USRP N3xx Series
Comparative features list
  • Hardware Capabilities:
    • Dual SFP+ Transceivers (can be used with 1 GigE, 10 GigE, and Aurora)
    • External PPS input & output
    • External 10 MHz input & output (20 MHz and 25 MHz inputs also supported)
    • Internal 25 MHz reference clock
    • Internal GPSDO for timing, location, and 20 MHz reference clock + PPS
    • External USB Connection for built-in JTAG debugger and serial console
    • Xilinx Zynq SoC with dual-core ARM Cortex A9 and Virtex-7 FPGA
  • Software Capabilities:
  • FPGA Capabilities:
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • RFNoC capability
N310 (4-channel transceiver)
The N310 is a 4-channel receiver based on the AD9371 transceiver IC. It has two daughterboards with one AD9371 each; every daughterboard provides two RF channels.
  • Supported master clock rates: 122.88 MHz, 125 MHz, 153.6 MHz
  • Tuning range: 10 MHz to 6 GHz (below 300 MHz, additional LOs and mixer stages are required to shift the signal into the frequency range of the AD9371 transceiver)
  • 4 RX DDC chains in FPGA
  • 4 TX DUC chain in FPGA
The STM32 microcontroller
tbw
The SD card
  1. Boot partition (contains the bootloader). This partition usually does not require touching.
  2. A data partition, mounted in /data. This is the only partition that is not erased during file system updates.
  1. Two identical system partitions (root file systems). These contain the operating system and the home directory (anything mounted under / that is not the data or boot partition). The reason there are two of these is to enable remote updates: An update running on one partition can update the other one without any effect to the currently running system. Note that the system partitions are erased during updates and are thus unsuitable for permanently storing information.
$ mkdir temp
$ mount /dev/mmcblk0p3 temp
Getting started
Assembling the N3XX
TODO: Sync with getting-started guide
Checklist:
  • Connect power and network
  • Read security settings
  • Connect clocking (if required)
  • Connect external LOs (if required)
Updating the file system
Before doing any major work with a newly acquired USRP N3XX, it is recommended to update the file system to the latest version. By default, the N3xx supports two methods of updating:
  1. Directly writing the latest SD card image. This requires physical access to the device. To do this, remove the SD card from the device, and plug it into another computer with an SD card reader. Download the latest SD card image file (it typically has a .sdimg file ending) and run the following command:
    $ sudo dd if=$yourimage.sdimg of=/dev/$yoursdcard bs=1M
    The $yoursdcard device node depends on your operating system and which other devices are plugged in. Typical values are sdb or mmcblk0.
  2. Using Mender to update. For more details on this procedure, see Section Mender: Remote update capability . This is possible without removing the SD card. Updates will take a bit longer though.
Serial connection
$ ls /dev/serial/by-id
usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0
usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0
usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0
usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to Linux, whereas the second connects to the STM32 microcontroller. If you have multiple N3XX devices connect, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
root@ni-n3xx-311FE00:~#
$ sudo screen /dev/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0 115200
SSH connection
$ ssh [email protected]
(TODO: Add the hostname thing here)
Network Connectivity
The SFP+ (eth1, eth2) ports are configured with static addresses 192.168.10.2/24 and 192.168.20.2/24 respectively.
The configuration for the ethX port is stored in /etc/systemd/networkd/ethX.network.
For configuration please refer to the manual pages systemd-networkd manual pages
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
eth1 (static):
    [Match]
    Name=eth1
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=9000
eth2 (static):
    [Match]
    Name=eth2
    [Network]
    Address=192.168.20.2/24
    [Link]
    MTUBytes=9000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /etc/systemd/networkd/eth1.network~), that systemd-networkd might pick up.
Note: Temporarily setting the IP addresses via ifconfig etc will only change the value until the next reboot / reload of the FPGA image.
