byte_vector.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <boost/range.hpp>
12 #include <algorithm>
13 #include <cstddef>
14 #include <cstdint>
15 #include <string>
16 #include <vector>
18 namespace uhd {
19
21 typedef std::vector<uint8_t> byte_vector_t;
22
23 template <typename RangeSrc, typename RangeDst>
24 UHD_INLINE void byte_copy(const RangeSrc& src, RangeDst& dst)
25 {
26  std::copy(boost::begin(src), boost::end(src), boost::begin(dst));
27 }
28
30 UHD_API std::string bytes_to_string(const byte_vector_t& bytes);
31
33 UHD_API byte_vector_t string_to_bytes(const std::string& str, size_t max_length);
34
35 } // namespace uhd
#define UHD_INLINE
Definition: config.h:65
Definition: config.h:87
Definition: build_info.hpp:12
Definition: byte_vector.hpp:21
UHD_API byte_vector_t string_to_bytes(const std::string &str, size_t max_length)
Definition: byte_vector.hpp:24
UHD_API std::string bytes_to_string(const byte_vector_t &bytes)
