Example Programs
UHD Example Programs
UHD (USRP Hardware Driver) ships with a comprehensive set of example programs in both C++ and Python. These examples are designed to help users understand how to interact with USRP devices, configure hardware, stream data, and implement common signal processing tasks using the UHD Multi-USRP and RFNoC APIs.
In addition to the UHD examples, it may also be helpful to explore the GNU Radio example programs that demonstrate how to use UHD with USRP devices. These can be found in the gr-uhd directory of the GNU Radio repository.
What are UHD Examples For?
The UHD examples serve several important purposes:
  • Getting Started: They provide working code for basic device setup, streaming, and file I/O, making it easy for new users to get started with USRP hardware.
  • Reference Implementations: The examples demonstrate recommended usage patterns for the UHD API, including device configuration, error handling, and timing control.
  • Testing and Validation: Some examples can be used to verify hardware operation, test connectivity, and validate system performance.
  • Advanced Features: Some examples showcase advanced UHD features such as multi-channel streaming, timed commands, RFNoC block usage, and synchronization across multiple devices.
You can use these examples as templates for your own applications, as diagnostic tools, or as a starting point for learning UHD programming.
Location of Example Programs
The UHD example programs are installed in the examples directory within the UHD installation.
  • Linux:
    • The default installation path is /usr/lib/uhd/examples (or /usr/libexec/uhd/examples).
  • Windows:
    • The default installation path is C:\Program Files\UHD\lib\uhd\examples.
The examples directory contains:
Running the Examples:
Most UHD examples can be run directly from the command line. Use the --help option with each example to see available command-line arguments and usage instructions. Most examples require device arguments (e.g., --args "addr=192.168.10.2" or --args "type=b200,name=123456").
Modifying and Compiling C++ Example Programs
Most C++ examples are built and installed automatically as part of the UHD build process.
For instructions on building UHD from source, see the UHD Build Guide.
  • The C++ example source files are located in the UHD source tree at:
    host/examples/
  • If you wish to develop your own C++ application and link it against UHD (either dynamically or statically), refer to the init_usrp.cpp example in the UHD source tree.
    For a step-by-step guide, see Getting Started with UHD and C++.
Overview of UHD Example Programs
The tables below list the UHD C++ and Python example programs that are shipped with the UHD driver. These examples are provided to help users learn how to interact with USRP devices, explore UHD features, and perform common or advanced tasks.
API Compatibility and Device Requirements:
The "UHD API" column indicates whether the example uses the high-level Multi-USRP API (compatible with most USRP devices) or the RFNoC API (requires RFNoC-capable USRP devices).
Glossary for Table Columns:
  • Multiple Channel Support: Indicates if the example supports multiple USRP channels from one ore more USRP devices simultaneously.
  • TX/RX: Shows whether the example transmits (TX), receives (RX), or does both (TX/RX).
  • UHD API: Specifies the UHD API used (multi_usrp or rfnoc).
  • Description: Brief summary of the example's purpose.
For clarity, the examples are classified into three categories, although the boundaries between them are not strict (The classification of examples into Application, Feature, and Utility is for convenience; some examples may demonstrate multiple aspects of UHD usage.):
  • Application Examples: Ready-to-use programs for transmitting or receiving data with USRP device(s). These examples typically support a wide range of command-line options, allowing users to adapt the behavior to various hardware configurations, signal types, and operational scenarios.
  • Feature Examples: Programs designed to specifically demonstrate the use of a particular UHD feature or API function. These are ideal for learning how to implement or integrate specific capabilities, such as timed commands, streaming modes, or device synchronization.
  • Utility Examples: Tools for characterizing USRP performance, diagnosing hardware or software issues, or performing measurements such as latency, throughput, or clock stability.
Some examples use the Multi-USRP API, which provides a high-level, device-agnostic interface for configuring, controlling, and streaming data to and from USRP devices. The Multi-USRP API makes it easy to set up devices, manage channels, and perform standard SDR operations with minimal code. If an example listed in the tables below uses the 'Multi-USRP API' and is marked as having 'Multiple Channel Support', then it inherently supports operation with multiple USRP devices.
Other examples use the RFNoC API, which allows for direct interaction with RFNoC (RF Network-on-Chip) blocks on supported USRP devices. The RFNoC API enables advanced users to leverage FPGA-based signal processing, custom block development, and flexible data routing for high-performance and specialized applications.
Refer to the tables below for a summary of the available UHD C++ and Python examples, their classification, and a brief description of their purpose.
C++ Examples
Example Filename Multiple Channel Support TX/RX UHD API Description
rx_ascii_art_dft[.cpp] No RX Multi-USRP Continuously receives complex baseband samples (IQ) from a USRP device and displays an ASCII-art DFT spectrum in the terminal.
rx_samples_to_file[.cpp] Yes RX Multi-USRP Receive complex baseband samples (IQ) from USRP device(s) and save them to binary file(s).
rx_samples_to_udp[.cpp] No RX Multi-USRP Stream received complex baseband samples (IQ) from USRP device(s) and forward them to a UDP socket.
twinrx_freq_hopping[.cpp] No RX Multi-USRP Demonstrates how to use the TwinRX daughterboard to receive complex baseband samples (IQ) with frequency hopping on USRP devices.
tx_samples_from_file[.cpp] Yes TX Multi-USRP Transmit complex baseband samples (IQ) from a binary file via USRP device(s).
tx_waveforms[.cpp] Yes TX Multi-USRP Transmit complex baseband samples (IQ) of generated waveforms (sine, square, ramp, constant) via USRP device(s).
txrx_loopback_to_file[.cpp] Yes TX/RX Multi-USRP Transmit and receive complex baseband samples (IQ) in TX/RX loopback mode using one or two USRP devices, with support for waveform generation and multi-channel file recording.
rfnoc_radio_loopback[.cpp] No n/a RFNoC Configures an RFNoC graph to stream complex baseband samples (IQ) directly from RX to TX.
rfnoc_replay_samples_from_file[.cpp] No TX RFNoC Demonstrates replaying complex baseband samples (IQ) from a file to a USRP radio using the RFNoC Replay block.
rfnoc_rx_to_file[.cpp] No RX RFNoC Configures an RFNoC graph to stream complex baseband samples (IQ) from Radio to host and saves received data to file. Allows to insert a user-defined RFNoC block.
