USRP Hardware Driver and USRP Manual  Version: 4.6.0.0-7-gece7c4811
uhd::dict< Key, Val > Class Template Reference
#include <uhd/types/dict.hpp>
Inheritance diagram for uhd::dict< Key, Val >:
uhd::usrp_clock::octoclock_eeprom_t
 dict (void)
template<typename InputIterator >
std::size_t size (void) const
std::vector< Key > keys (void) const
std::vector< Val > vals (void) const
bool has_key (const Key &key) const
const Val & get (const Key &key, const Val &other) const
const Val & get (const Key &key) const
void set (const Key &key, const Val &val)
const Val & operator[] (const Key &key) const
bool operator== (const dict< Key, Val > &other) const
bool operator!= (const dict< Key, Val > &other) const
Val pop (const Key &key)
void update (const dict< Key, Val > &new_dict, bool fail_on_conflict=true)
 operator std::map< Key, Val > () const
template<typename Key, typename Val>
class uhd::dict< Key, Val >
A templated dictionary class with a python-like interface.
◆ dict() [1/2]
template<typename Key , typename Val >
uhd::dict< Key, Val >::dict ( void  )
Create a new empty dictionary.
◆ dict() [2/2]
uhd::dict< Key, Val >::dict ( InputIterator  first,
InputIterator  last
Input iterator constructor: Makes boost::assign::map_list_of work.
firstthe begin iterator
lastthe end iterator
◆ get() [1/2]
const Val & uhd::dict< Key, Val >::get ( const Key &  key,
const Val &  other
) const
Get a value in the dict or default.
keythe key to look for
otheruse if key not found
the value or default
◆ get() [2/2]
const Val & uhd::dict< Key, Val >::get ( const Key &  key) const
Get a value in the dict or throw.
◆ has_key()
template<typename Key, typename Val >
bool uhd::dict< Key, Val >::has_key ( const Key &  key) const
Does the dictionary contain this key?
true if found
◆ keys()
std::vector< Key > uhd::dict< Key, Val >::keys ( void  ) const
Get a list of the keys in this dict. Key order depends on insertion precedence.
vector of keys
◆ operator std::map< Key, Val >()
uhd::dict< Key, Val >::operator std::map< Key, Val > ( ) const
Typecast operator to std::map<>
◆ operator!=()
bool uhd::dict< Key, Val >::operator!= ( const dict< Key, Val > &  other) const
Not equal operator for the dict type
otherthe dict being compared to this
whether or not the two dict's are not equal
◆ operator==()
bool uhd::dict< Key, Val >::operator== ( const dict< Key, Val > &  other) const
Equals operator for the dict type
whether or not the two dict's are equal
◆ operator[]() [1/2]
const Val & uhd::dict< Key, Val >::operator[] ( const Key &  key) const
Get a value for the given key if it exists. If the key is not found throw an error.
the value at the key
Exceptions
anexception when not found
◆ operator[]() [2/2]
Set a value for the given key, however, in reality it really returns a reference which can be assigned to.
keythe key to set to
a reference to the value
◆ pop()
Val uhd::dict< Key, Val >::pop ( const Key &  key)
Pop an item out of the dictionary.
keythe item key
the value of the item
Exceptions
void uhd::dict< Key, Val >::set ( const Key &  key,
const Val &  val
Set a value in the dict at the key.
keythe key to set at
valthe value to set
◆ size()
std::size_t uhd::dict< Key, Val >::size ( void  ) const
Get the number of elements in this dict.
◆ update()
void uhd::dict< Key, Val >::update ( const dict< Key, Val > &  new_dict,
bool  fail_on_conflict = true
Update this dictionary with values from another.
Basically, this copies all the key/value pairs from new_dict into this dict. When the key is already present in the current dict, it either overwrites the current value (if fail_on_conflict is false) or it throws (if fail_on_conflict is true and the values differ).
With the exception of fail_on_conflict, this behaves analogously to Python's dict.update() method.
new_dictThe arguments to copy.
fail_on_conflictIf true, throws.
Exceptions
uhd::value_error
◆ vals()
std::vector< Val > uhd::dict< Key, Val >::vals ( void  ) const
Get a list of the values in this dict. Value order depends on insertion precedence.
vector of values
