#include <uhd/transport/udp_simple.hpp>
| virtual  | ~udp_simple (void)=0 |
| virtual size_t  | send (const boost::asio::const_buffer &buff)=0 |
| virtual size_t  | recv (const boost::asio::mutable_buffer &buff, double timeout=0.1)=0 |
| virtual std::string  | get_recv_addr (void)=0 |
| static const size_t  | mtu = 1500 - 20 - 8 |
|   | The maximum number of bytes per udp packet.  More...
◆ ~udp_simple()
          | virtual uhd::transport::udp_simple::~udp_simple  |
          void  |
pure virtual   |
◆ get_recv_addr()
          | virtual std::string uhd::transport::udp_simple::get_recv_addr  |
          void  |
pure virtual   |
◆ make_broadcast()
          | static sptr uhd::transport::udp_simple::make_broadcast  |
          const std::string &  |
          addr,  |
          port  |
static   |
- Parameters
    | addr | a string representing the destination address  |
    | port | a string representing the destination port  |
◆ make_connected()
          | static sptr uhd::transport::udp_simple::make_connected  |
          addr,  |
          port  |
static   |
- Parameters
◆ make_uart()
- Parameters
    | udp | the UDP transport object  |
- Returns
 - a new UART interface
◆ recv()
          | virtual size_t uhd::transport::udp_simple::recv  |
          const boost::asio::mutable_buffer &  |
          buff,  |
          double  |
          timeout = 0.1  |
pure virtual   |
- Parameters
    | buff | a mutable buffer to receive into  |
    | timeout | the timeout in seconds  |
- Returns
 - the number of bytes received or zero on timeout
◆ send()
          | virtual size_t uhd::transport::udp_simple::send  |
          const boost::asio::const_buffer &  |
          buff | ) |
pure virtual   |
- Parameters
- Returns
 - the number of bytes sent
◆ mtu
          | const size_t uhd::transport::udp_simple::mtu = 1500 - 20 - 8 |
static   |
