uhd::rfnoc::node_t Class Referenceabstract
#include <uhd/rfnoc/node.hpp>
Inheritance diagram for uhd::rfnoc::node_t:
uhd::rfnoc::noc_block_base uhd::rfnoc::test::mock_ddc_node_t uhd::rfnoc::test::mock_edge_node_t uhd::rfnoc::test::mock_fifo_t uhd::rfnoc::test::mock_radio_node_t uhd::rfnoc::test::mock_routing_node_t uhd::rfnoc::test::mock_streamer_t uhd::rfnoc::test::mock_terminator_t
The base class for all nodes within an RFNoC graph
The block supports the following types of data access:
  • High-level property access
  • Action execution
enum class  action_mode_t { SYNC , ASYNC }
 Action execution modes. More...
using post_action_handler_t = std::function< void(const res_source_info &, action_info::sptr, action_mode_t)>
 Return a unique identifier string for this node. More...
 Return the number of input ports for this block. More...
 Return the number of output ports for this block. More...
Protected Types
void post_action (const res_source_info &edge_info, action_info::sptr action, action_mode_t mode=action_mode_t::SYNC)
Static Protected Attributes
Friends
class node_accessor_t
◆ action_handler_t
◆ forwarding_map_t
using uhd::rfnoc::node_t::forwarding_map_t = std::unordered_map<res_source_info, std::vector<res_source_info> >
◆ graph_mutex_callback_t
using uhd::rfnoc::node_t::graph_mutex_callback_t = std::function<std::recursive_mutex&(void)>
◆ post_action_handler_t
◆ prop_ptrs_t
using uhd::rfnoc::node_t::prop_ptrs_t = std::vector<property_base_t*>
◆ resolve_callback_t
using uhd::rfnoc::node_t::resolve_callback_t = std::function<void(void)>
◆ resolver_fn_t
using uhd::rfnoc::node_t::resolver_fn_t = std::function<void(void)>
◆ action_mode_t
Enumerator
SYNC
Synchronous: wait for all actions to be processed.
ASYNC
Asynchronous: queue action and return immediately.
◆ forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Enumerator
ONE_TO_ONE
Forward the property/action to the opposite port with the same index (e.g., if it comes from input port 0, forward it to output port 0).
ONE_TO_FAN
Fan-out forwarding: Forward to all opposite ports.
ONE_TO_ALL_IN
Forward the property to all input ports.
ONE_TO_ALL_OUT
Forward the property to all output ports.
ONE_TO_ALL
Forward the property to all ports.
DROP
Property propagation ends here.
USE_MAP
Forward the property based on a client-provided map.
◆ node_t()
uhd::rfnoc::node_t::node_t ( )
◆ ~node_t()
virtual uhd::rfnoc::node_t::~node_t ( )
◆ add_property_resolver()
void uhd::rfnoc::node_t::add_property_resolver ( prop_ptrs_t &&  inputs,
prop_ptrs_t &&  outputs,
resolver_fn_t &&  resolver_fn
Add a resolver function to this block.
A resolver function is used to reconcile state changes in the block, and is triggered by a user or other upstream/downstream blocks. A block may have multiple resolvers.
Notes on resolvers:
  • Multiple resolvers may share properties for reading and a resolver may read multiple properties
  • A resolver may assume the properties are in a consistent state before it executes, but it must leave the properties in a consistent state when it completes.
  • The framework will perform run-time validation to ensure read/write property access is not violated. All properties can be read during execution, but only properties in the outputs list can be written to.
  • Resolvers are stored and executed in the same order they are added. That is to say, if two resolvers both share a condition that will trigger them, the first resolver to be added will be the first resolver to be executed. This allows to make some assumptions on the order of execution, in case resolvers have dependencies.
  • This method has no built-in thread safety, since it is typically only called in the constructor. If resolvers need to be added at runtime (which is considered advanced usage), then the block needs to serialize access to this function itself.
