uhd::features::complex_gain_iface< trx > Class Template Referenceabstract
#include <uhd/features/complex_gain_iface.hpp>
Inheritance diagram for uhd::features::complex_gain_iface< trx >:
uhd::features::discoverable_feature
using sptr = std::shared_ptr< complex_gain_iface >
- Public Types inherited from uhd::features::discoverable_feature
enum  feature_id_t {
  RESERVED0 , RESERVED1 , FPGA_LOAD_NOTIFICATION , ADC_SELF_CALIBRATION ,
  REF_CLK_CALIBRATION , TRIG_IO_MODE , GPIO_POWER , SPI_GETTER_IFACE ,
  INTERNAL_SYNC , GPS , TX_COMPLEX_GAIN , RX_COMPLEX_GAIN
using sptr = std::shared_ptr< discoverable_feature >
std::string get_feature_name () const
 Returns a human-readable string name of this feature. More...
virtual ~complex_gain_iface ()=default
virtual void set_gain_coeff (const std::complex< double > gain_coeff, const size_t chan, const std::optional< uhd::time_spec_t > time={})=0
virtual std::complex< double > get_gain_coeff (const size_t chan)=0
- Public Member Functions inherited from uhd::features::discoverable_feature
virtual ~discoverable_feature ()=default
static discoverable_feature::feature_id_t get_feature_id ()
template<uhd::direction_t trx>
using uhd::features::complex_gain_iface< trx >::sptr = std::shared_ptr<complex_gain_iface>
◆ ~complex_gain_iface()
virtual uhd::features::complex_gain_iface< trx >::~complex_gain_iface ( )
virtualdefault
◆ get_feature_id()
static discoverable_feature::feature_id_t uhd::features::complex_gain_iface< trx >::get_feature_id ( )
inlinestatic
◆ get_feature_name()
std::string uhd::features::complex_gain_iface< trx >::get_feature_name ( ) const
Implements uhd::features::discoverable_feature.
◆ get_gain_coeff()
virtual std::complex<double> uhd::features::complex_gain_iface< trx >::get_gain_coeff ( const size_t  chan)
Returns the currently active complex gain coefficient
◆ set_gain_coeff()
virtual void uhd::features::complex_gain_iface< trx >::set_gain_coeff ( const std::complex< double >  gain_coeff,
const size_t  chan,
const std::optional< uhd::time_spec_t >  time = {}
Apply complex gain at a specified time
The specified complex gain coefficient will be applied at a given timestamp. The default gain coefficient is 1.0 + 0.0i (unity gain). Alternatively, if the user sets the command time for the noc block, the timestamp is the current command time. If the timestamp has already passed or no time is specified, the gain will be applied as soon as possible.
Note: This timed function takes the timestamp as an argument and does not honor the timestamp which was set by 'set_command_time()'.
Note to check if the complex gain feature is enabled in the device bitfile. When the coefficient is queued, it will be immediately acknowledged by the USRP. However, if the queue is full, the acknowledgment will be delayed until it can be queued.
gain_coeff The complex gain coefficient to apply (1.0 is unity) chan The channel index time Optional timestamp to specify when to apply the gain
