uhd::utils::chdr::chdr_packet Class Reference
#include <uhd/utils/chdr/chdr_packet.hpp>
A Generic class that represents a CHDR Packet
This class is not used by UHD, it is a helper class for writing tests or other types of utilities. The class has the capability of representing any CHDR packet, and serializing this class into a CHDR packet (or deserializing from a buffer to populate this class). It is not optimized for high performance. For example, this is used in UHD unit tests, and in the USRP simulator to provide an easy way to generate CHDR packets from Python.
Whether the packet has a specific type of payload is not specified, but of course the CHDR header can be set as desired, and a payload can be provided to the constructor.
template<typename payload_t >
 chdr_packet (uhd::rfnoc::chdr_w_t chdr_w, uhd::rfnoc::chdr::chdr_header header, payload_t payload, std::optional< uint64_t > timestamp={}, std::vector< uint64_t > metadata={})
 chdr_packet (uhd::rfnoc::chdr_w_t chdr_w, uhd::rfnoc::chdr::chdr_header header, std::vector< uint8_t > payload_data, std::optional< uint64_t > timestamp={}, std::vector< uint64_t > metadata={})
uhd::rfnoc::chdr::chdr_header get_header () const
void set_header (uhd::rfnoc::chdr::chdr_header header)
std::optional< uint64_t > get_timestamp () const
void set_timestamp (std::optional< uint64_t > timestamp)
const std::vector< uint64_t > & get_metadata () const
void set_metadata (std::vector< uint64_t > metadata)
std::vector< uint8_t > serialize_to_byte_vector (endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
template<typename OutputIterator >
void serialize (OutputIterator first, OutputIterator last, endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
size_t get_packet_len () const
const std::vector< uint8_t > & get_payload_bytes () const
void set_payload_bytes (std::vector< uint8_t > bytes)
payload_t get_payload (uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
void set_payload (payload_t payload, uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE)
std::string to_string () const
 Return a string representation of this object. More...
std::string to_string_with_payload (uhd::endianness_t endianness=uhd::ENDIANNESS_LITTLE) const
 Return a string representation of this object and deserialize its payload. More...
void serialize (OutputIterator first, OutputIterator last, uhd::endianness_t endianness) const
template<typename InputIterator >
chdr_packet deserialize (uhd::rfnoc::chdr_w_t chdr_w, InputIterator first, InputIterator last, uhd::endianness_t endianness)
static chdr_packet deserialize (uhd::rfnoc::chdr_w_t chdr_w, InputIterator first, InputIterator last, endianness_t endianness=uhd::ENDIANNESS_LITTLE)
◆ chdr_packet() [1/2]
uhd::utils::chdr::chdr_packet::chdr_packet ( uhd::rfnoc::chdr_w_t  chdr_w,
payload_t  payload,
std::optional< uint64_t >  timestamp = {},
std::vector< uint64_t >  metadata = {}
Constructs a CHDR Packet from a header and a payload
This is commonly used to create a non-data packet (e.g., control, stream status, etc.).
chdr_wCHDR width
headerCHDR header
payloadThe payload object (e.g., a chdr_rfnoc::ctrl_payload if that's the type of payload_t).
timestampTimestamp, defaults to no timestamp in the header.
metadataMetadata, defaults to no metadata.
◆ chdr_packet() [2/2]
Construct a CHDR Packet from a header and raw payload words
This is the typical way to construct data packets, or to manually construct non-data packets by bypassing the corresponding payload types.
chdr_wCHDR width
headerCHDR header
payload_dataThe payload data as bytes, i.e., whatever follows the CHDR header.
◆ deserialize() [1/2]
static chdr_packet uhd::utils::chdr::chdr_packet::deserialize ( uhd::rfnoc::chdr_w_t  chdr_w,
InputIterator  last,
endianness_t  endianness = uhd::ENDIANNESS_LITTLE
Deserialize a CHDR Packet from a buffer of bytes
chdr_wthe CHDR_W of the incoming packet
endiannessthe endianness of the input buffer (link endianness)
firstthe start of the input buffer
lastthe end of the input buffer
a CHDR Packet with an unspecified payload type
◆ deserialize() [2/2]
InputIterator  last,
◆ get_header()
uhd::rfnoc::chdr::chdr_header uhd::utils::chdr::chdr_packet::get_header ( ) const
Returns the contents of the CHDR header
The CHDR header
◆ get_metadata()
const std::vector<uint64_t>& uhd::utils::chdr::chdr_packet::get_metadata ( ) const
Returns a const reference to the metadata
The metadata reference
◆ get_packet_len()
size_t uhd::utils::chdr::chdr_packet::get_packet_len ( ) const
Get the total serialized length of the packet
The length of the packet in bytes
◆ get_payload()
payload_t uhd::utils::chdr::chdr_packet::get_payload ( uhd::endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
Parses the data out of this objects payload field into a payload_t object
endiannessThe link endianness of the CHDR Link
The parsed payload_t object
◆ get_payload_bytes()
const std::vector<uint8_t>& uhd::utils::chdr::chdr_packet::get_payload_bytes ( ) const
Returns a const reference to the payload bytes
The payload reference
◆ get_timestamp()
std::optional<uint64_t> uhd::utils::chdr::chdr_packet::get_timestamp ( ) const
Returns the timestamp in the packet as an optional value
A std::optional which if initialized has the timestamp
◆ serialize() [1/2]
void uhd::utils::chdr::chdr_packet::serialize ( OutputIterator  first,
) const
Serialize a CHDR Packet into a buffer
endiannessthe endianness of the output buffer (link endianness)
firstthe start of the output buffer
lastthe end of the output buffer
◆ serialize() [2/2]
) const
◆ serialize_to_byte_vector()
std::vector<uint8_t> uhd::utils::chdr::chdr_packet::serialize_to_byte_vector ( endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
Serialize a CHDR Packet into a vector of bytes
endiannessthe endianness of the returned vector (link endianness)
a vector of bytes which represents the CHDR Packet in serialize form
◆ set_header()
void uhd::utils::chdr::chdr_packet::set_header ( uhd::rfnoc::chdr::chdr_header  header)
Change this object's header
headerThe new CHDR header
◆ set_metadata()
void uhd::utils::chdr::chdr_packet::set_metadata ( std::vector< uint64_t >  metadata)
Sets the metadata for a CHDR packet and updates the headers
metadataA vector containing the new metadata
◆ set_payload()
void uhd::utils::chdr::chdr_packet::set_payload ( payload_t  payload,
Serializes the payload object into bytes and stores it in this object's payload field
payloadthe payload object to store
◆ set_payload_bytes()
void uhd::utils::chdr::chdr_packet::set_payload_bytes ( std::vector< uint8_t >  bytes)
Sets the current payload
bytesthe payload to store inside this object (It is moved from)
◆ set_timestamp()
void uhd::utils::chdr::chdr_packet::set_timestamp ( std::optional< uint64_t >  timestamp)
Sets the timestamp in the packet
timestampthe timestamp to set, or an empty optional for no timestamp
◆ to_string()
std::string uhd::utils::chdr::chdr_packet::to_string ( ) const
◆ to_string_with_payload()
std::string uhd::utils::chdr::chdr_packet::to_string_with_payload ( uhd::endianness_t  endianness = uhd::ENDIANNESS_LITTLE) const
