uhd::rfnoc::rf_control::nameless_gain_mixin Class Reference
#include <uhd/rfnoc/rf_control/nameless_gain_mixin.hpp>
Inheritance diagram for uhd::rfnoc::rf_control::nameless_gain_mixin:
uhd::rfnoc::rf_control::core_iface
Partially implements core_iface for the gain functions which take no name parameter
using name_selector = std::function< std::string(const uhd::direction_t trx, const size_t chan)>
- Public Types inherited from uhd::rfnoc::rf_control::core_iface
using sptr = std::shared_ptr< core_iface >
 nameless_gain_mixin (name_selector name_selector)
virtual ~nameless_gain_mixin ()=default
double set_tx_gain (const double gain, const size_t chan) override
double get_tx_gain (const size_t chan) override
double set_rx_gain (const double gain, const size_t chan) override
double get_rx_gain (const size_t chan) override
gain_range_t get_tx_gain_range (const size_t chan) const override
gain_range_t get_rx_gain_range (const size_t chan) const override
- Public Member Functions inherited from uhd::rfnoc::rf_control::core_iface
virtual ~core_iface ()=default
virtual std::string get_tx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_tx_antennas (const size_t chan) const =0
virtual void set_tx_antenna (const std::string &ant, const size_t chan)=0
virtual std::string get_rx_antenna (const size_t chan) const =0
virtual std::vector< std::string > get_rx_antennas (const size_t chan) const =0
virtual void set_rx_antenna (const std::string &ant, const size_t chan)=0
virtual double get_tx_frequency (const size_t chan)=0
virtual double set_tx_frequency (const double freq, size_t chan)=0
virtual void set_tx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range (const size_t chan) const =0
virtual double get_rx_frequency (const size_t chan)=0
virtual double set_rx_frequency (const double freq, const size_t chan)=0
virtual void set_rx_tune_args (const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range (const size_t chan) const =0
virtual std::vector< std::string > get_tx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_tx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_tx_gain (const std::string &name, const size_t chan)=0
virtual double set_tx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_rx_gain_names (const size_t chan) const =0
virtual uhd::gain_range_t get_rx_gain_range (const std::string &name, const size_t chan) const =0
virtual double get_rx_gain (const std::string &name, const size_t chan)=0
virtual double set_rx_gain (const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_agc (const bool enable, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range (size_t chan) const =0
virtual double get_tx_bandwidth (const size_t chan)=0
virtual double set_tx_bandwidth (const double bandwidth, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range (size_t chan) const =0
virtual double get_rx_bandwidth (const size_t chan)=0
virtual double set_rx_bandwidth (const double bandwidth, const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range (const std::string &name, const size_t chan) const =0
virtual void set_rx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_rx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled (bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_rx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_rx_lo_freq (double freq, const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq (const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names (const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources (const std::string &name, const size_t chan) const =0
virtual freq_range_t get_tx_lo_freq_range (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_source (const std::string &src, const std::string &name, const size_t chan)=0
virtual std::string get_tx_lo_source (const std::string &name, const size_t chan)=0
virtual void set_tx_lo_export_enabled (const bool enabled, const std::string &name, const size_t chan)=0
virtual bool get_tx_lo_export_enabled (const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq (const double freq, const std::string &name, const size_t chan)=0
virtual double get_tx_lo_freq (const std::string &name, const size_t chan)=0
◆ name_selector
using uhd::rfnoc::rf_control::nameless_gain_mixin::name_selector = std::function<std::string(const uhd::direction_t trx, const size_t chan)>
◆ nameless_gain_mixin()
uhd::rfnoc::rf_control::nameless_gain_mixin::nameless_gain_mixin ( name_selector  name_selector)
Sets the name selector for the mixin. The closure receives the direction of the call and the channel, and returns the gain to use for the call. The name selector may simply return a string, or may do a more complex algorithm.
◆ ~nameless_gain_mixin()
virtual uhd::rfnoc::rf_control::nameless_gain_mixin::~nameless_gain_mixin ( )
virtualdefault
◆ get_rx_gain()
double uhd::rfnoc::rf_control::nameless_gain_mixin::get_rx_gain ( const size_t  chan)
overridevirtual
Return the overall receive gain on channel chan
The actual gain value
Implements uhd::rfnoc::rf_control::core_iface.
◆ get_rx_gain_range()
gain_range_t uhd::rfnoc::rf_control::nameless_gain_mixin::get_rx_gain_range ( const size_t  chan) const
overridevirtual
Return a range of valid RX gains
◆ get_tx_gain()
double uhd::rfnoc::rf_control::nameless_gain_mixin::get_tx_gain ( const size_t  chan)
overridevirtual
Return the overall transmit gain on channel chan
◆ get_tx_gain_range()
gain_range_t uhd::rfnoc::rf_control::nameless_gain_mixin::get_tx_gain_range ( const size_t  chan) const
overridevirtual
Return a range of valid TX gains
◆ set_rx_gain()
double uhd::rfnoc::rf_control::nameless_gain_mixin::set_rx_gain ( const double  gain,
const size_t  chan
overridevirtual
Set the overall receive gain on channel chan
This function will attempt to set the gain as close as possible, and return a coerced value of the actual gain value.
◆ set_tx_gain()
double uhd::rfnoc::rf_control::nameless_gain_mixin::set_tx_gain ( const double  gain,
const size_t  chan
overridevirtual
Set the transmit gain on channel chan
This method will set the overall gain. To set a specific gain, use set_tx_gain(const double, const std::string&, const size_t).