Feature Examples
gpio[.cpp] Yes TX/RX Multi-USRP Demonstrates and tests USRP GPIO configuration, bit-banging, and ATR control.
rx_multi_samples[.cpp] Yes RX Multi-USRP Demonstrates time aligned reception of complex baseband samples (IQ) from multiple channels/USRP devices.
rx_timed_samples[.cpp] Yes RX Multi-USRP Demonstrates scheduling RX at a specific USRP time, stopping after N samples, and checking for errors.
spi[.cpp] No n/a Multi-USRP Demonstrates basic SPI communication via the USRP GPIO interface of X4xx USRP devices using the UHD API.
sync_to_gps[.cpp] No n/a Multi-USRP Demonstrates configuring USRP to use a built-in GPSDO for clock and PPS reference.
test_messages[.cpp] No TX/RX Multi-USRP Tests USRP async error and event message handling (e.g., late command, burst ACK).
test_timed_commands[.cpp] No RX Multi-USRP Demonstrates and tests timed USRP commands and timed RX streaming with UHD.
tx_bursts[.cpp] Yes TX Multi-USRP Transmit complex baseband samples (IQ) in timed bursts with user-defined timing and burst length via USRP.
tx_timed_samples[.cpp] No TX Multi-USRP Demonstrates scheduling TX at a specific USRP time, stopping after N samples, and checking for ACK.
txrx_complex_gain[.cpp] Yes TX/RX Multi-USRP Demonstrates how to enable and use timed complex gain adjustment for TX and RX.
rfnoc_nullsource_ce_rx[.cpp] No n/a RFNoC Demonstrates use of the RFNoC Null Source/Sink block to generate and stream test data to the host.
Utilities
benchmark_rate[.cpp] Yes TX/RX Multi-USRP Benchmark streaming performance for complex baseband samples (IQ) on transmit and/or receive channels at a user-specified rate.
latency_test[.cpp] No TX/RX Multi-USRP Measures and verifies whether the system can reliably achieve a user-specified round-trip latency for transmitting and receiving complex baseband samples (IQ) with USRP devices.
test_clock_synch[.cpp] No n/a Multi-USRP Tests synchronizing time across multiple USRPs using a clock device (e.g., OctoClock).
test_dboard_coercion[.cpp] No n/a Multi-USRP Sweeps daughterboard frequency/gain ranges to verify tuning across all supported values.
test_pps_input[.cpp] No n/a Multi-USRP Tests if the USRP's PPS (pulse-per-second) input signal is detected and working.
usrp_list_sensors[.cpp] No n/a Multi-USRP Lists all available USRP device, motherboard, and channel sensors and prints their values.
Python Examples
rx_spectrum_to_asciiplot.py No RX Multi-USRP Continuously receives complex baseband samples (IQ) from a USRP device and displays an ASCII-art DFT spectrum in the terminal (using curses).
rx_spectrum_to_pyplot.py No RX Multi-USRP Continuously receives complex baseband samples (IQ) from a USRP device and displays an ASCII-art DFT spectrum (using matplotlib).
rx_to_file.py Yes RX Multi-USRP RFNoC Receive complex baseband samples (IQ) from USRP device(s) and save them to binary file(s). Supports RX streaming from host using Multi-USRP API as well as recording using RFNoC Replay block using RFNoC API.
rx_to_remote_udp.py Yes RX Multi-USRP Stream received complex baseband samples (IQ) from USRP channels/device(s) and forward them to remote UDP socket(s).
tx_waveforms.py Yes TX Multi-USRP RFNoC Transmit complex baseband samples (IQ) of generated waveforms (sine, square, ramp, constant) via USRP device(s). Supports TX streaming from host using Multi-USRP API as well as using RFNoC Replay block using RFNoC API.
rfnoc_rx_replay_samples_to_file.py Yes RX RFNoC Capture complex baseband samples (IQ) from one or more channels of a USRP device into a Replay block, then stream them to host and write them to binary file(s).
rfnoc_rx_to_file.py Yes RX RFNoC Receive complex baseband samples (IQ) from USRP device(s) and write them to binary file(s).
rfnoc_txrx_fft_block_loopback.py No TX/RX RFNoC Demonstrates how to send and receive FFT frames using the RFNoC FFT block.
x440_L_band_capture.py No RX RFNoC Demonstrates simultaneous capture of complex baseband samples (IQ) at different rates, frequencies and master clock rates to display a wideband PSD for the L-Band.
Feature Examples
usrp_power_meter.py No n/a Multi-USRP Measure the received signal power in dBm at a specified center frequency using a power calibrated USRP device.
Utilities
benchmark_rate.py Yes TX/RX Multi-USRP Benchmark streaming performance for complex baseband samples (IQ) on transmit and/or receive channels at a user-specified rate.
C Examples
Example Filename Multiple Channel Support TX/RX Description
rx_samples_c[.c] No RX Receive complex baseband samples (IQ) from a USRP device and save them to a binary file.
tx_samples_c[.c] No TX Transmit complex baseband samples (IQ) for transmission via a USRP device.
