USRP X3x0 Series
More information:
Comparative features list
  • Hardware Capabilities:
    • 2 transceiver card slots (can do 2x2 MIMO out of the box)
    • Dual SFP+ Transceivers (can be used with 1 GigE, 10 GigE)
    • PCI Express over cable (MXI) gen1 x4
    • External PPS input & output
    • External reference (10 MHz, 11.52 MHz, 23.04 MHz, or 30.72 MHz) input & output
    • Expandable via 2nd SFP+ interface
    • Supported master clock rates: 200 MHz and 184.32 MHz
    • Variable daughterboard clock rates
    • External USB Connection for built-in JTAG debugger
    • Internal GPSDO option
    • Kintex-7 FPGA (X310: XC7K410T, X300: XC7K325T)
  • FPGA Capabilities:
    • 2 RX DDC chains in FPGA
    • 2 TX DUC chain in FPGA
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • Up to 120 MHz of RF bandwidth with 16-bit samples
Getting started
This will run you through the first steps relevant to get your USRP X300/X310 up and running. Here, we assume you will connect your USRP using Gigabit Ethernet (1GigE), as this interface is readily available in most computers. For 10 Gigabit Ethernet (10GigE) or PCI Express (PCIe), see the corresponding sections in this manual page.
Assembling the X300/X310 kit
Before you can start using your USRP, you might have to assemble the hardware, if this has not yet happened. Make sure you are grounded (e.g. by touching a radiator) in order not to damage sensitive electronics through static discharge!
  1. Unscrew the top of your X300/X310 (there are 2 screws which can be easily loosened using a small Phillips screwdriver).
  2. Insert the daughterboards by inserting them into the slots and optionally screwing them onto the motherboard.
  3. Connect the RF connectors on the daughterboards to the front panel. In order to avoid confusion, make sure the internal connections match the labels on the front panel (i.e. TX/RX is connected to TX/RX).
  4. If you have purchased an internal GPSDO, follow the instructions on Internal GPSDO Application Notes (USRP-X3x0 Models) to insert the GPSDO. Note that you will need an external GPS antenna connected to the rear GPS ANT connector in order to make use of GPS, although your USRP will still be usable without.
  5. Connect the 1 GigE SFP+ transceiver into the Ethernet port 0 and connect the X300/X310 with your computer.
  6. Connect the power supply and switch on the USRP.
Network Connectivity
The next step is to make sure your computer can talk to the USRP. An otherwise unconfigured USRP device will have the IP address 192.168.10.2 when using 1GigE. It is recommended to directly connect your USRP to the computer at first, and to set the IP address on your machine to 192.168.10.1. See Setup the host interface on details how to change your machine's IP address.
Note: If you are running an automatic IP configuration service such as Network Manager, make sure it is either deactivated or configured to not change the network device! This can, in extreme cases, lead to you bricking the USRP!
If your network configuration is correct, running uhd_find_devices will find your USRP and print some information about it. You will also be able to ping the USRP by running:
ping 192.168.10.2
on the command line. At this point, you should also run:
uhd_usrp_probe --args addr=192.168.10.2
to make sure all of your components (daughterboards, GPSDO) are correctly detected and usable.
Updating the FPGA
If the output from uhd_find_devices and uhd_usrp_probe didn't show any warnings, you can skip this step. However, if there were errors regarding the FPGA version compatibility number, you will have to update the FPGA image before you can start using your USRP.
  1. Download the current UHD images. You can use the uhd_images_downloader script provided with UHD (see also Firmware and FPGA Images).
  2. Use the uhd_image_loader utility to update the FPGA image. On the command line, run:
       uhd_image_loader --args="type=x300,addr=192.168.10.2,fpga=HG"
    If you have installed the images to a non-standard location, you might need to run (change the filename according to your device):
        uhd_image_loader --args="type=x300,addr=192.168.10.2" --fpga-path="<path_to_images>/usrp_x310_fpga_HG.bit"
    The process of updating the FPGA image will take several minutes. Make sure the process of flashing the image does not get interrupted.
