USRP Hardware Driver and Device Manual
Version: 4.11.0.0-0-g0d7ed3b1
config.hpp
1
2
// Copyright 2010-2011,2014-2016 Ettus Research LLC
3
// Copyright 2018 Ettus Research, a National Instruments Company
4
5
// SPDX-License-Identifier: GPL-3.0-or-later
6
7
8
#pragma once
9
10
#ifdef _MSC_VER
11
12
# define UHD_MSVC _MSC_VER
13
// suppress warnings
14
// # pragma warning(push)
15
// # pragma warning(disable: 4511) // copy constructor can't not be generated
16
// # pragma warning(disable: 4512) // assignment operator can't not be generated
// # pragma warning(disable: 4100) // unreferenced formal parameter
18
// # pragma warning(disable: 4996) // <symbol> was declared deprecated
19
# pragma warning(disable : 4355)
// 'this' : used in base member initializer list
// # pragma warning(disable: 4706) // assignment within conditional expression
21
# pragma warning(disable : 4251)
// class 'A<T>' needs to have dll-interface to be used
22
// by clients of class 'B'
23
// # pragma warning(disable: 4127) // conditional expression is constant
// # pragma warning(disable: 4290) // C++ exception specification ignored except to ...
25
// # pragma warning(disable: 4180) // qualifier applied to function type has no meaning;
26
// ignored
27
# pragma warning(disable : 4275)
// non dll-interface class ... used as base for
28
// dll-interface class ...
29
// # pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible
30
// loss of data # pragma warning(disable: 4511) // 'class' : copy constructor could not
31
// be generated
32
# pragma warning(disable : 4250)
// 'class' : inherits 'method' via dominance
33
# pragma warning( \
34
disable : 4200)
// nonstandard extension used : zero-sized array in struct/union
35
36
// define logical operators
37
# include <ciso646>
38
39
// define ssize_t
40
# ifndef _SSIZE_T_DEFINED
41
# define _SSIZE_T_DEFINED
42
# include <BaseTsd.h>
43
typedef
SSIZE_T ssize_t;
44
# endif
/* _SSIZE_T_DEFINED */
45
46
#endif
// _MSC_VER
47
53
#define UHD_FALLTHROUGH [[fallthrough]];
54
55
// define cross platform attribute macros
56
#if defined(UHD_MSVC)
57
# define UHD_EXPORT __declspec(dllexport)
58
# define UHD_IMPORT __declspec(dllimport)
59
# define UHD_EXPORT_HEADER
60
# define UHD_IMPORT_HEADER
61
# define UHD_INLINE __forceinline
62
# define UHD_FORCE_INLINE __forceinline
63
# define UHD_DEPRECATED __declspec(deprecated)
64
# define UHD_ALIGNED(x) __declspec(align(x))
65
# define UHD_UNUSED(x) x
66
# define UHD_FUNCTION __FUNCTION__
67
# define UHD_PRETTY_FUNCTION __FUNCSIG__
68
#elif defined(__MINGW32__)
69
70
71
72
73
# define UHD_INLINE inline
74
# define UHD_FORCE_INLINE inline
75
76
77
# define UHD_UNUSED(x) x __attribute__((unused))
78
# define UHD_FUNCTION __func__
79
# define UHD_PRETTY_FUNCTION __PRETTY_FUNCTION__
80
#elif defined(__clang__)
81
# define UHD_EXPORT __attribute__((visibility("default"
82
# define UHD_IMPORT __attribute__((visibility("default"
83
# define UHD_EXPORT_HEADER __attribute__((visibility("default"
84
# define UHD_IMPORT_HEADER __attribute__((visibility("default"
85
# define UHD_INLINE inline __attribute__((always_inline))
86
# define UHD_FORCE_INLINE inline __attribute__((always_inline))
87
# define UHD_DEPRECATED __attribute__((deprecated))
88
# define UHD_ALIGNED(x) __attribute__((aligned(x)))
89
90
91
92
# if __clang_major__ >= 10
93
# define UHD_HAVE_WDEPRECATED_VOLATILE
94
# endif
95
#elif defined(__GNUG__) && __GNUG__ >= 4
96
97
98
99
100
101
102
103
104
105
106
107
# if __GNUG__ >= 10
108
# define UHD_HAVE_WVOLATILE
109
# endif
110
#else
111
# define UHD_EXPORT
112
# define UHD_IMPORT
113
114
115
116
117
118
119
120
121
# define UHD_PRETTY_FUNCTION __func__
122
#endif
123
124
// Define API declaration macro
125
126
// UHD_API should be used for classes/structs that
127
// have a direct cpp implementations that get directly
128
// built into a so/dylib/dll.
129
130
// UHD_API_HEADER should be used for classes/structs
131
// that are implemented in header only like hpp/ipp.
132
#ifdef UHD_STATIC_LIB
133
# define UHD_API
134
# define UHD_API_HEADER
135
#else
136
# ifdef UHD_DLL_EXPORTS
137
# define UHD_API UHD_EXPORT
138
# define UHD_API_HEADER UHD_EXPORT_HEADER
139
# else
140
# define UHD_API UHD_IMPORT
141
# define UHD_API_HEADER UHD_IMPORT_HEADER
142
# endif
// UHD_DLL_EXPORTS
143
#endif
// UHD_STATIC_LIB
144
145
// Platform defines for conditional parts of headers:
146
// Taken from boost/config/select_platform_config.hpp,
147
// however, we define macros, not strings for platforms.
148
#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) \
149
&& !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
150
# define UHD_PLATFORM_LINUX
151
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
152
# define UHD_PLATFORM_WIN32
153
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
154
# define UHD_PLATFORM_MACOS
155
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) \
156
157
# define UHD_PLATFORM_BSD
158
#endif
159
160
// Define 'stringize' preprocessor macros. The stringize macro, XSTR, takes
161
// variable arguments so that it can deal with strings that contain commas.
162
// There are two different versions because MSVC handles this syntax a bit
163
// differently than other compilers.
164
165
# define XSTR(x, ...) # x
166
#else
167
# define XSTR(x...) # x
168
#endif
169
170
#define STR(x) XSTR(x)
include
uhd
config.hpp
Generated by
1.9.1
