps_locked sensor, as well as obtain raw NMEA sentences using the gps_gprmc, and gps_gpgga sensors. Location information can be parsed out of the gps_gpgga sensor by using gpsd or another NMEA parser.
WARNING: This is considered advanced usage, and sending custom commands to the GPS module can cause the GPSDO to go into an undefined state, or stop functioning correctly. Only use this if you are sure of what you are doing.
The GPS module inside the X3x0 supports many more features than are exposed by the regular UHD APIs. To access the full feature set of the GPS module, you need to send custom commands to the GPS module. This can be done by accessing the gps_iface feature, which can be done as follows:
For a full listing of the available commands, consult the Jackson Labs LC_XO manual.
