The E320 is a 2-channel transmitter/receiver based on the AD9361 transceiver IC. It is a monolithic board with one AD9361 and provides two RF channels.
The main CPU of the E320 is a Xilinx Zynq SoC XC7Z045. It is both a dual-core ARM Cortex A9 CPU and Kintex-7 FPGA on a single die. The CPU is clocked at 1GHz (speedgrade 3).
The E320 uses a micro SD card as its main storage. The entire root file system (Linux kernel, libraries) and any user data are stored on this SD card.
This will run you through the first steps relevant to getting your USRP E320 up and running. Note: This guide was creating on an Ubuntu machine, and other distributions or OS's may have different names/methods.
Unlike the X300 or N200 series, there is no assembly of required since it is a monolithic board.
Checklist:
To obtain the default micro SD card image for a specific version of UHD, install that version of UHD (3.13.0.2 or later) on a host system with Internet access and run:
$ uhd_images_downloader -t e320 -t sdimg
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_e320_fs.sdimg
, where <UHD_INSTALL_DIR>
is the UHD installation directory.
The <YOUR_IMAGE>
is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_e320_fs.sdimg
The <YOUR_SD_CARD>
device node depends on your operating system and which other devices are plugged in. Typical values are sdb
or mmcblk0
CAUTION: The Linux utility dd
or bmap
can cause unrecoverable data loss if the incorrect disk is selected, or if the parameters are input incorrectly. Ensure you have selected the correct input and output parameters for your system configuration.
In this command, we prepend 'sudo' to elevate user privileges (by default, accessing serial ports is not available to regular users), we specify the device node (in this case, /dev/ttyUSB2
), and the baud rate (115200).
The exact device node depends on your operating system's driver and other USB devices that might be already connected. Modern Linux systems offer alternatives to simply trying device nodes; instead, the OS might have a directory of symlinks under /dev/serial/by-id
$ ls /dev/serial/by-id /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if00-port0 /dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if01-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if00-port0 /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if01-port0
Every E320 device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The one with the if01
suffix connects to Linux, whereas the one with if00
suffix connects to the STM32 microcontroller. If you have multiple E320 devices connected, you may have to try out multiple devices. In this case, to use this symlink instead of the raw device node address, modify the command above to:
root@ni-e320-311FE00:~#
The USRP E320 devices have two network connections: One SFP port, and an RJ-45 connector. The latter is by default configured by DHCP; by plugging it into into 1 Gigabit switch on a DHCP-capable network, it will get assigned an IP address and thus be accessible via ssh.
$ ssh root@ni-e320-311FE00 # Replace with your actual device name!
Depending on your network setup, using a .local
domain may work:
$ ssh [email protected]
Note: The device's hostname is derived from its serial number by default (ni-e320-<SERIAL>
). You can change the hostname by modifying the /etc/hostname
file and rebooting.
The SFP+ (sfp0) port is configured with static address 192.168.10.2/24
The configuration for the sfp0 port is stored in /etc/systemd/networkd/sfp0.network.
eth0 (DHCP): [Match] Name=eth0 [Network] DHCP=v4 [DHCPv4] UseHostname=false sfp0 (static): [Match] Name=sfp0 [Network] Address=192.168.10.2/24 [Link] MTUBytes=8000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /etc/systemd/networkd/sfp0.network~), that systemd-networkd might accidentally pick up.
The E320 ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA follows the same procedure as other USRPs. Use the uhd_image_loader
command line utility to upload a new FPGA image onto the device. The command can be run on the host to load the image via RJ-45 network connection or it can be run on the device.
$ uhd_image_loader --args type=e3xx,addr=ni-e320-311fe00
to update the FPGA using the default settings. Replace ni-e320-311fe00 in the addr with the correct device address. If a custom FPGA image is targeted for uploading, use the --fpga-path
command line argument. Run
$ uhd_image_loader --help
to see a full list of command line options. Note that updating the FPGA image will force a reload of the FPGA, which will temporarily take down the SFP network interfaces (and temporary settings, such as applied via ifconfig
on the command line, will be lost).
