Building and Installing UHD from source
Build Dependencies
C++ Compiler
  • GCC >= 4.8
  • Clang >= 3.3
  • MSVC >= 2015 (14.0); the free version works.
CMake
Boost
LibUSB
Python
  • Purpose: Used by mako build time, and utility scripts and the Python API at runtime
  • Minimum Version: 2.7
  • Usage: build time + runtime utility scripts (required)
  • Download URL: http://www.python.org/download/
Mako
  • Purpose: source code generation
  • Minimum Version: 0.5.0
  • Usage: build time (required)
  • Download URL: http://www.makotemplates.org/download.html
  • Alternative method: You can use pip or easy_install to install Mako from PyPi.
Doxygen
Git
On Windows, install Cygwin with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
Setting up the dependencies on Ubuntu
sudo apt-get install libboost-all-dev libusb-1.0-0-dev python-mako doxygen python-docutils cmake build-essential
Setting up the dependencies on Fedora
sudo yum -y install boost-devel libusb1-devel python-mako doxygen python-docutils cmake make gcc gcc-c++
or
sudo dnf -y install boost-devel libusb1-devel python-mako doxygen python-docutils cmake make gcc gcc-c++
Getting the source code
The UHD source is stored in a Git repository. To download it, follow these instructions:
git clone git://github.com/EttusResearch/uhd.git
If you also want the FPGA code (which is not necessary for building UHD and applications which depend on it), run:
git clone --recursive git://github.com/EttusResearch/uhd.git
This will populate the fpga-src submodule inside the repository. You can also do this after cloning the repository by running these commands from the top level source directory:
git submodule init
git submodule update
Our source code repository contains of two main branches:
  • master: This is the main development branch, with updated new features and bug fixes.
  • maint: This branch has all bugfixes since the last major release, but there are no new features. This is what you should be using if you need a stable release.
Using PyBOMBS
$ pybombs install uhd
Build Instructions (Unix)
Generate Makefiles with CMake
cd <uhd-repo-path>/host
mkdir build
cd build
cmake ../
  • For a custom install prefix: -DCMAKE_INSTALL_PREFIX=<install-path>
  • To install libs into lib64: cmake -DLIB_SUFFIX=64
Example usage:
Build and install
make
make test
sudo make install
Setup the library path (Linux)
sudo ldconfig
Build Instructions (Windows)
Generate the project with CMake
  • Open the CMake GUI.
  • Set the path to the source code: <uhd-repo-path>/host.
  • Set the path to the build directory: <uhd-repo-path>/host/build.
  • Make sure that the paths do not contain spaces.
  • Click "Configure" and select "Microsoft Visual Studio 10".
  • Set the build variables
    • Boost_INCLUDE_DIR should point to the PATH where the Boost .hpp files are, e.g. C:\local\boost_version\boost
    • Boost_LIBRARY_DIR should point to the pre-built libraries, e.g. C:\local\boost_version\lib64-msvc-14.0)
  • Click "Generate", and a project file will be created in the build directory.
Compile and Install with Visual Studio
  • Open the <uhd-repo-path>\\host\\build\\ALL_BUILD.vcxproj in visual studio, generate the project. Watch the output console for errors.
  • If you did not specify a CMAKE_INSTALL_PREFIX where your user has write privileges, you must close Visual Studio, run it again with Administrator Privileges, and open ALL_BUILD.vcxproj.
  • Right click on the INSTALL project in the project explorer, generate it. Watch the output console for errors.
LibUSB notes
On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
  • From the CMake GUI, select "Advanced View".
  • Set LIBUSB_INCLUDE_DIRS to the directory with libusb.h.
  • Set LIBUSB_LIBRARIES to the full path for libusb-1.0.lib.
  • Recommend the static libusb-1.0.lib to simplify runtime dependencies.
  • Check the box to enable USB support, click "Configure" and "Generate".
Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
Build the project in MSVC
  • Open the generated project file in MSVC.
  • Change the build type from "Debug" to "Release".
  • Select the "Build All" target, right-click, and choose "Build".
  • Select the install target, right-click, and choose "Build".
Build the project in MSVC (command line)
cd <uhd-repo-path>\host\build
DevEnv uhd.sln /build Release /project ALL_BUILD
DevEnv uhd.sln /build Release /project INSTALL
Setup the PATH environment variable
X11/XQuartz or Terminal
Xcode
xcode-select --install
Background Dependencies
sudo port install uhd
sudo port uninstall uhd
NOTE: Other package managers (e.g., Fink, HomeBrew) will require different commands than the above to install all dependencies and then remove the UHD install. Please consult the specific package manager in use for how to do these commands properly; they will not be covered here.
Compiling UHD from Source
$ mkdir build
$ cd build
$ CC=/usr/bin/llvm-gcc CXX=/usr/bin/llvm-g++ cmake -DCMAKE_INSTALL_PREFIX=/opt/local -DPYTHON_EXECUTABLE=/opt/local/bin/python2.7 -DPYTHON_INCLUDE_DIR=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Headers -DPYTHON_LIBRARY=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Python ../host
$ make
$ make test
To install the build, issue
$ sudo make install
Post-Install Tasks
  • After installing, you might want to download the FPGA images packages by running uhd_images_downloader on the command line, or one of these executables (the actual path may differ based on your installation):
    • Linux: /usr/local/lib/uhd/utils/uhd_images_downloader.py
    • Windows: C:\Program Files\share\uhd\utils\uhd_images_downloader.py
    • Mac OS X: In MacPorts, when UHD is installed the images are automatically downloaded and installed into their proper location. For any other package manager or install method, you should execute the uhd_images_downloader.py script to get the images installed appropriately.
  • For USB-Based devices, make sure to read USB Transport (LibUSB) for platform-specific post-installation tasks.
Building applications that require UHD using CMake
find_package(UHD "3.10.0")
Static Builds
