| virtual size_t uhd::rx_streamer::recv |
const buffs_type & |
buffs, |
const size_t |
nsamps_per_buff, |
rx_metadata_t & |
metadata, |
const double |
timeout = 0.1, |
const bool |
one_packet = false |
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
- Parameters
| buffs | a vector of writable memory to fill with samples |
| nsamps_per_buff | the size of each buffer in number of samples |
| metadata | data to fill describing the buffer |
| timeout | the timeout in seconds to wait for a packet |
| one_packet | return after the first packet is received |
- Returns
- the number of samples received or 0 on error
