build_info.hpp
2 // Copyright 2015 National Instruments Corp.
5 //
6
7 #pragma once
8
9 #include <uhd/config.hpp>
10 #include <string>
11
12 namespace uhd { namespace build_info {
13
15 UHD_API const std::string boost_version();
16
18 UHD_API const std::string build_date();
19
21 UHD_API const std::string c_compiler();
22
24 UHD_API const std::string cxx_compiler();
25
27 UHD_API const std::string c_flags();
28
30 UHD_API const std::string cxx_flags();
31
33 UHD_API const std::string enabled_components();
34
36 UHD_API const std::string install_prefix();
37
39 UHD_API const std::string libusb_version();
40
42 UHD_API const std::string dpdk_version();
43
45 UHD_API const std::string pkg_data_dir();
46 }} // namespace uhd::build_info
Definition: config.h:87
Return the default CMake install prefix for this build.
Return the version of Boost this build was built with.
Return the C++ flags passed into this build.
Return the C compiler used for this build.
Return the date and time (GMT) this UHD build was built.
Return the value of PKG_DATA_DIR at build time (e.g., "share/uhd").
Return the C++ compiler used for this build.
Return the version of DPDK this build was built with.
Return the UHD components enabled for this build, comma-delimited.
Return the C flags passed into this build.
Return the version of libusb this build was built with.
Definition: build_info.hpp:12
