#include <uhd/cal/database.hpp>
Calibration Data Storage/Retrieval Class
UHD can store calibration data on disk or compiled within UHD. This class provides access to both locations.
This class can read and write binary data, but it does not verify the data or expect any kind of format. It simply manages BLOBs (binary large objects). It is up to the consumers and producers of this data to agree on a format. Typically, since this class stores calibration data, it will be consuming data that was produced by uhd::usrp::cal::container::serialize().
Calibration data is indexed by two keys: An arbitrary key that describes the type of calibration data (e.g., "rx_iq") and a serial number. The serial number has to uniquely identify the device for which the calibration data was obtained. This can either be the serial number of the daughterboard (if the calibration data only relates to the daughterboard), the motherboard (for example, if there is no such thing as a daughterboard, or the data only relates to the motherboard), it can be combination of both daughterboard and motherboard serial (if the calibration data is only valid for a combination), or it can be a combination of a device serial number and a channel index (if a device with single serial has different channels that have separate characteristics).
It is up to the individual device drivers which value they use for the serial numbers and keys.
Note that the serial number is irrelevant when the data is pulled out of the resource compiler. By definition, it is not permitted to store data in the resource compiler that is specific to a certain serial number, only data that applies to an entire family of devices is permitted.
Public Types | |
| using | has_data_fn_type = std::function< bool(const std::string &, const std::string &)> |
| Function type to look up if there is cal data given a key and serial. More... | |
| using | get_data_fn_type = std::function< std::vector< uint8_t >(const std::string &, const std::string &)> |
| Function type to return serialized cal data key and serial. More... | |
| static std::vector< uint8_t > | read_cal_data (const std::string &key, const std::string &serial, const source source_type=source::ANY) |
| Return a calibration data set as a serialized string. More... | |
| static bool | has_cal_data (const std::string &key, const std::string &serial, const source source_type=source::ANY) |
| Check if calibration data exists for a given source type. More... | |
| static void | write_cal_data (const std::string &key, const std::string &serial, const std::vector< uint8_t > &cal_data, const std::string &backup_ext="") |
| Store calibration data to the local filesystem database. More... | |
| static void | register_lookup (has_data_fn_type has_cal_data, get_data_fn_type get_cal_data, const source source_type=source::FLASH) |
| Register a lookup function for cal data. More... | |
| using uhd::usrp::cal::database::get_data_fn_type = std::function<std::vector<uint8_t>(const std::string&, const std::string&)> |
These functions should throw a uhd::runtime_error if called with invalid key/serial pairs, although database will internally always call the corresponding 'has' function before calling this.
| using uhd::usrp::cal::database::has_data_fn_type = std::function<bool(const std::string&, const std::string&)> |
This can be called before calling read_cal_data() to avoid having to catch an exception. If source_type is FILESYSTEM, then it will only return true if a file is found with the appropriate cal data. The same is true for RC. If is ANY, then having either RC or FILESYSTEM data will yield true.
| key | The calibration type key (e.g., "rx_iq") |
| serial | The serial number of the device this data is for. See also Serial number and key |
| source_type | Where to read the calibration data from. For anything other than RC, FILESYSTEM, or ANY, this will always return false because this class does not have access to user data or EEPROM data. |
Note: the source_type parameter can be used to specify where to read cal data from. However, this class only has access to RC and FILESYSTEM type cal data. ANY will pick FILESYSTEM data if both are available, and RC data if only RC data is available.
| source_type | Where to read the calibration data from. See comments above. For anything other than RC, FILESYSTEM, or ANY, this will always throw a uhd::key_error because this class does not have access to user data or EEPROM data. |
| uhd::key_error | if no calibration data is found matching the source type. |
| has_cal_data | A function object to a function that returns true if cal data is available |
| get_cal_data | A function object to a function that returns serialized cal data |
| source_type | Reserved. Must be source::FLASH. |
This implies a source type of FILESYSTEM. Note that writing the data does not apply it to a currently running UHD session. Devices will typically load calibration data at initialization time, and thus this call will take effect only for future UHD sessions.
If calibration data for this key/serial pair already exists in the database, the original data will be backed up by renaming the original file from filename.cal to filename.cal.$TIMESTAMP. Alternatively, a custom extension can be chosen instead of $TIMESTAMP.
| cal_data | The calibration data to be written |
| backup_ext | A custom extension for backing up calibration data. If left empty, a POSIX timestamp is used. |
