USRP E3xx Series
Comparative features list
  1. E310 series which includes E310, E312 and E313.
  2. E320 - OEM board-only and with enclosure.
  • TX band: 47 MHz to 6.0 GHz
  • RX band: 70 MHz to 6.0 GHz
  • 56 MHz of instantaneous bandwidth
  • 2 RX DDC chains in FPGA
  • 2 TX DUC chain in FPGA
E310
  • Hardware Capabilities:
    • 2 USB 2.0 Host ports
    • Configurable clock rate
    • Internal IMU
    • Internal GPS
    • Internal GPIO connector with UHD API control
    • External USB Connection for built-in JTAG debugger and serial console
    • Xilinx Zynq SoC with dual-core ARM Cortex A9 (Speed Grade 1 and 3) and Kintex-7 FPGA (XC7Z020)
  • Software Capabilities:
  • FPGA Capabilities:
    • RFNoC capability
E320
    • Single SFP+ Transceivers (can be used with 1 GigE, 10 GigE, and Aurora)
    • External PPS input
    • External 10 MHz input
    • Internal IMU
    • Internal GPSDO for timing, location, and 10 MHz reference clock + PPS
    • Xilinx Zynq SoC with dual-core ARM Cortex A9 (Speedgrade 3) and Kintex-7 FPGA (XC7Z045)
    • Fan connector (for board-only version)
    • RFNoC capability
E310 Overview
The Zynq CPU/FPGA and host operating system
E310 Migration Guide to MPM architecture
Here is a list of a changes with the latest E310 filesystem (UHD v3.15.0.0) that can affect customer usage and applications:
  1. Hostname: The hostname for the devices have changed from ni-e3xx(-sg3) to ni-e31x-<serial>. This makes it easier to identify devices. You can change the hostname by modifying the /etc/hostname file and rebooting.
  2. "product" name: The "product" name for E310 is now "e310_<speedgrade>" i.e. e310_sg1 and e310_sg3 for speed grade 1 and 3 respectively. Note that the "type" for e310 remains the same as before i.e. "e3xx".
  3. FPGA bit/bin/rpt file name and image target:
    FPGA type Old filename New filename
    IDLE Image (power saving mode) SG1 usrp_e3xx_fpga_idle.bit usrp_e310_sg1_idle_fpga.bit
    IDLE Image (power saving mode) SG3 usrp_e3xx_fpga_idle_sg3.bit usrp_e310_sg3_idle_fpga.bit
    NORMAL Image SG1 usrp_e310_fpga.bit usrp_e310_sg1_fpga.bit
    NORMAL Image SG3 usrp_e310_fpga_sg3.bit usrp_e310_sg3_fpga.bit
    The names of the FPGA build targets have been modified but the old FPGA targets would continue to work as before. The generated bit files names in the build directory will be new as mentioned above.
    • E310_<speedgrade> for default image
    • E310_<speedgrade>_RFNOC for RFNOC image (contains a few blocks)
    • E310_<speedgrade>_IDLE to build idle image (Doesn't need to modified for most cases)
  4. Loading FPGA image: The device arg "fpga=" can now only be used in the uhd_image_loader; it can no longer be used to update the fpga image in other UHD applications. This tooling now matches X310, E320, N3XX, etc. devices. See section Updating the FPGA for details.
  5. With UHD v3.15.0.0. or higher, a lot of UHD dependencies have been upgraded too e.g. Boost, CMake, etc. The filesystem now runs a newer Linux kernel (e.g. linux-yocto_4.15 or higher). Existing customer applications might need to be updated in order to use the new filesystem and new UHD.
  6. In order to build a custom filesystem, refer to Building custom filesystems and SD card images for more details.
  7. E310 filesystem no longer contains GNURadio by default. Custom filesystems are need to run GNURadio.
  8. The network mode (streaming through RJ-45) for the E310 is not supported. In order to use the network mode use UHD 3.9 LTS release.