For more information, see props_resolvers.
inputsThe properties that will cause this resolver to run
outputsThe properties that this resolver will write to
resolver_fnThe resolver function
Exceptions
uhd::runtime_errorif any of the properties listed is not registered
◆ check_topology()
virtual bool uhd::rfnoc::node_t::check_topology ( const std::vector< size_t > &  connected_inputs,
const std::vector< size_t > &  connected_outputs
protectedvirtual
Check if the current connections "work" for this block
The default implementation simply checks if all connections are within the valid range, i.e., no connected_inputs element is larger than get_num_input_ports(), etc. This can be overridden, but keep in mind that blocks need some kind of tolerance here, because blocks may simply not be part of the current application, and left unconnected. This check is more meant for blocks that simply don't work of only one of two ports is connected, or situations like that.
Note that this method is always called when a graph is committed, i.e., no connections will be added or removed without calling this method again, unless the user bypasses calling uhd::rfnoc_graph::commit(). This method can therefore be used to make decisions about the behaviour of the block.
connected_inputsA list of input ports that are connected
connected_outputsA list of output ports that are connected
true if the block can deal with this configuration
◆ clear_command_time()
virtual void uhd::rfnoc::node_t::clear_command_time ( const size_t  instance)
virtual
Standard API for resetting the command time
This will clear the time previously set by set_command_time(). It defaults to calling set_command_time(time_spec_t(0.0), instance)
◆ get_command_time()
virtual uhd::time_spec_t uhd::rfnoc::node_t::get_command_time ( const size_t  instance) const
virtual
Return a previously set command time
When no time was set, this will return uhd::time_spec_t::ASAP
◆ get_num_input_ports()
virtual size_t uhd::rfnoc::node_t::get_num_input_ports ( ) const
◆ get_num_output_ports()
virtual size_t uhd::rfnoc::node_t::get_num_output_ports ( ) const
◆ get_property() [1/2]
const prop_data_t & uhd::rfnoc::node_t::get_property ( const std::string &  id,
const res_source_info &  src_info
Get the value of a property.
This is like get_property(), but it also allows reading edge properties. All comments from get_property() still apply.
Template Parameters
prop_data_tThe data type of the property
idThe identifier of the property to write.
src_infoSource info of this property
The value of the property.
Exceptions
uhd::lookup_errorif the property can't be found.
◆ get_property() [2/2]
const size_t  instance = 0
Get the value of a specific block argument. The type of an argument must be known at compile time.
If the property does not exist, or if the property can be determined to be of a different type than prop_data_t due to the usage of runtime type information (RTTI), a lookup_error is thrown.
Note: Despite this being a "getter", this function is not declared const. This is because internally, it can resolve properties, which may cause changes within the object.
Template Parameters
instanceThe instance number of this property
Exceptions
◆ get_property_ids()
std::vector<std::string> uhd::rfnoc::node_t::get_property_ids ( ) const
Return the names of all possible user properties that can be accessed for this block.
Note that the type of the property is not auto-detectable.
A vector of all possible IDs of user properties supported by this block.
◆ get_unique_id()
virtual std::string uhd::rfnoc::node_t::get_unique_id ( ) const
virtual
In every RFNoC graph, no two nodes cannot have the same ID.
The unique ID as a string
Reimplemented in uhd::rfnoc::noc_block_base, uhd::rfnoc::test::mock_routing_node_t, uhd::rfnoc::test::mock_edge_node_t, uhd::rfnoc::test::mock_terminator_t, uhd::rfnoc::test::mock_streamer_t, uhd::rfnoc::test::mock_fifo_t, uhd::rfnoc::test::mock_ddc_node_t, and uhd::rfnoc::test::mock_radio_node_t.
◆ post_action()
void uhd::rfnoc::node_t::post_action ( const res_source_info &  edge_info,
action_mode_t  mode = action_mode_t::SYNC
Post an action to an up- or downstream node in the graph.
If the action is posted to an edge which is not connected, the action is lost.
