uhd::rfnoc::fosphor_block_control Member List
This is the complete list of members for uhd::rfnoc::fosphor_block_control, including all inherited members.
action_mode_t enum nameuhd::rfnoc::node_t
clear_history()=0uhd::rfnoc::fosphor_block_controlpure virtual
get_enable_dither() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_enable_histogram() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_enable_noise() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_enable_waterfall() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_histogram_decay_rate() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_histogram_decimation() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_histogram_offset() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_histogram_rise_rate() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_histogram_scale() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_spectrum_alpha() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_spectrum_max_hold_decay() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_waterfall_decimation() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_waterfall_mode() const =0uhd::rfnoc::fosphor_block_controlpure virtual
get_waterfall_predivision() const =0uhd::rfnoc::fosphor_block_controlpure virtual
node_t()uhd::rfnoc::node_t
post_action(const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)uhd::rfnoc::node_tprotected
post_action_handler_t typedefuhd::rfnoc::node_t
REG_ALPHA_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_CLEAR_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_DECIM_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_ENABLE_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_EPSILON_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_OFFSET_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_RANDOM_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_SCALE_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_TDECAY_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_TRISE_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_WF_CTRL_ADDRuhd::rfnoc::fosphor_block_controlstatic
REG_WF_DECIM_ADDRuhd::rfnoc::fosphor_block_controlstatic
set_enable_dither(const bool enable_dither)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_enable_histogram(const bool enable_histogram)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_enable_noise(const bool enable_noise)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_enable_waterfall(const bool enable_waterfall)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_histogram_decay_rate(const uint16_t decay_rate)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_histogram_decimation(const uint16_t decimation)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_histogram_offset(const uint16_t offset)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_histogram_rise_rate(const uint16_t rise_rate)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_histogram_scale(const uint16_t scale)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_spectrum_alpha(const uint16_t alpha)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_spectrum_max_hold_decay(const uint16_t epsilon)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_waterfall_decimation(const uint16_t waterfall_decimation)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_waterfall_mode(const fosphor_waterfall_mode waterfall_mode)=0uhd::rfnoc::fosphor_block_controlpure virtual
set_waterfall_predivision(const fosphor_waterfall_predivision_ratio waterfall_predivision)=0uhd::rfnoc::fosphor_block_controlpure virtual