  9. Refer section Battery notes for changes related to the battery.
  10. Subdev spec has been changed from "A:A and A:B" to "A:0 and A:1" to match X310, N3xx and E320.
E320 Overview
The STM32 microcontroller
The SD card
  • Boot partition (contains the bootloader). This partition usually does not require any modifications.
  • A data partition, mounted in /data. This is the only partition that is not erased during file system updates.
  • Two identical system partitions (root file systems). These contain the operating system and the home directory (anything mounted under / that is not the data or boot partition). The reason there are two of these is to enable remote updates: An update running on one partition can update the other one without any effect to the currently running system. Note that the system partitions are erased during updates and are thus unsuitable for permanently storing information.
$ mkdir temp
$ mount /dev/mmcblk0p3 temp
Getting started
Assembling the E3XX
Checklist:
  • Connect power and network
  • Read security settings
  • Connect clocking (if required)
Updating the file system
E310/E312/E313 file system
E320 file system
Updating the SD card
Using Docker to build filesystems
Serial connection
For E310:
$ ls /dev/serial/by-id
/dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DQ0041HO-if00-port0
For E320:
/dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if00-port0
/dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if01-port0
/dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if00-port0
/dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if01-port0
For E310:
For E320:
SSH connection
Note: The device's hostname is derived from its serial number by default (ni-<e31x/e320>-<SERIAL>). You can change the hostname by modifying the /etc/hostname file and rebooting.
Network Connectivity
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
E320 has an extra SFP+ (sfp0) port which is configured with static address 192.168.10.2/24. The configuration for the sfp0 port is stored in /etc/systemd/networkd/sfp0.network.
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=8000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /etc/systemd/networkd/sfp0.network~), that systemd-networkd might accidentally pick up.
Security-related settings
The E320 ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA
$ uhd_images_downloader
$ uhd_image_loader --help
Using an E3XX USRP from UHD
auto usrp = uhd::usrp::multi_usrp::make("type=e3xx");
Device arguments
Key Description Example Value
addr IPv4 address of primary SFP+/RJ-45 port to connect to addr=192.168.30.2
find_all When using broadcast, find all devices, even if unreachable via CHDR. find_all=1
master_clock_rate Master Clock Rate in Hz. Default is 16 MHz. master_clock_rate=30.72e6
skip_dram Ignore DRAM FIFO block. Connect TX streamers straight into DUC or radio. skip_dram=1
skip_ddc Ignore DDC block. Connect Rx streamers straight into radio. skip_ddc=1
skip_duc Ignore DUC block. Connect Tx streamers or DRAM straight into radio. skip_duc=1
skip_init Skip the initialization process for the device. skip_init=1
discovery_port Override default value for MPM discovery port. discovery_port=49700
rpc_port Override default value for MPM RPC port. rpc_port=49701
The sensor API
E31X Sensors
Like other USRPs, the E310 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
  • temp_fpga: temperature (in Celsius) of the FPGA die
  • temp_mb: temperature (in Celsius) of the motherboard
  • ref_locked: This will check that all the daughter boards have locked to the reference clock.
E320 Sensors
Like other USRPs, the E320 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
  • temp_internal: temperature (in Celsius) of Temperature Sensor on board
  • temp_rf_channelA: temperature (in Celsius) near power amplifier RF A
  • temp_rf_channelB: temperature (in Celsius) near power amplifier RF B
  • temp_main_power: temperature (in Celsius) near power supply
  • gps_locked: GPS lock
  • gps_time: GPS time in seconds sin ce the epch
  • gps_tpv: A TPV report from GPSd serialized as JSON
  • gps_sky: A SKY report from GPSd serialized as JSON
  • ref_locked: This will check that all the daughter boards have locked to the external/internal reference clock.
  • fan: get fan speed (in rpm)
Remote Management
Mender: Remote update capability
$ mender -rootfs /path/to/latest.mender
$ mender -rootfs http://server.name/path/to/latest.mender
$ reboot
$ mender -commit
If you are running a hosted server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is simple way to update groups of rack-mounted USRPs with custom file systems.
