serial.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
11 #include <cstddef>
12 #include <cstdint>
13 #include <memory>
14 #include <string>
15 #include <vector>
16
17 namespace uhd {
18
22 typedef std::vector<uint8_t> byte_vector_t;
23
37 {
38 public:
39  typedef std::shared_ptr<i2c_iface> sptr;
40
41  virtual ~i2c_iface(void);
42
45
51  virtual void write_i2c(uint16_t addr, const byte_vector_t& buf) = 0;
52
59  virtual byte_vector_t read_i2c(uint16_t addr, size_t num_bytes) = 0;
60
67  virtual void write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t& buf);
68
76  virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset, size_t num_bytes);
77 };
78
84 {
89  enum edge_t : uint32_t { EDGE_RISE = 'r', EDGE_FALL = 'f' };
90
93
96
99
101  size_t divider;
102
107  spi_config_t(edge_t edge = EDGE_RISE);
108
114  spi_config_t(edge_t edge, size_t divider);
115 };
116
123 {
124 public:
125  typedef std::shared_ptr<spi_iface> sptr;
126
127  virtual ~spi_iface(void);
128
138  virtual uint32_t transact_spi(int which_slave,
139  const spi_config_t& config,
140  uint32_t data,
141  size_t num_bits,
142  bool readback) = 0;
143
152  virtual uint32_t read_spi(
153  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
154
162  virtual void write_spi(
163  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
164 };
165
170 {
171 public:
172  typedef std::shared_ptr<uart_iface> sptr;
173
174  virtual ~uart_iface(void);
175
180  virtual void write_uart(const std::string& buf) = 0;
181
187  virtual std::string read_uart(double timeout) = 0;
188 };
189
190 } // namespace uhd
Definition: serial.hpp:37
virtual byte_vector_t read_i2c(uint16_t addr, size_t num_bytes)=0
virtual void write_i2c(uint16_t addr, const byte_vector_t &buf)=0
i2c_iface::sptr eeprom16(void)
Create an i2c_iface than can talk to 16 bit addressable EEPROMS.
std::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:39
virtual void write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t &buf)
Definition: serial.hpp:123
std::shared_ptr< spi_iface > sptr
Definition: serial.hpp:125
virtual uint32_t transact_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits, bool readback)=0
virtual uint32_t read_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
virtual void write_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
Definition: serial.hpp:170
virtual void write_uart(const std::string &buf)=0
virtual std::string read_uart(double timeout)=0
std::shared_ptr< uart_iface > sptr
Definition: serial.hpp:172
Definition: config.h:87
Definition: build_info.hpp:12
Definition: byte_vector.hpp:21
Definition: serial.hpp:84
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:95
edge_t
Definition: serial.hpp:89
spi_config_t(edge_t edge=EDGE_RISE)
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:98
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:92
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:101