See Load the Images onto the On-board Flash for more details.
When your FPGA is up to date, power-cycle the device and re-run uhd_usrp_probe. There should be no more warnings at this point, and all components should be correctly detected. Your USRP is now ready for development!
Hardware Setup
Gigabit Ethernet (1 GigE)
  • Prior to installing the module, the host PC can remain powered on.
  • Plug a 1 Gigabit SFP Transceiver into Ethernet Port 0 on the USRP X300/X310 device.
  • Use the Ethernet cable to connect the SFP+ transceiver on the device to the host computer. For maximum throughput, Ettus Research recommends that you connect each device to its own dedicated Gigabit Ethernet interface on the host computer.
  • Connect the AC/DC power supply to the device and plug the supply into a wall outlet.
  • The OS will automatically recognize the device (e.g. when running uhd_find_devices).
Ten Gigabit Ethernet (10 GigE)
Installing the Host Ethernet Interface
Ettus Research recommends the Intel Ethernet Converged Network Adapter X520-DA2 interface for communication with the USRP X300/X310 device. Installation instructions for this interface are available on the official Intel website.
Installing the USRP X300/X310
  • Use a 10 Gigabit SFP+ cable to connect Ethernet Port 1 on the USRP X300/X310 device to the host computer. For maximum throughput, Ettus Research recommends that you connect the device to its own dedicated Ten Gigabit, Ettus Research recommended Ethernet interface on the host computer.
The LEDs on the front panel can be useful in debugging hardware and software issues (see Front Panel)
Dual 10 Gigabit Ethernet
The benchmark_rate tool can be used to test this capability. Run the following commands to test the X-series USRP over both 10 Gigabit Ethernet interfaces with the maximum rate of 200 Msps per channel:
cd <install-path>/lib/uhd/examples
./benchmark_rate --args="type=x300,addr=<Primary IP>,second_addr=<secondary IP>" --channels="0,1" --rx_rate 200e6
DPDK Support
To enable the highest streaming rates over the network, X310 supports using transports based on the Data Plane Development Kit (DPDK). See the DPDK page for details on how it can improve streaming and how to use it.
PCI Express (Desktop)
Important Note: The USRP X-Series provides PCIe connectivity over MXI cable. We will use the 'MXI' nomenclature for the rest of this manual.
Installing the PCIe Kernel Drivers
In order to use the USRP X-Series on a PCIe-over-MXI connection, you need to install the NI RIO drivers on your system. Please follow the instructions here: NI RIO Kernel Modules for X-Series PCIe Connectivity
Installing the PCI Express Interface Kit
Follow the instructions listed in the Set Up Your MXI-Express x4 System document to setup the NI PCIe-8371 module.
  • Prior to installing the module, make sure that the PC is powered off.
  • Using a MXI-Express Cable connect the USRP X300/X310 to the NI PCIe-8371.
  • Power on the USRP X300/X310 device using the power switch located in the bottom-right corner of the front panel.
  • Power on the PC (The OS automatically recognizes the new device)
Note: The USRP device is not hot-pluggable over PCI Express. Any connection changes with only be detected by your computer after a successful reboot.
Troubleshooting
Two possible failure modes are your computer not booting when connected to your USRP device through MXI-Express, and Windows not properly discovering your devices (for example, there is a yellow exclamation point on a PCI to PCI bridge in Windows Device Manager, despite drivers for all devices being installed). These situations often are due to programming errors in PCI Express device configuration of the BIOS. To use this software, you need a MXI-Express device that supports Mode 1 operation. Refer to NI MXI-Express BIOS Compatibility Software Readme for more information.
The BIOS Compatibility Software can be downloaded for Windows from the MXI-Express BIOS Compatibility Software page.
PCI Express (Laptop)
Important Note: The USRP X-Series provides PCIe connectivity over MXI cable We will use the 'MXI' nomenclature for the rest of this manual.