The action handling can be either asynchronous or synchronous based on the mode parameter. When asynchronous, the action is placed in a FIFO queue and the function returns immediately. When synchronous (default), the function waits until all actions in the queue have been processed before returning. Note that only one thread can post actions synchronously, if another thread attempts to do so, that will result in a deadlock. Therefore, never post actions from an action handler synchronously.
edge_infoThe edge to which this action is posted. If edge_info.type == INPUT_EDGE, that means the action will be posted to an upstream node, on port edge_info.instance.
actionA reference to the action info object.
modeAction execution mode (SYNC for synchronous, ASYNC for asynchronous)
Exceptions
uhd::runtime_errorif edge_info is neither INPUT_EDGE nor OUTPUT_EDGE
◆ register_action_handler()
void uhd::rfnoc::node_t::register_action_handler ( const std::string &  id,
action_handler_t &&  handler
Handle a request to perform an action. The default action handler ignores user action and forwards port actions.
idThe action ID for which this action handler is valid. The first argument to the handler will be a uhd::rfnoc::action_info::sptr, and its id value will match this parameter (unless the same action handler is registered multiple times). If this function was previously called with the same id value, the previous action handler is overwritten.
handlerThe function that is called to handle the action. It needs to accept a uhd::rfnoc::res_source_info object, and a uhd::rfnoc::action_info::sptr.
◆ register_property()
void uhd::rfnoc::node_t::register_property ( property_base_t *  prop,
resolve_callback_t &&  clean_callback = nullptr
Register a property for this block
This is typically called from the constructor. It is possible to register properties later, but then the node must take care of serialization.
This has the intentional side-effect of setting the access mode to RW for the property. The idea is that after registering a property, the node might need some time to settle on the default value. The access mode will either be reset after the constructor is finished, or the next time properties are resolved.
For more information, see props_define.
propA reference to the property
clean_callbackA callback that gets executed whenever this property is dirty and gets marked clean
Exceptions
uhd::key_errorif another property with the same ID and source type is already registered
◆ set_action_forwarding_map()
void uhd::rfnoc::node_t::set_action_forwarding_map ( const forwarding_map_t &  map)
Specify a table that maps how an action should be forwarded
Whenever this node is asked to handle an action that is not registered, and the forwarding policy for the particular action is set to USE_MAP, the node will consult a user-provided map to determine what to do with the action. The map's keys are the source edges for the incoming action and the value associated with each key is a vector of destination edges to which the action should be forwarded.
incoming action and the value is a vector of destination edges to which the action should be forwarded.
If there is no key in the map matching an incoming action's source edge, or if the value of the key is the empty vector, the action is dropped and not forwarded further.
The following conditions will generate exceptions at action forwarding time:
  • Any value in the destination vector represents a non-existent port
mapThe map describing how actions should be forwarded
◆ set_action_forwarding_policy()
void uhd::rfnoc::node_t::set_action_forwarding_policy ( forwarding_policy_t  policy,
const std::string &  action_key = ""
Set an action forwarding policy
Whenever this node is asked to handle an action that is not registered, this is how the node knows what to do with the action. For example, the FIFO block controller will almost always want to pass on actions to the next block.
This method can be called more than once, and it will overwrite previous policies. Typically, this function should only ever be called from within the constructor.
policyThe policy that is applied (see also forwarding_policy_t).
action_keyThe action key that this forwarding policy is applied to. If action_key is not given, it will apply to all properties, unless a different policy was given with a matching key.
◆ set_command_time()
virtual void uhd::rfnoc::node_t::set_command_time ( uhd::time_spec_t  time,
virtual
Standard API for setting the command time
There are instances where commands need a time associated with them. For example, a block could have a 'freq' user property, which should be changed at a certain time. In that case, the block would have to be written to handle command times.
The reason there is no 'time' parameter in set_property() or other API calls is because there is no uniform definition of what the time means; it can change from block to block. The transformation of time to a tick count, for example, is non-standard.