Salt: Remote configuration management and execution
$ systemctl start salt-minion
  1. Install the salt-master package on the server (e.g. by running apt install salt-master if the server is an Ubuntu system), and make sure the Salt master is running.
  2. Add the network address / hostname of that server to the /etc/salt/minion file on the device by editing the master: line.
  3. Launch the Salt minion on the USRP by running the command systemctl start salt-minion.
  4. The minion will try to connect to the master. You need to authorize the minion by running salt-key -a $hostname where $hostname is the name of the minion.
  5. Once the device is authorized, you can try various commands to see if the communication was established:
$ [sudo] salt '*' test.ping
ni-e3xx-$serial:
True
ni-e3xx-$serial:
eth0:
hwaddr:
02:00:03:11:fe:00
inet:
|_
address:
xx.xx.xx.xx
broadcast:
xx.xx.xx.xx
label:
eth0
netmask:
255.255.254.0
up:
True
Theory of Operation
Modifying and compiling UHD and MPM for the E320
Compiling MPM natively
$ mkdir uhd # Create a new, empty directory called uhd
$ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the device
$ mkdir build_mpm
$ cd build_mpm # You are now in /home/root/build_mpm
$ cmake ../uhd/mpm
$ make -j2 install # This will take several minutes
Obtaining an SDK
$ cd /usr/local/share/uhd/images # Change this to where your images are stored
$ ./oecore-x86_64-cortexa9hf-neon-toolchain-nodistro.0.sh
SDK Usage
$ $CC -dumpmachine
Building UHD
  2. Set up your environment as described in SDK Usage
     $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. # Add any CMake options you desire
     $ make # You can run make -j12 to compile on 12 processes at once
Note: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your device.
Building GNU Radio
  1. Obtain the GNU Radio source code via git or tarball
$ mkdir build-arm
$ cd build-arm
-DENABLE_GR_DTV=OFF -DENABLE_DOXYGEN=OFF ../ # Append any CMake options you desire
E310-specific Features
Front Panel
USRP E310 Front panel
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend side A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend side A
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend B
  • PWR: Power switch with integrated status LED, for status description see below.
  • SYNC: Input port for external PPS signal
  • Version 1 (original E310)
    • Off: Indicates device is off and not charging
    • Solid Red: Indicates device is charging
    • Solid Green: Indicates device is on
    • Fast Blinking Red: Indicates an error code
      • 1 - Low voltage error
      • 2 - Regulator low voltage error
      • 3 - FPGA power error
      • 4 - DRAM power error
      • 5 - 1.8V rail power error
      • 6 - 3.3V rail power error
      • 7 - Daughterboard / TX power error
      • 9 - Temperature error
  • Version 2 (E312 and upgraded E310)
    • Slow Blinking Green: Indicates device is off and charging
    • Fast Blinking Green: Indicates device is on and charging
    • Solid Green: Indicates device is on (and not charging, if E312)
    • Solid Orange: Indicates device is on and discharging
    • Fast Blinking Orange: Indicates device is on, discharging, and charge is below 10% charge
      • 8 - Charger error
      • 9 - Charger temperature error
      • 10 - Battery low error
      • 11 - Fuel Gauge temperature error
      • 12 - Global (case) temperature error
Rear Panel
USRP E310 Rear Panel
  • PWR: Locking connector (Kycon KLDHCX-0202-A-LT) for the USRP-E Series power supply
  • 1G ETH: RJ45 port for Ethernet interfaces
  • USB: USB 2.0 Port
  • SERIAL: Micro USB connection for serial uart console
Clock and Time Synchronization
PPS - Pulse Per Second
Internal GPS
The device provides a 3.3V supply voltage to an external antenna connected to the GPS port of your device. Note that this supply voltage is turned off in order to safe power upon destruction of the software object.
