ranges.h
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.h>
11 #include <uhd/error.h>
12
13 #include <stdbool.h>
14 #include <stdlib.h>
15
17 typedef struct
18 {
20  double start;
22  double stop;
24  double step;
25 } uhd_range_t;
26
27 #ifdef __cplusplus
28 # include <uhd/types/ranges.hpp>
29 # include <string>
30
31 struct uhd_meta_range_t
32 {
33  uhd::meta_range_t meta_range_cpp;
34  std::string last_error;
35 };
36
37 extern "C" {
38 #else
39 struct uhd_meta_range_t;
40 #endif
41
43
46 typedef struct uhd_meta_range_t* uhd_meta_range_handle;
47
50  const uhd_range_t* range, char* pp_string_out, size_t strbuffer_len);
51
53
58
60
65
68
71
74
77  uhd_meta_range_handle h, double value, bool clip_step, double* result_out);
78
81
84  uhd_meta_range_handle h, const uhd_range_t* range);
85
88  uhd_meta_range_handle h, size_t num, uhd_range_t* range_out);
89
92  uhd_meta_range_handle h, char* pp_string_out, size_t strbuffer_len);
93
96  uhd_meta_range_handle h, char* error_out, size_t strbuffer_len);
97
98 #ifdef __cplusplus
99 }
100
101 UHD_API uhd::range_t uhd_range_c_to_cpp(const uhd_range_t* range_c);
102
103 UHD_API void uhd_range_cpp_to_c(const uhd::range_t& range_cpp, uhd_range_t* range_c);
104 #endif
Definition: ranges.hpp:23
Definition: config.h:87
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_meta_range_make(uhd_meta_range_handle *h)
Create a meta range handle.
UHD_API uhd_error uhd_meta_range_to_pp_string(uhd_meta_range_handle h, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given meta range.
UHD_API uhd_error uhd_meta_range_free(uhd_meta_range_handle *h)
Destroy a meta range handle.
UHD_API uhd_error uhd_meta_range_start(uhd_meta_range_handle h, double *start_out)
Get the overall start value for the given meta range.
UHD_API uhd_error uhd_meta_range_at(uhd_meta_range_handle h, size_t num, uhd_range_t *range_out)
Get the range at the given index.
UHD_API uhd_error uhd_meta_range_clip(uhd_meta_range_handle h, double value, bool clip_step, double *result_out)
Clip the given value to a possible value in the given range.
UHD_API uhd_error uhd_meta_range_stop(uhd_meta_range_handle h, double *stop_out)
Get the overall stop value for the given meta range.
UHD_API uhd_error uhd_meta_range_last_error(uhd_meta_range_handle h, char *error_out, size_t strbuffer_len)
Get the last error recorded by the underlying meta range.
UHD_API uhd_error uhd_meta_range_push_back(uhd_meta_range_handle h, const uhd_range_t *range)
Add a range to the given meta range.
UHD_API uhd_error uhd_range_to_pp_string(const uhd_range_t *range, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given range.
Definition: ranges.h:46
UHD_API uhd_error uhd_meta_range_size(uhd_meta_range_handle h, size_t *size_out)
Get the number of ranges in the given meta range.
UHD_API uhd_error uhd_meta_range_step(uhd_meta_range_handle h, double *step_out)
Get the overall step value for the given meta range.
Definition: ranges.hpp:67
Range of floating-point values.
Definition: ranges.h:18
double stop
Last value.
Definition: ranges.h:22
double start
First value.
Definition: ranges.h:20
double step
Granularity.
Definition: ranges.h:24