Installing the PCI Express Card
Follow the instructions listed in the “Installing an NI ExpressCard-8360 Host Card” section of the Set Up Your MXI-Express x1 System document to setup the NI ExpressCard-8360B module.
Because a laptop computer is not grounded, follow this procedure to safely connect a laptop computer to your USRP device.
  • Connect the AC/DC power supply to the device and plug the supply into a wall outlet. Ensure that the USRP device is powered off.
  • Touch the NI ExpressCard-8360B and a metal part of the USRP device simultaneously. Do not install the NI ExpressCard-8360B into the laptop computer yet.
  • Connect the cable to the NI ExpressCard-8360B and USRP.
  • Plug the NI ExpressCard-8360B into an available ExpressCard slot. If your laptop computer is already running (or hibernating, suspended, etc.) when you install an NI ExpressCard-8360B, you must reboot to detect the USRP. Otherwise, the USRP is detected when you start your computer.
Note: The USRP device is not hot-pluggable over PCI Express. Any connection changes will only be detected by your computer after a successful reboot.
On-Board JTAG Programmer
The USRP X3x0 includes an on-board JTAG programmer, built into the motherboard. To connect to this JTAG device, simply connect your computer to the USB JTAG port on the front of the X3x0 device. You may now use the JTAG programmer in the same way you would use any other, including:
In order to use the JTAG programmer with the Xilinx tools, the Digilent drivers and plugin have to be installed first. Although recent versions of Vivado ship with the driver, it has to still be manually installed.
To install first locate your Vivado installation path on a Linux system (default is /opt/Xilinx/Vivado/<Version>):
sudo `find /opt/Xilinx/Vivado/<Version> -name install_digilent.sh`
The USRP-X series device should now be usable with all the tools mentioned above.
Load FPGA Images onto the Device
The USRP-X Series device ships with a bitstream pre-programmed in the flash, which is automatically loaded onto the FPGA during device power-up. However, a new FPGA image can be configured over the PCI Express interface or the on-board USB-JTAG programmer. This process can be seen as a "one-time load", in that if you power-cycle the device, it will not retain the FPGA image.
Please note that this process is different than replacing the FPGA image stored in the flash, which will then be automatically loaded the next time the device is reset.
FPGA Image Flavors
The USRP-X Series devices contains two SFP+ ports for the two Ethernet channels. Because the SFP+ ports support both 1 Gigabit (SFP) and 10 Gigabit (SFP+) transceivers, several FPGA images are shipped with UHD to determine the behavior of the above interfaces.
 FPGA Image Flavor   SFP+ Port 0 Interface  SFP+ Port 1 Interface
 HG (Default)    1 Gigabit Ethernet  10 Gigabit Ethernet
 XG    10 Gigabit Ethernet  10 Gigabit Ethernet
 HA    1 Gigabit Ethernet  Aurora
 XA    10 Gigabit Ethernet  Aurora
Note: The Aurora images need to be built manually from the FPGA source code.
FPGA images are shipped in 2 formats:
  • LVBITX: LabVIEW FPGA configuration bitstream format (for use over PCI Express and Ethernet)
  • BIT: Xilinx configuration bitstream format (for use over Ethernet and JTAG)
To get the latest images, simply use the uhd_images_downloader script. On Unix systems, use this command:
$ [sudo] uhd_images_downloader
On Windows, use:
<path_to_python.exe> <install-path>/bin/uhd_images_downloader.py
Use PCI Express to load FPGA images
UHD requires a valid LabVIEW FPGA configuration bitstream file (LVBITX) to use the USRP-X Series device over the PCI Express bus. LabVIEW FPGA is not required to use UHD with a USRP-X Series device. Because FPGA configuration is a part of normal operation over PCI Express, there is no setup required before running UHD.
