#include <uhd/rfnoc/node_ctrl_base.hpp>
| virtual std::string | unique_id () const |
| | Returns a unique string that identifies this block. More...
| virtual void | clear () |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| template<typename T > |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node () |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node () |
| template<typename T , typename value_type > |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
◆ node_map_pair_t
◆ node_map_t
◆ sptr
◆ wptr
◆ node_ctrl_base()
| uhd::rfnoc::node_ctrl_base::node_ctrl_base |
void |
inlineprotected |
◆ ~node_ctrl_base()
| virtual uhd::rfnoc::node_ctrl_base::~node_ctrl_base |
inlineprotectedvirtual |
◆ _register_downstream_node()
| virtual void uhd::rfnoc::node_ctrl_base::_register_downstream_node |
node_ctrl_base::sptr |
downstream_node, |
size_t |
port |
protectedvirtual |
Registers another node as downstream of this node, connected to a given port.
This implies that this node is a source node, and the downstream node is a sink node. See also uhd::rfnoc::source_node_ctrl::_register_downstream_node().
◆ _register_upstream_node()
| virtual void uhd::rfnoc::node_ctrl_base::_register_upstream_node |
upstream_node, |
size_t |
port |
protectedvirtual |
Registers another node as upstream of this node, connected to a given port.
This implies that this node is a sink node, and the upstream node is a source node. See also uhd::rfnoc::sink_node_ctrl::_register_upstream_node().
◆ clear()
| virtual void uhd::rfnoc::node_ctrl_base::clear |
virtual |
Clears the list of connected nodes.
◆ find_downstream_node()
| UHD_INLINE std::vector< boost::shared_ptr<T> > uhd::rfnoc::node_ctrl_base::find_downstream_node |
inline |
Find nodes downstream that match a predicate.
Uses a non-recursive breadth-first search algorithm. On every branch, the search stops if a block matches. See this example:
A -> B -> C -> C
Say node A searches for nodes of type C. It will only find the first 'C' block, not the second.
Returns blocks that are of type T.
Search only goes downstream.
◆ find_downstream_unique_property()
| UHD_INLINE value_type uhd::rfnoc::node_ctrl_base::find_downstream_unique_property |
boost::function< value_type(boost::shared_ptr< T > node, size_t port)> |
get_property, |
value_type |
null_value, |
const std::set< boost::shared_ptr< T > > & |
exclude_nodes = std::set< boost::shared_ptr<T> >() |
inline |
Checks if downstream nodes share a common, unique property.
This will use find_downstream_node() to find all nodes downstream of this that are of type T. Then it will use get_property to return a property from all of them. If all these properties are identical, it will return that property. Otherwise, it will throw a uhd::runtime_error.
get_property A functor to return the property from a node null_value If get_property returns this value, that node is skipped. explored_nodes A list of nodes to exclude from the search. This is typically to avoid recursion loops.
◆ find_upstream_node()
| UHD_INLINE std::vector< boost::shared_ptr<T> > uhd::rfnoc::node_ctrl_base::find_upstream_node |
inline |
◆ find_upstream_unique_property()
| UHD_INLINE value_type uhd::rfnoc::node_ctrl_base::find_upstream_unique_property |
get_property, |
value_type |
null_value, |
inline |
◆ get_downstream_port()
| size_t uhd::rfnoc::node_ctrl_base::get_downstream_port |
const size_t |
this_port | ) |
Return the remote port of a connection on a given port.
- Exceptions
◆ get_upstream_port()
| size_t uhd::rfnoc::node_ctrl_base::get_upstream_port |
const size_t |
this_port | ) |
- Exceptions
◆ list_downstream_nodes()
| node_map_t uhd::rfnoc::node_ctrl_base::list_downstream_nodes |
inline |
◆ list_upstream_nodes()
| node_map_t uhd::rfnoc::node_ctrl_base::list_upstream_nodes |
inline |
◆ set_downstream_port()
| void uhd::rfnoc::node_ctrl_base::set_downstream_port |
const size_t |
this_port, |
const size_t |
remote_port |
For an existing connection, store the remote port number.
- Exceptions
◆ set_upstream_port()
| void uhd::rfnoc::node_ctrl_base::set_upstream_port |
const size_t |
this_port, |
const size_t |
remote_port |
- Exceptions
◆ unique_id()
| virtual std::string uhd::rfnoc::node_ctrl_base::unique_id |
const |
virtual |
◆ _args
Stores default arguments.
◆ _downstream_nodes
| node_map_t uhd::rfnoc::node_ctrl_base::_downstream_nodes |
protected |
List of downstream nodes.
◆ _upstream_nodes
| node_map_t uhd::rfnoc::node_ctrl_base::_upstream_nodes |
protected |
