uhd::rfnoc::rf_control::antenna_radio_control_mixin Class Reference
#include <uhd/rfnoc/rf_control/antenna_iface.hpp>
Inheritance diagram for uhd::rfnoc::rf_control::antenna_radio_control_mixin:
uhd::rfnoc::rf_control::core_iface
Partially implements core_iface for antenna, redirecting to one of two subobjects for RX or TX.
virtual ~antenna_radio_control_mixin ()=default
std::string get_tx_antenna (const size_t chan) const override
std::vector< std::string > get_tx_antennas (const size_t chan) const override
void set_tx_antenna (const std::string &ant, const size_t chan) override
std::string get_rx_antenna (const size_t chan) const override
std::vector< std::string > get_rx_antennas (const size_t chan) const override
void set_rx_antenna (const std::string &ant, const size_t chan) override
- Public Member Functions inherited from uhd::rfnoc::rf_control::core_iface
virtual ~core_iface ()=default
virtual double get_tx_frequency (const size_t chan)=0
virtual double set_tx_frequency (const double freq, size_t chan)=0
virtual void set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range (const size_t chan) const =0
virtual double get_rx_frequency (const size_t chan)=0
virtual double set_rx_frequency (const double freq, const size_t chan)=0
virtual void set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range (const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_tx_gain (const size_t chan)=0
virtual double get_tx_gain (const std::string &name, const size_t chan)=0
virtual double set_tx_gain (const double gain, const size_t chan)=0
virtual double set_tx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_rx_gain (const size_t chan)=0
virtual double get_rx_gain (const std::string &name, const size_t chan)=0
virtual double set_rx_gain (const double gain, const size_t chan)=0
virtual double set_rx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_agc (const bool enable, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan) const =0
virtual double get_tx_bandwidth (const size_t chan)=0
virtual double set_tx_bandwidth (const double bandwidth, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan) const =0
virtual double get_rx_bandwidth (const size_t chan)=0
virtual double set_rx_bandwidth (const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0
virtual void set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_rx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq (const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_tx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan)=0
Protected Attributes
antenna_iface::sptr _rx_antenna
antenna_iface::sptr _tx_antenna
- Public Types inherited from uhd::rfnoc::rf_control::core_iface
using sptr = std::shared_ptr< core_iface >
◆ ~antenna_radio_control_mixin()
virtual uhd::rfnoc::rf_control::antenna_radio_control_mixin::~antenna_radio_control_mixin ( )
virtualdefault
◆ get_rx_antenna()
std::string uhd::rfnoc::rf_control::antenna_radio_control_mixin::get_rx_antenna ( const size_t  chan) const
overridevirtual
Return the selected RX antenna for channel chan.
The selected antenna.
Implements uhd::rfnoc::rf_control::core_iface.
◆ get_rx_antennas()
std::vector<std::string> uhd::rfnoc::rf_control::antenna_radio_control_mixin::get_rx_antennas ( const size_t  chan) const
overridevirtual
Return a list of valid RX antenna for channel chan.
◆ get_tx_antenna()
std::string uhd::rfnoc::rf_control::antenna_radio_control_mixin::get_tx_antenna ( const size_t  chan) const
overridevirtual
Return the selected TX antenna for channel chan.
◆ get_tx_antennas()
std::vector<std::string> uhd::rfnoc::rf_control::antenna_radio_control_mixin::get_tx_antennas ( const size_t  chan) const
overridevirtual
Return a list of valid TX antenna for channel chan.
◆ set_rx_antenna()
void uhd::rfnoc::rf_control::antenna_radio_control_mixin::set_rx_antenna ( const std::string &  ant,
const size_t  chan
overridevirtual
Select RX antenna for channel chan.
Exceptions
uhd::value_errorif ant is not a valid value.
◆ set_tx_antenna()
void uhd::rfnoc::rf_control::antenna_radio_control_mixin::set_tx_antenna ( const std::string &  ant,
const size_t  chan
overridevirtual
Select TX antenna for channel chan.
Exceptions
◆ _rx_antenna
antenna_iface::sptr uhd::rfnoc::rf_control::antenna_radio_control_mixin::_rx_antenna
◆ _tx_antenna
antenna_iface::sptr uhd::rfnoc::rf_control::antenna_radio_control_mixin::_tx_antenna
