#include <uhd/transport/usb_device_handle.hpp>
Public Types | |
| typedef boost::shared_ptr< usb_device_handle > | sptr |
| typedef std::pair< boost::uint16_t, boost::uint16_t > | vid_pid_pair_t |
| virtual | ~usb_device_handle (void) |
| virtual std::string | get_serial () const =0 |
| virtual std::string | get_manufacturer () const =0 |
| virtual std::string | get_product () const =0 |
| virtual boost::uint16_t | get_vendor_id () const =0 |
| virtual boost::uint16_t | get_product_id () const =0 |
| virtual bool | firmware_loaded ()=0 |
| static std::vector< usb_device_handle::sptr > | get_device_list (boost::uint16_t vid, boost::uint16_t pid) |
| static std::vector< usb_device_handle::sptr > | get_device_list (const std::vector< usb_device_handle::vid_pid_pair_t > &vid_pid_pair_list) |
Device handle class that represents a USB device Used for identifying devices on the USB bus and selecting which device is used when creating a USB transport. A minimal subset of USB descriptor fields are used. Fields can be found in the USB 2.0 specification Table 9-8 (Standard Device Descriptor). In addition to fields of the device descriptor, the interface returns the device's USB device address.
Note: The USB 2.0 Standard Device Descriptor contains an index rather then a true descriptor serial number string. This interface returns the actual string descriptor.
| typedef boost::shared_ptr<usb_device_handle> uhd::transport::usb_device_handle::sptr |
| typedef std::pair<boost::uint16_t, boost::uint16_t> uhd::transport::usb_device_handle::vid_pid_pair_t |
virtual |
Test whether the firmware is loaded on the device.
Return a vector of USB devices on this host
Return the device's manufacturer identification string
Return the device's product identification string
Return the device's Product ID (usually assigned by manufacturer)
Return the device's serial number
Return the device's Vendor ID (usually assigned by the USB-IF)