The fpga tag can be set in the optional device args passed to indicate the FPGA image flavor to UHD. If the above tag is specified, UHD will attempt to load the FPGA image with the requested flavor from the UHD images directory. If the tag is not specified, UHD will automatically detect the flavor of the image and attempt to load the corresponding configuration bitstream onto the device. Note that if UHD detects that the requested image is already loaded onto the FPGA then it will not reload it.
Use JTAG to load FPGA images
The USRP-X Series device features an on-board USB-JTAG programmer that can be accessed on the front-panel of the device. There are multiple tools available to access the FPGA through the JTAG connector (see On-Board JTAG Programmer).
If you have Vivado installed, we provide a command-line script to flash images. Make sure your X3x0 is powered on and connected to your computer using the front panel USB JTAG connector (USB 2.0 is fine for this). Head to the X3x0 FPGA directory, then run the following commands:
$ cd uhd/fpga-src/usrp3/top/x300 # Assuming this is where the FPGA code is checked out
$ source ./setupenv.sh
$ viv_jtag_program /path/to/bitfile.bit
If you have iMPACT installed, you can use the impact_jtag_programmer.sh tool to install images. Then run the tool:
To change the FPGA image stored in the on-board flash, the USRP-X Series device can be reprogrammed over the network or PCI Express. Once you have programmed an image into the flash, that image will be automatically loaded on the FPGA during the device boot-up sequence.
Note: Different hardware revisions require different FPGA images. Determine the revision number from the sticker on the rear of the device. If you are manually specifying an FPGA path, the utility will not try to detect your device information, and you will need to use this number to select which image to burn.
Note: The image loader utility will default to using the appropriate BIT file if no custom FPGA image path is specified, but it is compatible with BIN, BIT, and LVBITX images.
Use the image loader over Ethernet
Automatic FPGA path, detect image type:
uhd_image_loader --args="type=x300,addr=<IP address>"
Automatic FPGA path, select image type:
uhd_image_loader --args="type=x300,addr=<IP address>,fpga=<HG or XG>"
Manual FPGA path:
uhd_image_loader --args="type=x300,addr=<IP address>" --fpga-path="<path to FPGA image>"
Use the image loader over PCI Express
uhd_image_loader --args="type=x300,resource=<NI-RIO resource>"
uhd_image_loader --args="type=x300,resource=<NI-RIO resource>,fpga=<HG or XG>"
Manual FPGA path:
uhd_image_loader --args="type=x300,resource=<NI-RIO resource>" --fpga-path="<path to FPGA image>"
Device recovery and bricking
It is possible to put the device into an unusable state by loading bad images ("bricking"). Fortunately, the USRP-X Series device can be loaded with a good image temporarily using the USB-JTAG interface. Once booted into the safe image, the user can once again load images onto the device over Ethernet or PCI Express.
See Section Use JTAG to load FPGA images on how to load the FPGA image onto the device using a JTAG interface. After running the JTAG process, a new image can be flashed onto the device using the usual procedure to permently recover the device.
Setup Networking
The USRP-X Series only supports Gigabit and Ten Gigabit Ethernet and will not work with a 10/100 Mbps interface.
Please note that 10 Gigabit Ethernet defines the protocol, not necessary the medium. For example, you may use 10GigE over optical with optical SFP+ transceiver modules.
The USRP-X Series communicates at the IP/UDP layer over the Gigabit and Ten Gigabit Ethernet. The default IP address for the USRP X300/X310 device depends on the Ethernet Port and interface used. You must configure the host Ethernet interface with a static IP address on the same subnet as the connected device to enable communication, as shown in the following table:
 Ethernet Interface USRP Ethernet Port  Default USRP IP Address  Host Static IP Address Host Static Subnet Mask Address EEPROM key
 Gigabit   Port 0 (HG Image)  192.168.10.2 192.168.10.1 255.255.255.0 ip-addr0
 Ten Gigabit   Port 0 (XG Image)  192.168.30.2 192.168.30.1 255.255.255.0 ip-addr2
 Ten Gigabit   Port 1 (HG/XG Image)  192.168.40.2 192.168.40.1 255.255.255.0 ip-addr3
As you can see, the X300/X310 actually stores different IP addresses, which all address the device differently: Each combination of Ethernet port and interface type (i.e., Gigabit or Ten Gigabit) has its own IP address. As an example, when addressing the device through 1 Gigabit Ethernet on its first port (Port 0), the relevant IP address is the one stored in the EEPROM with key ip-addr0, or 192.168.10.2 by default.
