uhd::experts::expert_factory Class Reference
#include <uhd/experts/expert_factory.hpp>
Inheritance diagram for uhd::experts::expert_factory:
expert_factory is a friend of expert_container and handles all operations to create and change the structure of the an expert container. The expert_factory allocates storage for the nodes in the expert_container and passes allocated objects to the container using private APIs. The expert_container instance owns all data and workernodes and is responsible for releasing their storage on destruction.
static expert_container::sptr create_container (const std::string &name)
template<typename data_t >
static void add_data_node (expert_container::sptr container, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
static property< data_t > & add_prop_node (expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
static property< data_t > & add_prop_node (expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
static property< data_t > & add_dual_prop_node (expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const std::string &desired_name, const std::string &coerced_name, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
static property< data_t > & add_dual_prop_node (expert_container::sptr container, property_tree::sptr subtree, const fs_path &path, const data_t &init_val, const auto_resolve_mode_t mode=AUTO_RESOLVE_OFF)
template<typename worker_t >
static void add_worker_node (expert_container::sptr container)
template<typename worker_t , typename... Args>
static void add_worker_node (expert_container::sptr container, Args const &... args)
◆ add_data_node()
static void uhd::experts::expert_factory::add_data_node ( expert_container::sptr  container,
const std::string &  name,
const data_t &  init_val,
const auto_resolve_mode_t  mode = AUTO_RESOLVE_OFF
inlinestatic
Add a data node to the expert graph.
containerA shared pointer to the container to add the node to
nameThe name of the data node
init_valThe initial value of the data node
modeThe auto resolve mode
Requirements for data_t
  • Must have a default constructor
  • Must have a copy constructor
  • Must have an assignment operator (=)
  • Must have an equality operator (==)
◆ add_dual_prop_node() [1/2]
static property<data_t>& uhd::experts::expert_factory::add_dual_prop_node ( expert_container::sptr  container,
const fs_path &  path,
inlinestatic
Add a dual expert property to a property tree AND an expert graph. A dual property is a desired and coerced value pair The property is registered with path/desired as the desired node name and path/coerced as the coerced node name
containerA shared pointer to the expert container to add the node to
subtreeA shared pointer to subtree to add the property to
pathThe path of the property in the subtree
init_valThe initial value of both the data nodes
◆ add_dual_prop_node() [2/2]
const std::string &  desired_name,
const std::string &  coerced_name,
inlinestatic
desired_nameThe name of the desired data node in the expert graph
coerced_nameThe name of the coerced data node in the expert graph
◆ add_prop_node() [1/2]
static property<data_t>& uhd::experts::expert_factory::add_prop_node ( expert_container::sptr  container,
inlinestatic
Add a expert property to a property tree AND an expert graph. The property is registered with the path as the identifier for both the property subtree and the expert container
◆ add_prop_node() [2/2]
inlinestatic
The underlying property can be used like any other property tree property, including setting a coercer through set_coercer(). However, this means that the coercion is happening outside of the expert framework. This is primarily useful for tiny coercions (e.g., we accept both upper and lower case values, but only want lower case downstream) for which we don't want to bother with a full expert, or for which we don't want to trigger resolution at all (if mode is set to AUTO_RESOLVE_OFF). For more full-fledged coercion, prefer add_dual_prop_node(). This will properly engage the expert graph.
nameThe name of the data node in the expert graph
◆ add_worker_node() [1/2]
static void uhd::experts::expert_factory::add_worker_node ( expert_container::sptr  container)
inlinestatic
Add a worker node to the expert graph. The expert_container owns and manages storage for the worker
Template Parameters
worker_tData type of the worker class
◆ add_worker_node() [2/2]
static void uhd::experts::expert_factory::add_worker_node ( expert_container::sptr  container,
inlinestatic
Template Parameters
arg1_tData type of the first argument to the constructor
argN_tData type of the Nth argument to the constructor
argsarguments to the ctor
◆ create_container()
static expert_container::sptr uhd::experts::expert_factory::create_container ( const std::string &  name)
Creates an empty instance of expert_container with the specified name.
nameName of the container
