uhd::rfnoc::property_base_t Class Referenceabstract
#include <uhd/rfnoc/property.hpp>
Inheritance diagram for uhd::rfnoc::property_base_t:
uhd::rfnoc::property_t< double > uhd::rfnoc::property_t< int > uhd::rfnoc::dirtifier_t uhd::rfnoc::property_t< data_t >
Base class for properties
enum  access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 }
 property_base_t (const std::string &id, const res_source_info &source_info)
virtual ~property_base_t ()
const std::string & get_id () const
 Gets the ID (name) of this property. More...
const res_source_info & get_src_info () const
 Return the source info for this property. More...
virtual bool is_dirty () const =0
 Query this property's dirty flag. More...
virtual bool is_valid () const =0
 Query this property's valid flag. More...
bool read_access_granted () const
 Returns true if this property can be read. More...
bool write_access_granted () const
 Returns true if this property can be written to. More...
access_t get_access_mode () const
 Return the current access mode. More...
virtual bool equal (property_base_t *rhs) const =0
 Return true if rhs has the same type and value. More...
virtual std::unique_ptr< property_base_t > clone (res_source_info)
 Create a copy of this property. More...
virtual void force_dirty ()=0
virtual void set_from_str (const std::string &new_val_str)=0
Friends
class prop_accessor_t
◆ access_t
Enumerator
NONE
Neither reading nor writing to this property is permitted.
RO
Read-Only.
RW
Read-Write.
RWLOCKED
Write is locked. This lets you call set(), but only if the value is unchanged.
◆ property_base_t()
uhd::rfnoc::property_base_t::property_base_t ( const std::string &  id,
const res_source_info &  source_info
◆ ~property_base_t()
virtual uhd::rfnoc::property_base_t::~property_base_t ( )
◆ clone()
virtual std::unique_ptr<property_base_t> uhd::rfnoc::property_base_t::clone ( res_source_info  )
The copy must have the same type, value, and ID. However, it is often desirable to have a new source information, so that can be overridden.
The cleanliness state of original is not preserved. The new property will have the same cleanliness state as any other new property.
Reimplemented in uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, and uhd::rfnoc::property_t< int >.
◆ equal()
virtual bool uhd::rfnoc::property_base_t::equal ( property_base_t *  rhs) const
◆ force_dirty()
virtual void uhd::rfnoc::property_base_t::force_dirty ( )
◆ get_access_mode()
access_t uhd::rfnoc::property_base_t::get_access_mode ( ) const
◆ get_id()
const std::string& uhd::rfnoc::property_base_t::get_id ( ) const
◆ get_src_info()
const res_source_info& uhd::rfnoc::property_base_t::get_src_info ( ) const
◆ is_dirty()
virtual bool uhd::rfnoc::property_base_t::is_dirty ( ) const
If it's true, that means this property was recently changed, but changes have not propagated yet and still need resolving.
Implemented in uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, uhd::rfnoc::property_t< int >, and uhd::rfnoc::dirtifier_t.
◆ is_valid()
virtual bool uhd::rfnoc::property_base_t::is_valid ( ) const
If it's false, that means this property has a default value that should NOT be forwarded.
◆ read_access_granted()
bool uhd::rfnoc::property_base_t::read_access_granted ( ) const
◆ set_from_str()
virtual void uhd::rfnoc::property_base_t::set_from_str ( const std::string &  new_val_str)
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
Exceptions
uhd::runtime_errorif the underlying type has no conversion from a string
◆ write_access_granted()
bool uhd::rfnoc::property_base_t::write_access_granted ( ) const
Friends And Related Function Documentation
◆ prop_accessor_t
friend class prop_accessor_t
friend