See Configuring the host's IP address on details how to change your machine's IP address and MTU size to work well with the X300.
Multiple devices per host
For maximum throughput, one Ethernet interface per USRP is recommended, although multiple devices may be connected via an Ethernet switch. In any case, each Ethernet interface should have its own subnet, and the corresponding USRP device should be assigned an address in that subnet. Example:
Configuration for USRP-X Series device 0:
  • USRP-X Series device IPv4 address: 192.168.10.2
Configuration for USRP-X Series device 1:
  • Ethernet interface IPv4 address: 192.168.110.1
  • USRP-X Series device IPv4 address: 192.168.110.2
If all devices are to be used in a compound, see also Multiple USRP configurations.
Change the USRP's IP address
  • to use multiple USRP-X Series devices on the same host computer
  • to set a known IP address into USRP (in case you forgot)
To change the USRP's IP address, you must know the current address of the USRP, and the network must be setup properly as described above. You must also know which IP address of the X300 you want to change, as identified by their address EEPROM key (e.g. ip-addr0, see the table above). Run the following commands:
UNIX:
./usrp_burn_mb_eeprom --args=<optional device args> --values="ip-addr0=192.168.10.3"
Windows:
cd <install-path>\lib\uhd\utils
usrp_burn_mb_eeprom.exe --args=<optional device args> --values="ip-addr0=192.168.10.3"
You must power-cycle the device before you can use this new address.
Setup Clocking
Motherboard clock
The X300 series generates a master clock on the motherboard, which is then used to drive the ADCs, DACs, and the radio blocks. This clock rate is referred to as the "master clock rate". There is always a single master clock rate per motherboard. This rate is also the base sample rate of the radio blocks. By using DDC and DUC blocks (these are part of the default X300/X310 FPGA image), the actual sampling rate available to your application can be an integer divisor of the master clock rate, so for a 200 MHz master clock rate, the sampling rate available to the application can be 200 Msps, 100 Msps, 66.6 Msps, 50 Msps, and so on.
The X300 series support a 200 MHz and a 184.32 MHz master clock rate, with 200 MHz being the default. To specify a master clock rate, use the master_clock_rate device arg at initialization time. Example:
auto usrp = uhd::usrp::multi_usrp::make("type=x300,master_clock_rate=184.32e6");
usrp->set_rx_rate(30e6); // This will coerce to the next possible value
// The next possible value is 30.72e6, which is 184.32e6 / 6
std::cout << usrp->get_rx_rate() << std::endl; // Prints 30.72e6
Note: The X300 series does not support the uhd::usrp::multi_usrp::set_master_clock_rate() API call, because it can only configure the clock at initialization time, but not afterwards. To switch the master clock rate, destroy your USRP object, and recreate a new one. Example:
// 1. Create USRP object with 184.32 MHz master clock rate
// 2. Destroy the reference
usrp.reset();
// 3. Recreate the object with a 200 MHz master clock rate
usrp = uhd::usrp::multi_usrp::make("type=x300,master_clock_rate=200e6");
Due to the contract of uhd::usrp::multi_usrp::set_master_clock_rate(), the call will not throw an exception, but will coerce to the previously set master clock rate. Effectively, it will do nothing but print a warning (but it won't terminate your application). Also note that the return value of said API call as well as the associated getter will always return accurate values. Example:
auto usrp = uhd::usrp::multi_usrp::make("type=x300,master_clock_rate=200e6");
double desired_rate = 184.32e6;
// This call does nothing:
usrp->set_master_clock_rate(desired_rate);
// At this point, desired_rate does not actually store the correct rate!