Security-related settings
The N3XX ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA
tbw (using uhd_image_loader)
Using an N3XX USRP from UHD
auto usrp = uhd::usrp::multi_usrp::make("type=n3xx");
Device arguments
Key Description Supported Devices Example Value
addr IPv4 address of primary SFP+ port to connect to. All N3xx addr=192.168.30.2
second_addr IPv4 address of secondary SFP+ port to connect to. All N3xx second_addr=192.168.40.2
mgmt_addr IPv4 address or hostname which to connect the RPC client. Defaults to `addr'.All N3xx mgmt_addr=ni-sulfur-311FE00 (can also go to RJ45)
master_clock_rate Master Clock Rate in Hz N310 master_clock_rate=125e6
identify Causes front-panel LEDs to blink. The duration is variable. N310 identify=5 (will blink for about 5 seconds)
serialize_init Force serial initialization of daughterboards. All N3xx serialize_init=1
skip_dram Ignore DRAM FIFO block. Connect TX streamers straight into DUC or radio. All N3xx skip_dram=1
skip_ddc Ignore DDC block. Connect Rx streamers straight into radio. All N3xx skip_ddc=1
skip_duc Ignore DUC block. Connect Rx streamers or DRAM straight into radio. All N3xx skip_duc=1
skip_init Skip the initialization process for the device. All N3xx skip_init=1
ref_clk_freq Specify the external reference clock frequency, default is 10 MHz. N310 ref_clk_freq=20e6
init_cals Specify the bitmask for initial calibrations of the RFIC. N310 init_cals=BASIC
init_cals_timeout Timeout for initial calibrations in milliseconds. N310 init_cals_timeout=45000
discovery_port Override default value for MPM discovery port. All N3xx discovery_port=49700
rpc_port Override default value for MPM RPC port. All N3xx rpc_port=49701
tracking_cals Specify the bitmask for tracking calibrations of the RFIC. N310 tracking_cals=ALL
rx_lo_source Initialize the source for the RX LO. N310 rx_lo_source=external
tx_lo_source Initialize the source for the TX LO. N310 tx_lo_source=external
The sensor API
Remote Management
$ mender -rootfs /path/to/latest.mender
$ mender -rootfs http://server.name/path/to/latest.mender
$ reboot
$ mender -commit
If you are running a hosted server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is simple way to update groups of rack-mounted USRPs with custom file systems.
Salt: Remote configuration management and execution
$ systemctl start salt-minion
TODO: Add some example
Theory of Operation
tbw
N310-specific Features
RF Calibrations
Not all calibrations available on the AD9371 are applicable to the USRP N310. However, those calibrations that are applicable can be enabled/disabled at initialization time using the tracking_cals and init_cals device args (see also Device arguments). These device can be set to the precise bit mask the chip uses to set those calibrations (e.g., init_cals=0x4DFF,tracking_cals=0xC3) or they can use the following descriptive keys provided by UHD (e.g.init_cals=DEFAULT,tracking_cals=TX_QEC|RX_QEC). The | symbol can be used to combine keys (equivalent to a bitwise OR).
Key (init_cal) Function
TX_BB_FILTER Tx baseband filter calibration
ADC_TUNER ADC tuner calibration
TIA_3DB_CORNER Rx TIA filter calibration
DC_OFFSET Rx DC offset calibration
TX_ATTENUATION_DELAY Tx attenuation delay
RX_GAIN_DELAY Rx gain delay calibration
FLASH_CAL ADC flash calibration
PATH_DELAY Path delay calibration
TX_LO_LEAKAGE_INTERNAL Tx LO leakage internal initial calibration
TX_LO_LEAKAGE_EXTERNAL Tx LO leakage external initial calibration (requires external LO)
TX_QEC_INIT Tx QEC initial
LOOPBACK_RX_LO_DELAY Loopback ORx LO delay (ORx not connected by default!)
LOOPBACK_RX_RX_QEC_INIT Loopback Rx QEC initial calibration
RX_LO_DELAY Rx LO delay
RX_QEC_INIT Rx QEC initial calibration
BASIC Preset for minimal calibrations (TX_BB_FILTER, ADC_TUNER, TIA_3DB_CORNER, DC_OFFSET and FLASH_CAL)
OFF Preset for disabling all initial calibrations
DEFAULT Preset for enabling most calibrations (BASIC plus TX_ATTENUATION_DELAY, RX_GAIN_DELAY, PATH_DELAY, RX_QEC_INIT, TX_LO_LEAKAGE_INTERNAL, TX_QEC_INIT, LOOPBACK_RX_LO_DELAY)
ALL Enable all applicable calibrations
Key (tracking_cal) Function
TRACK_RX1_QEC Rx1 QEC tracking
TRACK_RX2_QEC Rx2 QEC tracking
TRACK_ORX1_QEC ORx1 QEC tracking
TRACK_ORX2_QEC ORx1 QEC tracking
TRACK_TX1_LOL Tx1 LO leakage tracking
TRACK_TX2_LOL Tx2 LO leakage tracking
TRACK_TX1_QEC Tx1 QEC tracking
TRACK_TX2_QEC Tx2 QEC tracking
OFF Disable all tracking
RX_QEC Enable all RX QEC tracking
TX_QEC Enable all TX QEC tracking
TX_LOL Enable all TX LO leakage tracking
DEFAULT Enable all QEC tracking
ALL Enable all tracking (except ORx)
External LOs
  • Improving phase alignment: The N310 itself has no way of aligning phase between channels, and phase will be random between runs. By applying an external LO, the phase ambiguity is reduced to 180 degrees, produced by a by-2 divider in the AD9371 transceiver IC.
  • Improving phase noise: The quality of the onboard LO depends on the external reference clock, among other things. By providing a custom LO signal, it is possible to more accurately tune, assuming the externally generated LO signal is coming from a high-quality oscillator.
Storing user data in the EEPROM
