Typedefs | |
| typedef struct uhd_dboard_eeprom_t * | uhd_dboard_eeprom_handle |
| A C-level interface for interacting with a daughterboard EEPROM.  More... | |
Functions | |
| UHD_API uhd_error | uhd_dboard_eeprom_make (uhd_dboard_eeprom_handle *h) |
| Create handle for a USRP daughterboard EEPROM.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_free (uhd_dboard_eeprom_handle *h) |
| Safely destroy the given handle.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_get_id (uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len) |
| Get the ID associated with the given daughterboard as a string hex representation.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_set_id (uhd_dboard_eeprom_handle h, const char *id) |
| Set the daughterboard ID using a string hex representation.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_get_serial (uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len) |
| Get the daughterboard's serial.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_set_serial (uhd_dboard_eeprom_handle h, const char *serial) |
| Set the daughterboard's serial.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_get_revision (uhd_dboard_eeprom_handle h, int *revision_out) |
| Get the daughterboard's revision (not always present)  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_set_revision (uhd_dboard_eeprom_handle h, int revision) |
| Set the daughterboard's revision.  More... | |
| UHD_API uhd_error | uhd_dboard_eeprom_last_error (uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len) |
| Get the last error reported by the handle.  More... | |
| typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle |
See uhd::usrp::dboard_eeprom_t for more details.
NOTE: Using a handle before passing it into uhd_dboard_eeprom_make() will result in undefined behavior.
| UHD_API uhd_error uhd_dboard_eeprom_free | ( | uhd_dboard_eeprom_handle * | h | ) |
| UHD_API uhd_error uhd_dboard_eeprom_get_id | ( | uhd_dboard_eeprom_handle | h, |
| char * | id_out, | ||
| size_t | strbuffer_len | ||
| UHD_API uhd_error uhd_dboard_eeprom_get_revision | ( | uhd_dboard_eeprom_handle | h, |
| int * | revision_out | ||
| UHD_API uhd_error uhd_dboard_eeprom_get_serial | ( | uhd_dboard_eeprom_handle | h, |
| char * | serial_out, | ||
| UHD_API uhd_error uhd_dboard_eeprom_last_error | ( | uhd_dboard_eeprom_handle | h, |
| char * | error_out, | ||
| UHD_API uhd_error uhd_dboard_eeprom_make | ( | uhd_dboard_eeprom_handle * | h | ) |
| UHD_API uhd_error uhd_dboard_eeprom_set_id | ( | uhd_dboard_eeprom_handle | h, |
| const char * | id | ||
| UHD_API uhd_error uhd_dboard_eeprom_set_revision | ( | uhd_dboard_eeprom_handle | h, |
| int | revision | ||
| UHD_API uhd_error uhd_dboard_eeprom_set_serial | ( | uhd_dboard_eeprom_handle | h, |
| const char * | serial | ||