// This prints the correct rate:
std::cout << usrp->get_master_clock_rate() << std::endl; // Prints 200e6
Daughterboard clock
The X3x0 provides a clock signal to the daughterboards which is used as a reference clock for synthesizers and other components that require clocks. There are daughterboards that require non-default clock values. See Section Device Configuration through address string on how to change the clock value, and Daughterboards for information specific to certain daughterboards.
Not all combinations of daughterboards work within the same device, if daughterboard clock requirements conflict. Note that some daughterboards will try and set the daughterboard clock rate themselves. Refer to the Ettus Research Knowledge Base article on the X300/X310 for more information on daughterboard compatibilty.
Addressing the Device
Single device configuration
In a single-device configuration, the USRP device must have a unique IPv4 address on the host computer. The USRP can be identified through its IPv4 address, resolvable hostname, NI-RIO resource name or by other means. See the application notes on Device Identification. Use this addressing scheme with the uhd::usrp::multi_usrp interface (not a typo!).
Example device address string representation for a USRP-X Series device with IPv4 address 192.168.10.2:
addr=192.168.10.2
Example device address string representation for a USRP-X Series device with RIO resource name RIO0 over PCI Express:
resource=RIO0
Multiple device configuration
See also Multiple USRP configurations.
Troubleshooting
Communication Issues
Firewall Issues
Ping the device
ping 192.168.10.2
Device not enumerated over PCI-Express (Linux)
UHD requires the RIO device manager service to be running in order to communicate with an X-Series USRP over PCIe. This service is installed as a part of the USRP RIO (or NI-USRP) installer. On Linux, the service is not started at system boot time, and is left to the user to control. To start it, run the following command:
sudo niusrprio_pcie start
If the device still does not enumerate after starting the device manager, make sure that the host computer has successfully detected it. You can do so by running the following command:
lspci -k -d 1093:c4c4
A device similar to the following should be detected:
$ lspci -k -d 1093:c4c4
04:00.0 Signal processing controller: National Instruments ...
       Subsystem: National Instruments Device 76ca
       Kernel driver in use: niusrpriok_shipped
  • All USRP X-Series devices should appear with 'Subsystem: National Instruments Device'
  • The device ID following can be:
    • USRP X300: 7736 or 7861
    • USRP X310: 76CA or 7862
    • NI-USRP 294xR: 772B, 77FB, 772C, 77FC, 772D, 77FD, 772E, 7853, 785B, 7854, 785C, 7855, 785D or 7856
    • NI-USRP 295xR: 772F, 77FE, 7730, 77FF, 7731, 7800, 7732, 7857, 785E, 7858, 785F, 7859, 7860 or 785A
Device not enumerated over PCI-Express (Windows)
UHD requires the RIO device manager service to be running in order to communicate with an X-Series USRP over PCIe. This service is installed as a part of the USRP RIO (or NI-USRP) installer. On Windows, it can be found in the Services section in the Control Panel and it is started at system boot time. To ensure that the service is indeed started, navigate to the Services tag in the Windows Task Manager and ensure that the status of niusrpriorpc is "Running".
If the device still does not enumerate after starting the device manager, make sure that the host computer has successfully detected it. You can do so by checking if your device shows up in the Windows Device Manager.
Observe Ethernet port LEDs
Corrupt EEPROM
This is a rare bug in which the X-Series device's on-board EEPROM becomes corrupt and reports an incorrect firmware and FPGA version. In this situation, UHD cannot properly use the device. To fix this bug, use the usrp_burn_mb_eeprom utility as follows:
usrp_burn_mb_eeprom --args="type=x300,recover_mb_eeprom,disable_adc_self_test" --values="revision=(NUM HERE)"
Afterward, power-cycle your X-Series device for the changes to take effect.
