uhd::rfnoc::rf_control::enumerated_antenna Class Reference
#include <uhd/rfnoc/rf_control/antenna_iface.hpp>
Inheritance diagram for uhd::rfnoc::rf_control::enumerated_antenna:
uhd::rfnoc::rf_control::antenna_iface
Class for getting and setting antennas out of an enumerated set, where the API calls for the antenna actually map to property nodes.
using prop_path = std::function< fs_path(const size_t chan)>
- Public Types inherited from uhd::rfnoc::rf_control::antenna_iface
using sptr = std::shared_ptr< antenna_iface >
 enumerated_antenna (uhd::property_tree::sptr tree, prop_path prop_path_generator, const std::vector< std::string > &possible_antennas, const std::unordered_map< std::string, std::string > &compat_map)
virtual ~enumerated_antenna ()=default
std::vector< std::string > get_antennas (const size_t chan) const override
void set_antenna (const std::string &ant, const size_t chan) override
std::string get_antenna (const size_t chan) const override
- Public Member Functions inherited from uhd::rfnoc::rf_control::antenna_iface
virtual ~antenna_iface ()=default
◆ prop_path
using uhd::rfnoc::rf_control::enumerated_antenna::prop_path = std::function<fs_path(const size_t chan)>
◆ enumerated_antenna()
uhd::rfnoc::rf_control::enumerated_antenna::enumerated_antenna ( uhd::property_tree::sptr  tree,
const std::vector< std::string > &  possible_antennas,
const std::unordered_map< std::string, std::string > &  compat_map
Constructs an enumerated_antenna class.
treeThe property tree the nodes are on
prop_path_generatorClosure to generate the property path given the channel.
possible_antennasA vector of legal antennas.
compat_mapA map of alternative names for antennas.
◆ ~enumerated_antenna()
virtual uhd::rfnoc::rf_control::enumerated_antenna::~enumerated_antenna ( )
virtualdefault
◆ get_antenna()
std::string uhd::rfnoc::rf_control::enumerated_antenna::get_antenna ( const size_t  chan) const
overridevirtual
Return the selected antenna for channel chan.
The selected antenna.
Implements uhd::rfnoc::rf_control::antenna_iface.
◆ get_antennas()
std::vector<std::string> uhd::rfnoc::rf_control::enumerated_antenna::get_antennas ( const size_t  chan) const
overridevirtual
Return a list of valid antenna for channel chan.
◆ set_antenna()
void uhd::rfnoc::rf_control::enumerated_antenna::set_antenna ( const std::string &  ant,
const size_t  chan
overridevirtual
Select antenna for channel chan.
Exceptions
uhd::value_errorif ant is not a valid value.
