udp_zero_copy.hpp
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
13 #include <memory>
14
15 namespace uhd { namespace transport {
16
27 class UHD_API udp_zero_copy : public virtual zero_copy_if
28 {
29 public:
30  struct buff_params
31  {
34  };
35
36  typedef std::shared_ptr<udp_zero_copy> sptr;
37
54  static sptr make(const std::string& addr,
55  const std::string& port,
56  const zero_copy_xport_params& default_buff_args,
57  udp_zero_copy::buff_params& buff_params_out,
58  const device_addr_t& hints = device_addr_t());
59
66  virtual uint16_t get_local_port(void) const = 0;
67
73  virtual std::string get_local_addr(void) const = 0;
74 };
75
76 }} // namespace uhd::transport
Definition: device_addr.hpp:39
Definition: udp_zero_copy.hpp:28
static sptr make(const std::string &addr, const std::string &port, const zero_copy_xport_params &default_buff_args, udp_zero_copy::buff_params &buff_params_out, const device_addr_t &hints=device_addr_t())
virtual uint16_t get_local_port(void) const =0
std::shared_ptr< udp_zero_copy > sptr
Definition: udp_zero_copy.hpp:36
virtual std::string get_local_addr(void) const =0
Definition: zero_copy.hpp:147
Definition: config.h:87
Definition: build_info.hpp:12
Definition: udp_zero_copy.hpp:31
size_t send_buff_size
Definition: udp_zero_copy.hpp:33
size_t recv_buff_size
Definition: udp_zero_copy.hpp:32
Definition: zero_copy.hpp:123