The default implementation will simply stash away the time; it can be retrieved by calling get_command_time();
◆ set_prop_forwarding_map()
void uhd::rfnoc::node_t::set_prop_forwarding_map ( const forwarding_map_t &  map)
Specify a table that maps how a property should be forwarded
Whenever this node is asked to handle a property that is not registered, and the forwarding policy for the particular property is set to USE_MAP, the node will consult a user-provided map to determine what to do with the property. The map's keys are the source edges for the incoming property and the value associated with each key is a vector of destination edges to which the property should be propagated.
If there is no key in the map matching an incoming property's source edge, or if the value of the key is the empty vector, the property is dropped and not propagated further.
The following conditions will generate exceptions at property propagation time:
See also props_unknown.
mapThe map describing how properties should be propagated
◆ set_prop_forwarding_policy()
void uhd::rfnoc::node_t::set_prop_forwarding_policy ( forwarding_policy_t  policy,
const std::string &  prop_id = ""
Set a property forwarding policy for dynamic properties
Whenever this node is asked to handle a property that is not registered, this is how the node knows what to do with the property. For example, the FIFO block controller will almost always want to pass on properties to the next block.
This method can be called more than once, and it will overwrite previous policies. However, once a property has been registered with this block, the policy is set. Typically, this function should only ever be called from within the constructor.
prop_idThe property ID that this forwarding policy is applied to. If prop_id is not given, it will apply to all properties, unless a different policy was given with a matching ID.
◆ set_properties()
void uhd::rfnoc::node_t::set_properties ( const uhd::device_addr_t &  props,
Set multiple properties coming from a dictionary
This is equivalent to calling set_property() individually for every key/value pair of props. However, the type of the property will be automatically derived using RTTI. Only certain types are supported.
Property resolution happens after all properties have been updated.
This function allows the client to override the instance parameter for each property key/value pair passed in via the props parameter. If the key consists of the property name, followed by a colon (':') and then a number, the number following the colon is used to determine which instance of the property this set pertains to, and the instance parameter is ignored for that property. (Note that if the key does not have the colon and instance number override syntax, then instance is still used to determine which instance of the property to set. For example, in the following call:
node->set_properties("dog=10,cat:2=5,bird:0=0.5", 1)
instance 1 of node's 'dog' property is set to 10, the 1 coming from the instance parameter, instance 2 of the node's 'cat' property is set to 5 due to the override syntax provided in the string, and instance 0 of the node's 'bird' property is set to 0.5 due to its override.
If the instance override is malformed, that is, there is no number following the colon, or the number cannot be parsed as an integer, a value_error is thrown.
If a key in props is not a valid property of this block, a warning is logged, but no error is raised.
◆ set_property() [1/2]
void uhd::rfnoc::node_t::set_property ( const std::string &  id,
const prop_data_t &  val,
Set a specific property that belongs to this block.
This is like set_property(), but it also allows setting edge properties. All comments from set_property() still apply.
Template Parameters
idThe identifier of the property to write. To find out which values of id are valid, call get_property_ids()
valThe new value of the property.
src_infoSource info of the property
◆ set_property() [2/2]
Set a specific user property that belongs to this block.
Setting a user property will trigger a property resolution. This means that changing this block can have effects on other nodes.
Template Parameters
◆ shutdown()
virtual void uhd::rfnoc::node_t::shutdown ( )
protectedvirtual
Perform a shutdown sequence
This is mostly relevant for noc_block_base implementations. See also noc_block_base::shutdown().
Friends And Related Function Documentation
◆ node_accessor_t
friend class node_accessor_t
friend
◆ ALWAYS_DIRTY
dirtifier_t uhd::rfnoc::node_t::ALWAYS_DIRTY
staticprotected
A dirtifyer object, useful for properties that always need updating.
◆ ANY_PORT
const size_t uhd::rfnoc::node_t::ANY_PORT = size_t(~0)
