#include <uhd/rfnoc/graph.hpp>
◆ connect() [1/2]
          | virtual void uhd::rfnoc::graph::connect  |
          const block_id_t &  |
          src_block,  |
          size_t  |
          src_block_port,  |
          dst_block,  |
          size_t  |
          dst_block_port,  |
          const size_t  |
          pkt_size = 0  |
pure virtual   |
Connect a RFNOC block with block ID src_block to another with block ID dst_block.
This will:
- Check if this connection is valid (IO signatures, see if types match)
- Configure the flow control for the blocks
- Configure SID for the upstream block
- Register the upstream block in the downstream block
◆ connect() [2/2]
          src_block,  |
          dst_block  |
pure virtual   |
Shorthand for connect().
Using default ports for both source and destination.
◆ get_name()
          | virtual std::string uhd::rfnoc::graph::get_name  |
           const |
pure virtual   |