Internal GPIO
Connector
E3xx GPIO Connector
Pin Mapping
  • Pin 1: +3.3V
  • Pin 2: Reserved
  • Pin 3: Data[5]
  • Pin 4: Reserved
  • Pin 5: Data[4]
  • Pin 6: Data[0]
  • Pin 7: Data[3]
  • Pin 8: Data[1]
  • Pin 9: 0V
  • Pin 10: Data[2]
Connector
E3xx JTAG Connector
Pin Mapping
  • Pin 1: TDO
  • Pin 2: 3.3V
  • Pin 3: TCK
  • Pin 4: TDI
  • Pin 5: 0V
  • Pin 6: TMS
Battery notes
Connector
Battery pack connector
The pins are as follows:
  • Pin 1 (Red): VBat
  • Pin 2 (Black): GND
  • Pin 3 (White): Battery Thermistor
Driver
and for the charger:
SUBSYSTEM=="power_supply", ATTR{online}=="1", ATTR{temp}=="730", RUN+="/sbin/shutdown -h now"
Calibration Procedure
  1. Completely discharge battery (e.g. by booting up without SD card, so OS doesn't auto shutdown)
  2. Unplug the battery pack and external power
  3. Reconnect the battery pack
  4. Reconnect AC power and charge until charge completed.
  1. Completely charge battery
  2. Type:
  3. Unplug AC power
  4. Replug AC power and wait until charge completes
Daughterboard notes
Frontend tuning
Frontend gain
Frontend LO lock status
// assumes 'usrp' is a valid uhd::usrp::multi_usrp::sptr instance
// get status for rx frontend
usrp->get_rx_sensor("lo-locked");
// get status for tx frontend
usrp->get_tx_sensor("lo-locked");
Frontend Filter and Antenna Switches
Frontend Side A Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX2_V1,V2 VCRX2_V1,V2 RX2_BANDSEL[2:0] RX2B_BANDSEL[1:0] RX2C_BANDSEL[1:0]
TRX-A < 450 01 10 101 XX 01
TRX-A 450 – 700 01 10 011 XX 11
TRX-A 700 – 1200 01 10 001 XX 10
TRX-A 1200 – 1800 01 10 000 01 XX
TRX-A 1800 – 2350 01 10 010 11 XX
TRX-A 2350 – 2600 01 10 100 10 XX
TRX-A 2600 – 6000 01 01 XXX XX XX
RX2-A 70 – 450 TT 01 101 XX 01
RX2-A 450 – 700 TT 01 011 XX 11
RX2-A 700 – 1200 TT 01 001 XX 10
RX2-A 1200 – 1800 TT 01 000 01 XX
RX2-A 1800 – 2350 TT 01 010 11 XX
RX2-A 2350 – 2600 TT 01 100 10 XX
RX2-A >= 2600 TT 10 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX2_V1,V2 TX_ENABLE2A,2B TX_BANDSEL[2:0]
TRX-A < 117.7 10 01 111
TRX-A 117.7 – 178.2 10 01 110
TRX-A 178.2 – 284.3 10 01 101
TRX-A 284.3 – 453.7 10 01 100
TRX-A 453.7 – 723.8 10 01 011
TRX-A 723.8 – 1154.9 10 01 010
TRX-A 1154.9 – 1842.6 10 01 001
TRX-A 1842.6 – 2940.0 10 01 000
TRX-A >= 2940.0 11 10 XXX
Frontend Side B Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX1_V1,V2 VCRX1_V1,V2 RX1_BANDSEL[2:0] RX1B_BANDSEL[1:0] RX1C_BANDSEL[1:0]
TRX-B < 450 10 01 100 XX 10
TRX-B 450 – 700 10 01 010 XX 11
TRX-B 700 – 1200 10 01 000 XX 01
TRX-B 1200 – 1800 10 01 001 10 XX
TRX-B 1800 – 2350 10 01 011 11 XX
TRX-B 2350 – 2600 10 01 101 01 XX
