property_tree.hpp
2 // Copyright 2011,2014-2016 Ettus Research
4 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6 // SPDX-License-Identifier: GPL-3.0-or-later
7 //
8
9 #pragma once
10
11 #include <uhd/config.hpp>
13 #include <cstddef>
14 #include <functional>
15 #include <memory>
16 #include <string>
17 #include <vector>
18
19 namespace uhd {
26 {
27 public:
28  virtual ~property_iface() = default;
29 };
30
78 template <typename T>
80 {
81 public:
82  typedef std::function<void(const T&)> subscriber_type;
83  typedef std::function<T(void)> publisher_type;
84  typedef std::function<T(const T&)> coercer_type;
85
86  virtual ~property(void) = 0;
87
98  virtual property<T>& set_coercer(const coercer_type& coercer) = 0;
99
110  virtual property<T>& set_publisher(const publisher_type& publisher) = 0;
111
121  virtual property<T>& add_desired_subscriber(const subscriber_type& subscriber) = 0;
122
132  virtual property<T>& add_coerced_subscriber(const subscriber_type& subscriber) = 0;
133
140  virtual property<T>& update(void) = 0;
141
154  virtual property<T>& set(const T& value) = 0;
155
167  virtual property<T>& set_coerced(const T& value) = 0;
168
177  virtual const T get(void) const = 0;
178
185  virtual const T get_desired(void) const = 0;
186
193  virtual bool empty(void) const = 0;
194 };
195
196 template <typename T>
198 {
199  /* NOP */
200 }
201
206 struct UHD_API_HEADER fs_path : std::string
207 {
209  UHD_API fs_path(const char*);
210  UHD_API fs_path(const std::string&);
211  UHD_API std::string leaf(void) const;
213 };
214
217
222 {
223 public:
224  typedef std::shared_ptr<property_tree> sptr;
225
226  enum coerce_mode_t { AUTO_COERCE, MANUAL_COERCE };
227
228  virtual ~property_tree(void) = 0;
229
231  static sptr make(void);
232
234  virtual sptr subtree(const fs_path& path) const = 0;
235
237  virtual void remove(const fs_path& path) = 0;
238
240  virtual bool exists(const fs_path& path) const = 0;
241
243  virtual std::vector<std::string> list(const fs_path& path) const = 0;
244
246  template <typename T>
247  property<T>& create(const fs_path& path, coerce_mode_t coerce_mode = AUTO_COERCE);
248
250  template <typename T>
251  property<T>& access(const fs_path& path);
252
254  template <typename T>
255  std::shared_ptr<property<T>> pop(const fs_path& path);
256
257 private:
259  virtual std::shared_ptr<property_iface> _pop(const fs_path& path) = 0;
260
262  virtual void _create(
263  const fs_path& path, const std::shared_ptr<property_iface>& prop) = 0;
264
266  virtual std::shared_ptr<property_iface>& _access(const fs_path& path) const = 0;
267 };
268
269 } // namespace uhd
270
271 #include <uhd/property_tree.ipp>
Definition: property_tree.hpp:26
virtual ~property_iface()=default
Definition: property_tree.hpp:222
Definition: property_tree.hpp:224
virtual std::vector< std::string > list(const fs_path &path) const =0
Get an iterable to all things in the given path.
virtual ~property_tree(void)=0
virtual void remove(const fs_path &path)=0
Remove a property or directory (recursive)
virtual sptr subtree(const fs_path &path) const =0
Get a subtree with a new root starting at path.
Create a new + empty property tree.
virtual bool exists(const fs_path &path) const =0
True if the path exists in the tree.
coerce_mode_t
Definition: property_tree.hpp:226
@ AUTO_COERCE
Definition: property_tree.hpp:80
virtual property< T > & set_publisher(const publisher_type &publisher)=0
std::function< T(void)> publisher_type
Definition: property_tree.hpp:83
virtual property< T > & add_desired_subscriber(const subscriber_type &subscriber)=0
virtual const T get_desired(void) const =0
virtual bool empty(void) const =0
virtual property< T > & add_coerced_subscriber(const subscriber_type &subscriber)=0
virtual property< T > & set_coercer(const coercer_type &coercer)=0
virtual ~property(void)=0
Definition: property_tree.hpp:197
std::function< T(const T &)> coercer_type
Definition: property_tree.hpp:84
virtual property< T > & set_coerced(const T &value)=0
std::function< void(const T &)> subscriber_type
Definition: property_tree.hpp:82
virtual property< T > & update(void)=0
virtual const T get(void) const =0
virtual property< T > & set(const T &value)=0
#define UHD_API_HEADER
Definition: config.h:88
Definition: config.h:87
Definition: build_info.hpp:12
UHD_API fs_path operator/(const fs_path &, const fs_path &)
Definition: property_tree.hpp:207
UHD_API fs_path(const char *)
UHD_API fs_path branch_path(void) const
UHD_API fs_path(void)
UHD_API fs_path(const std::string &)