Like any other USRP, all E320 USRPs are controlled by the UHD software. To integrate a USRP E320 into your C++ application, you would generate a UHD device in the same way you would for any other USRP:
Key | Description | Example Value |
addr | IPv4 address of primary SFP+ port to connect to. | addr=192.168.30.2 |
find_all | When using broadcast, find all devices, even if unreachable via CHDR. | find_all=1 |
master_clock_rate | Master Clock Rate in Hz. Default is 16 MHz. | master_clock_rate=30.72e6 |
serialize_init | Force serial initialization of daughterboards. | serialize_init=1 |
skip_dram | Ignore DRAM FIFO block. Connect TX streamers straight into DUC or radio. | skip_dram=1 |
skip_ddc | Ignore DDC block. Connect Rx streamers straight into radio. | skip_ddc=1 |
skip_duc | Ignore DUC block. Connect Tx streamers or DRAM straight into radio. | skip_duc=1 |
skip_init | Skip the initialization process for the device. | skip_init=1 |
ref_clk_freq | Specify the external reference clock frequency, default is internal (20 MHz). | ref_clk_freq=10e6 |
init_cals | Specify the bitmask for initial calibrations of the RFIC. | init_cals=BASIC |
init_cals_timeout | Timeout for initial calibrations in milliseconds. | init_cals_timeout=45000 |
discovery_port | Override default value for MPM discovery port. | discovery_port=49700 |
rpc_port | Override default value for MPM RPC port. | rpc_port=49701 |
tracking_cals | Specify the bitmask for tracking calibrations of the RFIC. | tracking_cals=ALL |
Like other USRPs, the E320 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
temp_internal
: temperature (in C) of Temperature Sensor on boardtemp_fpga
: temperature (in C) of the FPGA dietemp_rf_channelA
: temperature (in C) near power amplifier RF Atemp_rf_channelB
: temperature (in C) near power amplifier RF Btemp_main_power
: temperature (in C) near power supplygps_locked
: GPS lockgps_time
: GPS time in seconds sin ce the epchgps_tpv
: A TPV report from GPSd serialized as JSONgps_sky
: A SKY report from GPSd serialized as JSONref_locked
: This will check that all the daughterboards have locked to the external/internal reference clock.fan
: get fan speed (in rpm)Mender is a third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Mender servers can be self-hosted, or hosted by Mender (see mender.io for pricing and availability).
To initiate an update from the device itself, download a Mender artifact containing the update itself. These are files with a .mender
suffix.
$ mender -rootfs /path/to/latest.mender
$ mender -rootfs http://server.name/path/to/latest.mender
$ reboot
$ mender -commit
If you are running a hosted server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is simple way to update groups of rack-mounted USRPs with custom file systems.
Salt (also known as SaltStack, see Salt Website) is a Python-based tool for maintaining fleets of remote devices. It can be used to manage USRP E320 remotely for all types of settings that are not controlled by UHD. For example, if an operator would like to reset the root password on multiple devices, or install custom software, this tool might be a suitable choice.
Salt is a third-party project with its own documentation, which should be consulted for configuring it. However, the Salt minion is installed by default on every E320 device. To start it, simply log on to the device and run:
$ systemctl start salt-minion
apt install salt-master
if the server is an Ubuntu system), and make sure the Salt master is running./etc/salt/minion
file on the device by editing the master:
line.systemctl start salt-minion
.salt-key -a $hostname
where $hostname
is the name of the minion.Once the device is authorized, you can try various commands to see if the communication was established:
$ [sudo] salt '*' test.ping ni-n3xx-$serial: True $ [sudo] salt '*' network.interfaces
hwaddr: 02:00:03:11:fe:00 inet:
address: xx.xx.xx.xx broadcast: xx.xx.xx.xx label: eth0 netmask: 255.255.254.0 up: True
E320 is on the MPM architecture (see also: The Module Peripheral Manager (MPM) Architecture). Inside the Linux operating system running on the ARM cores, there is hardware daemon which needs to be active in order for the device to function as a USRP (it is enabled to run by default).