TRX-B 2600 – 6000 10 10 XXX XX XX
RX2-B 70 – 450 TT 01 100 XX 10
RX2-B 450 – 700 TT 01 010 XX 11
RX2-B 700 – 1200 TT 01 000 XX 01
RX2-B 1200 – 1800 TT 01 001 10 XX
RX2-B 1800 – 2350 TT 01 011 11 XX
RX2-B 2350 – 2600 TT 01 101 01 XX
RX2-B >= 2600 TT 10 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX1_V1,V2 TX_ENABLE1A,1B TX1_BANDSEL[2:0]
TRX-B < 117.7 00 01 111
TRX-B 117.7 – 178.2 00 01 110
TRX-B 178.2 – 284.3 00 01 101
TRX-B 284.3 – 453.7 00 01 100
TRX-B 453.7 – 723.8 00 01 011
TRX-B 723.8 – 1154.9 00 01 010
TRX-B 1154.9 – 1842.6 00 01 001
TRX-B 1842.6 – 2940.0 00 01 000
TRX-B >= 2940.0 11 10 XXX
E320-specific Features
Front and Rear Panel
Front Panel GPIO
Front Panel GPIO Connections
GPIO Mini HDMI (Type C) HDMI (Type A)
Data[0] Data 0+ - Pin 8 Pin 7
Data[1] Data 0- - Pin 9 Pin 9
Data[2] Clock 0+ - Pin 11 Pin 10
Data[3] Clock 0- - Pin 12 Pin 12
Data[4] CEC - Pin 14 Pin 13
Data[5] SCL - Pin 15 Pin 15
Data[6] SDA - Pin 16 Pin 16
Data[7] Utility - Pin 17 Pin 14
EEPROM flags
EEPROM flags can be set with
$ eeprom-set-flags 0xFLAGS
Bit Description
0 Auto-boot (1=on)
1 Fan (1=present)
2 TPM (0=present)
3 Enclosure (1=present)
For example, to set your device to auto-boot, with TPM, and with fans, the flag value is 0x5, so
$ eeprom-set-flags 0x5
E3XX FPGA Register Map
AXI Slave Address Range UIO Label Description
Slave 0 4000_0000 - 4000_3fff - Ethernet DMA SFP (only for E320)
Slave 1 4000_4000 - 4000_4fff misc-enet-regs Ethernet registers SFP (only for E320)
Slave 2 4001_0000 - 4001_3fff mboard-regs Motherboard control
Slave 3 4001_4000 - 4001_41ff dboard-regs Daughterboard control
E3XX Register Map
AXI Slave Module Address Name Read/Write Description
Slave 0 axi_eth_dma 4000_0000 - 4000_4fff Ethernet DMA RW See Linux Driver (only on E320)
Slave 1 e320_mgt_io_core 4000_4000 PORT_INFO RO SFP port information
[31:24] COMPAT_NUM RO -
[23:18] 6'h0 RO -
[17] activity RO -
[16] link_up RO -
[15:8] mgt_protocol RO 0 - None, 1 - 1G, 2 - XG, 3 - Aurora
[7:0] PORTNUM RO -
e320_mgt_io_core 4000_4004 MAC_CTRL_STATUS RW Control 10gE and Aurora mac
[0] ctrl_tx_enable (PROTOCOL = "10GbE")RW-
[0] bist_checker_en (PROTOCOL = "Aurora")RW-
[1] bist_gen_en RW -
[2] bist_loopback_enRW -
[8:3] bist_gen_rate RW -
[9] phy_areset RW -
[10] mac_clear RW -
e320_mgt_io_core 4000_4008 PHY_CTRL_STATUS RW Phy reset control
e320_mgt_io_core 4000_400C MAC_LED_CTL RW Used by ethtool to indicate port
[1] identify_enable RW -
[0] identify_value RW -
mdio_master 4000_4010 MDIO_DATA RW -
4000_4014 MDIO_ADDR RW -
4000_4018 MDIO_OP RW -
4000_401C MDIO_CTRL_STATUSRW -
