Public Types | |
enum | unit_t { UNIT_RX = int('r'), UNIT_TX = int('t'), UNIT_BOTH = int('b') } |
tells the host which unit to use More... | |
enum | aux_dac_t { AUX_DAC_A = int('a'), AUX_DAC_B = int('b'), AUX_DAC_C = int('c'), AUX_DAC_D = int('d') } |
aux dac selection enums (per unit) More... | |
enum | aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') } |
aux adc selection enums (per unit) More... | |
typedef boost::shared_ptr< dboard_iface > | sptr |
typedef dboard_iface_special_props_t | special_props_t |
typedef uhd::usrp::gpio_atr::gpio_atr_reg_t | atr_reg_t |
typedef boost::shared_ptr< i2c_iface > | sptr |
virtual | ~dboard_iface (void) |
virtual special_props_t | get_special_props (void)=0 |
virtual void | write_aux_dac (unit_t unit, aux_dac_t which_dac, double value)=0 |
virtual double | read_aux_adc (unit_t unit, aux_adc_t which_adc)=0 |
virtual void | set_pin_ctrl (unit_t unit, boost::uint32_t value, boost::uint32_t mask=0xffff)=0 |
virtual boost::uint32_t | get_pin_ctrl (unit_t unit)=0 |
virtual void | set_atr_reg (unit_t unit, atr_reg_t reg, boost::uint32_t value, boost::uint32_t mask=0xffff)=0 |
virtual boost::uint32_t | get_atr_reg (unit_t unit, atr_reg_t reg)=0 |
virtual void | set_gpio_ddr (unit_t unit, boost::uint32_t value, boost::uint32_t mask=0xffff)=0 |
virtual boost::uint32_t | get_gpio_ddr (unit_t unit)=0 |
virtual void | set_gpio_out (unit_t unit, boost::uint32_t value, boost::uint32_t mask=0xffff)=0 |
virtual boost::uint32_t | get_gpio_out (unit_t unit)=0 |
virtual boost::uint32_t | read_gpio (unit_t unit)=0 |
virtual void | write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 |
virtual boost::uint32_t | read_write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 |
virtual void | set_clock_rate (unit_t unit, double rate)=0 |
virtual double | get_clock_rate (unit_t unit)=0 |
virtual std::vector< double > | get_clock_rates (unit_t unit)=0 |
virtual void | set_clock_enabled (unit_t unit, bool enb)=0 |
virtual double | get_codec_rate (unit_t unit)=0 |
virtual void | set_fe_connection (unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0 |
virtual uhd::time_spec_t | get_command_time (void)=0 |
virtual void | set_command_time (const uhd::time_spec_t &t)=0 |
virtual void | sleep (const boost::chrono::nanoseconds &time) |
virtual | ~i2c_iface (void) |
i2c_iface::sptr | eeprom16 (void) |
Create an i2c_iface than can talk to 16 bit addressable EEPROMS. More... | |
virtual void | write_i2c (boost::uint16_t addr, const byte_vector_t &buf)=0 |
virtual byte_vector_t | read_i2c (boost::uint16_t addr, size_t num_bytes)=0 |
virtual void | write_eeprom (boost::uint16_t addr, boost::uint16_t offset, const byte_vector_t &buf) |
virtual byte_vector_t | read_eeprom (boost::uint16_t addr, boost::uint16_t offset, size_t num_bytes) |
typedef boost::shared_ptr<dboard_iface> uhd::usrp::dboard_iface::sptr |
inlinevirtual |
unit | which unit rx or tx |
reg | which ATR register |
Get the command time.
Read from an aux adc.
which_adc | the adc index 0, 1, 2, 3... |
unit | which unit, rx or tx |
config | configuration settings |
data | the bits to write MSB first |
num_bits | the number of bits in data |
value | 16-bits, 0=ATR output low, 1=ATR output high |
mask | 16-bits, 0=do not change, 1=change value |
enb | true for enabled |
rate | the clock rate in Hz |
Set the command time.
t | the time |
Configure the front-end connection parameters.
fe_name | name of the front-end to update |
fe_conn | connection parameters class |
value | 16-bits, 0=GPIO input, 1=GPIO output |
value | 16-bits, 0=GPIO output low, 1=GPIO output high |
value | 16-bits, 0=GPIO controlled, 1=ATR controlled |
virtual |
Sleep for a set time
time | time to sleep in nanoseconds |
Write to an aux dac.
which_dac | the dac index 0, 1, 2, 3... |
value | the value in volts |