$ mkdir uhd # Create a new, empty directory called uhd $ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the device
$ mkdir build_mpm $ cd build_mpm # You are now in /home/root/build_mpm $ cmake -DMPM_DEVICE=e320 ../uhd/mpm $ make -j2 install # This will take several minutes
Note that this overwrites your system MPM. You can install MPM to another location by specifying -DCMAKE_INSTALL_PREFIX
, but make sure to update all of your paths appropriately.
The recommended way to develop software for the E320 is to cross-compile. By running the compiles on a desktop or laptop computer, you will be able to speed up compile times considerably (compiling UHD natively for the E320 would take many hours).
$ ./oecore-x86_64-cortexa9hf-neon-toolchain-nodistro.0.sh
This will prompt you for an installation path. Please ensure you have sufficient disk space, as each of the SDKs may require several gigabytes of disk space (depends on the image flavor selected).
This will modify the PATH, CC, CXX etc, environment variables and allow you to compile software for your USRP E320 device. To verify all went well you can try:
$ $CC -dumpmachine
Note: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your E320.
AXI Slave | Address Range | UIO Label | Description |
Slave 0 | 4000_0000 - 4000_3fff | - | Ethernet DMA SFP |
Slave 1 | 4000_4000 - 4000_4fff | misc-enet-regs | Ethernet registers SFP |
Slave 2 | 4001_0000 - 4001_3fff | mboard-regs | Motherboard control |
Slave 3 | 4001_4000 - 4001_41ff | dboard-regs | Daughterboard control |
AXI Slave | Module | Address | Name | Read/Write | Description |
Slave 0 | axi_eth_dma | 4000_0000 - 4000_4fff | Ethernet DMA | RW | See Linux Driver |
Slave 1 | e320_mgt_io_core | 4000_4000 | PORT_INFO | RO | SFP port information |
[31:24] | COMPAT_NUM | RO | - | ||
[23:18] | 6'h0 | RO | - | ||
[17] | activity | RO | - | ||
[16] | link_up | RO | - | ||
[15:8] | mgt_protocol | RO | 0 - None, 1 - 1G, 2 - XG, 3 - Aurora | ||
[7:0] | PORTNUM | RO | - | ||
e320_mgt_io_core | 4000_4004 | MAC_CTRL_STATUS | RW | Control 10gE and Aurora mac | |
[0] | ctrl_tx_enable (PROTOCOL = "10GbE") | RW | - | ||
[0] | bist_checker_en (PROTOCOL = "Aurora") | RW | - | ||
[1] | bist_gen_en | RW | - | ||
[2] | bist_loopback_en | RW | - | ||
[8:3] | bist_gen_rate | RW | - | ||
[9] | phy_areset | RW | - | ||
[10] | mac_clear | RW | - | ||
e320_mgt_io_core | 4000_4008 | PHY_CTRL_STATUS | RW | Phy reset control | |
e320_mgt_io_core | 4000_400C | MAC_LED_CTL | RW | Used by ethtool to indicate port | |
[1] | identify_enable | RW | - | ||
[0] | identify_value | RW | - | ||
mdio_master | 4000_4010 | MDIO_DATA | RW | - | |
4000_4014 | MDIO_ADDR | RW | - | ||
4000_4018 | MDIO_OP | RW | - | ||
4000_401C | MDIO_CTRL_STATUS | RW | - | ||
e320_mgt_io_core | 4000_4020 | AURORA_OVERUNS | RO | - | |
4000_4024 | AURORA_CHECKSUM_ERRORS | RO | - | ||
4000_4028 | AURORA_BIST_CHECKER_SAMPS | RO | - | ||
4000_402C | AURORA_BIST_CHECKER_ERRORS | RO | - | ||
eth_switch | 4000_5000 | MAC_LSB | RW | Device MAC LSB | |