e320_mgt_io_core 4000_4020 AURORA_OVERUNS RO -
4000_4024 AURORA_CHECKSUM_ERRORSRO -
4000_4028 AURORA_BIST_CHECKER_SAMPSRO -
4000_402C AURORA_BIST_CHECKER_ERRORSRO-
eth_switch 4000_5000 MAC_LSB RW Device MAC LSB
4000_5004 MAC_MSB RW Device MAC MSB
4000_6000 IP RW Device IP
4000_6004 PORT1, PORT0 RW Device UDP port
eth_dispatch 4000_6008 [1] ndest, [0] bcastRW Enable Crossover
4000_600c [1] my_icmp_type, [0] my_icmp_code-
eth_switch 4000_6010 BRIDGE_MAC_LSB Bridge SFP ports in ARM
4000_6014 BRIDGE_MAC_MSB -
4000_6018 BRIDGE_IP -
4000_601c BRIDGE_PORT1, BRIDGE_PORT0-
4000_6020 BRIDGE_EN -
chdr_eth_framer 4000_6108 onwards LOCAL_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 256 SIDs
4000_6208 onwards LOCAL_DST_UDP_MAC_MSBW Destination MAC for outgoing packets (MSB)
4000_6308 onwards LOCAL_DST_MAC_LSBW Destination MAC for outgoing packets (LSB)
4000_7000 onwards REMOTE_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 16 local addrs
4000_7400 onwards REMOTE_DST_UDP_MAC_HIW Destination MAC (MSB)
4000_7800 onwards REMOTE_DST_MAC_LOW
Destination MAC (LSB)
Slave 2 e320_core 4001_0000 COMPAT_NUM R FPGA Compat Number
[31:16] Major RO -
[15:0] Minor RO -
4001_0004 DATESTAMP RO -
4001_0008 GIT_HASH RO -
4001_000C SCRATCH RO -
4001_0010 NUM_CE RO Number of Computation Engines (RFNoC Blocks)
4001_0014 NUM_IO_CE RO Number of fixed IO CEs - Radios + DMA Fifo
4001_0018 CLOCK_CTRL -
[0] pps select (internal 10 MHz)RWOne-hot encoded pps_select to use the internal PPS from GPSDO
[1] pps select (external 10 MHz)RWOne-hot encoded pps_select to use the external PPS.
[2] refclk_select (internal/external 10 MHz)RWrefclk_select=0 for internal (GPSDO) 10 MHz, refclk_sel=1 for external 10 MHz.
4001_001C XADC_READBACK RO -
[11:0] FPGA temperatureRO -
4001_0020 BUS_CLK_RATE RO -
4001_0024 BUS_CLK_COUNT RO -
4001_0028 SFP_PORT_INFO RO Same as port_info register 0x4000_4000
4001_002C FP_GPIO_CTRL RW -
4001_0030 FP_GPIO_MASTER RW -
4001_0034 FP_GPIO_RADIO_SRC RW -
4001_0038 GPS_CTRL RW -
[0] GPS_PWR_EN RW Power on GPSDO
[1] GPS_RST_N RW -
[2] GPS_INITSURV_N RW -
4001_003C GPS_STATUS RO GPSDO Status
[0] GPS_LOCK RO Returns 1 if GPSDO is locked
[1] GPS_ALARM RO -
[2] GPS_PHASELOCK RO -
[3] GPS_SURVEY RO -
[4] GPS_WARMUP RO -
4001_0040 DBOARD_CTRL RO -
4001_0044 DBOARD_STATUS RO
axi_crossbar 4001_1010 XBAR_VERSION RO See crossbar kernel driver
4001_1014 XBAR_NUM_PORTS RO See crossbar kernel driver
4001_1018 LOCAL_ADDR RW See crossbar kernel driver
4001_1020 remote_offset WO XBAR settings reg
4001_1420 local_offset WO
XBAR settings reg
Slave 4 4001_40004001_41FFDaughterboard Registers- Don't exist now. TBD