Hardware Notes
Front Panel
X3x0
  • JTAG: USB connector for the on-board USB-JTAG programmer
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on daughterboard A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on daughterboard A
  • REF: Indicates that the external Reference Clock is locked
  • PPS: Indicates a valid PPS signal by pulsing once per second
  • AUX I/O: Front panel GPIO connector.
  • GPS: Indicates that GPS reference is locked
  • LINK: Indicates that the host computer is communicating with the device (Activity)
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on daughterboard B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on daughterboard B
  • PWR: Power switch
Rear Panel
X3x0 Rear Panel
  • PWR: Connector for the USRP-X Series power supply
  • 1G/10G ETH: SFP+ ports for Ethernet interfaces
  • REF OUT: Output port for the exported reference clock
  • PCIe x4: Connector for Cabled PCI Express link
  • PPS/TRIG OUT: Output port for the PPS signal
Ref Clock (10 MHz or other frequency)
Using an external 10 MHz reference clock, a square wave will offer the best phase noise performance, but a sinusoid is acceptable. The power level of the reference clock must exceed +15 dBm.
The following reference frequencies are supported:
  • 10 MHz
  • 11.52 MHz
  • 23.04 MHz
  • 30.72 MHz
If the external reference clock is not 10 MHz, the system_ref_rate device arg must be provided.
To use the external reference in your UHD session, make sure to either call uhd::usrp::multi_usrp::set_clock_source() or specify clock_source=external in your device args.
PPS - Pulse Per Second
Using a PPS signal for timestamp synchronization requires a square wave signal with a 5Vpp amplitude.
To use the external time source in your UHD session, make sure to either call uhd::usrp::multi_usrp::set_time_source() or specify time_source=external in your device args.
Internal GPSDO
Please see Internal GPSDO Application Notes (USRP-X3x0 Models) for information on configuring and using the internal GPSDO.
Front Panel GPIO
Connector
X3x0 GPIO Connector
Pin Mapping
  • Pin 1: +3.3V
  • Pin 2: Data[0]
  • Pin 3: Data[1]
  • Pin 4: Data[2]
  • Pin 5: Data[3]
  • Pin 6: Data[4]
  • Pin 7: Data[5]
  • Pin 8: Data[6]
  • Pin 9: Data[7]
  • Pin 10: Data[8]
  • Pin 11: Data[9]
  • Pin 12: Data[10]
  • Pin 13: Data[11]
  • Pin 14: 0V
  • Pin 15: 0V
On-Board LEDs
LED Description
DS1 1.2V power
DS2 TXRX1 Red: TX, Green: RX
DS3 RX1 Green: RX
DS4 REF reference lock
DS5 PPS flashes on edge
DS6 GPS GPS lock
DS7 SFP0 link
DS8 SFP0 link activity
DS10 TXRX2 Red: TX Green: RX
DS11 RX2 Green: RX
DS12 6V daughterboard power
DS13 3.8V power
DS14 3.3V management power
DS15 3.3V auxiliary management power
DS16 1.8V FPGA power
DS16 3.3V FPGA power
DS19 SFP1 link
DS20 SFP1 link active
DS21 LINK link activity
Xilinx chipscope allows for debugging custom FPGA designs similar to a logic analyzer. USRP-X series devices can be used with Xilinx chipscope using the onboard USB JTAG connector.
Miscellaneous
Configuring the device in an application
During runtime, the device can be configured in several different ways.
The following pages may shed some light:
Multiple RX channels
There are two complete DDC and DUC DSP chains in the FPGA. In the single channel case, only one chain is ever used. To receive from both channels, the user must set the RX or TX subdevice specification.
In the following example, a TVRX2 is installed. Channel 0 is sourced from subdevice RX1, and channel 1 is sourced from subdevice RX2 (RX1 and RX2 are antenna connectors on the TVRX2 daughterboard).
Available Sensors
The following sensors are available for the USRP-X Series motherboards; they can be queried through the API.
  • Other sensors are added when the GPSDO is enabled