4000_5004 | MAC_MSB | RW | Device MAC MSB | ||
4000_6000 | IP | RW | Device IP | ||
4000_6004 | PORT1, PORT0 | RW | Device UDP port | ||
eth_dispatch | 4000_6008 | [1] ndest, [0] bcast | RW | Enable Crossover | |
4000_600c | [1] my_icmp_type, [0] my_icmp_code | - | |||
eth_switch | 4000_6010 | BRIDGE_MAC_LSB | Bridge SFP ports in ARM | ||
4000_6014 | BRIDGE_MAC_MSB | - | |||
4000_6018 | BRIDGE_IP | - | |||
4000_601c | BRIDGE_PORT1, BRIDGE_PORT0 | - | |||
4000_6020 | BRIDGE_EN | - | |||
chdr_eth_framer | 4000_6108 onwards | LOCAL_DST_IP | W | Destination IP, MAC, UDP for Outgoing Packet for 256 SIDs | |
4000_6208 onwards | LOCAL_DST_UDP_MAC_MSB | W | Destination MAC for outgoing packets (MSB) | ||
4000_6308 onwards | LOCAL_DST_MAC_LSB | W | Destination MAC for outgoing packets (LSB) | ||
4000_7000 onwards | REMOTE_DST_IP | W | Destination IP, MAC, UDP for Outgoing Packet for 16 local addrs | ||
4000_7400 onwards | REMOTE_DST_UDP_MAC_HI | W | Destination MAC (MSB) | ||
4000_7800 onwards | REMOTE_DST_MAC_LO | W | Destination MAC (LSB) | ||
Slave 2 | e320_core | 4001_0000 | COMPAT_NUM | R | FPGA Compat Number |
[31:16] | Major | RO | - | ||
[15:0] | Minor | RO | - | ||
4001_0004 | DATESTAMP | RO | - | ||
4001_0008 | GIT_HASH | RO | - | ||
4001_000C | SCRATCH | RO | - | ||
4001_0010 | NUM_CE | RO | Number of Computation Engines (RFNoC Blocks) | ||
4001_0014 | NUM_IO_CE | RO | Number of fixed IO CEs - Radios + DMA Fifo | ||
4001_0018 | CLOCK_CTRL | - | |||
[0] | pps select (internal 10 MHz) | RW | One-hot encoded pps_select to use the internal PPS from GPSDO | ||
[1] | pps select (external 10 MHz) | RW | One-hot encoded pps_select to use the external PPS. | ||
[2] | refclk_select (internal/external 10 MHz) | RW | refclk_select=0 for internal (GPSDO) 10 MHz, refclk_sel=1 for external 10 MHz. | ||
4001_001C | XADC_READBACK | RO | - | ||
[11:0] | FPGA temperature | RO | - | ||
4001_0020 | BUS_CLK_RATE | RO | - | ||
4001_0024 | BUS_CLK_COUNT | RO | - | ||
4001_0028 | SFP_PORT_INFO | RO | Same as port_info register 0x4000_4000 | ||
4001_002C | FP_GPIO_CTRL | RW | - | ||
4001_0030 | FP_GPIO_MASTER | RW | - | ||
4001_0034 | FP_GPIO_RADIO_SRC | RW | - | ||
4001_0038 | GPS_CTRL | RW | - | ||
[0] | GPS_PWR_EN | RW | Power on GPSDO | ||
[1] | GPS_RST_N | RW | - | ||
[2] | GPS_INITSURV_N | RW | - | ||
4001_003C | GPS_STATUS | RO | GPSDO Status | ||
[0] | GPS_LOCK | RO | Returns 1 if GPSDO is locked | ||
[1] | GPS_ALARM | RO | - | ||
[2] | GPS_PHASELOCK | RO | - | ||
[3] | GPS_SURVEY | RO | - | ||
[4] | GPS_WARMUP | RO | - | ||
4001_0040 | DBOARD_CTRL | RO | - | ||
4001_0044 | DBOARD_STATUS | RO | - | ||
axi_crossbar | 4001_1010 | XBAR_VERSION | RO | See crossbar kernel driver | |
4001_1014 | XBAR_NUM_PORTS | RO | See crossbar kernel driver | ||
4001_1018 | LOCAL_ADDR | RW | See crossbar kernel driver | ||
4001_1020 | remote_offset | WO | XBAR settings reg | ||
4001_1420 | local_offset | WO | XBAR settings reg | ||
Slave 4 | 4001_4000 | 4001_41FF | Daughterboard Registers | - | Don't exist now. TBD |
