radio_ctrl.hpp
2 // Copyright 2015-2016 Ettus Research LLC
18 #ifndef INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP
19 #define INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP
21 #include <uhd/types/direction.hpp>
28
29 namespace uhd {
30  namespace rfnoc {
31
36  public sink_block_ctrl_base,
37  public rate_node_ctrl,
38  public tick_node_ctrl,
40 {
41 public:
43
44  virtual ~radio_ctrl(){}
45
46  /************************************************************************
47  * API calls
48  ***********************************************************************/
53  virtual double get_rate() const = 0;
54
59  virtual double set_rate(double rate) = 0;
60
65  virtual std::string get_tx_antenna(const size_t chan) /* const */ = 0;
66
71  virtual void set_tx_antenna(const std::string &ant, const size_t chan) = 0;
72
77  virtual std::string get_rx_antenna(const size_t chan) /* const */ = 0;
78
83  virtual void set_rx_antenna(const std::string &ant, const size_t chan) = 0;
84
92  virtual double get_tx_frequency(const size_t chan) /* const */ = 0;
93
104  virtual double set_tx_frequency(const double freq, size_t chan) = 0;
105
110  virtual double get_rx_frequency(const size_t chan) /* const */ = 0;
111
119  virtual double set_rx_frequency(const double freq, const size_t chan) = 0;
120
125  virtual double get_tx_gain(const size_t chan) = 0;
126
134  virtual double set_tx_gain(const double gain, const size_t chan) = 0;
135
140  virtual double get_rx_gain(const size_t chan) = 0;
141
149  virtual double set_rx_gain(const double gain, const size_t chan) = 0;
150
158  virtual void set_time_now(const time_spec_t &time_spec) = 0;
159
171  virtual void set_time_next_pps(const time_spec_t &time_spec) = 0;
172
181  virtual time_spec_t get_time_now() = 0;
182
187  virtual time_spec_t get_time_last_pps() = 0;
188
195  virtual size_t get_chan_from_dboard_fe(const std::string &fe, const uhd::direction_t dir) = 0;
196
199  virtual std::string get_dboard_fe_from_chan(const size_t chan, const uhd::direction_t dir) = 0;
200
201 }; /* class radio_ctrl */
202
203 }} /* namespace uhd::rfnoc */
204
205 #endif /* INCLUDED_LIBUHD_RFNOC_RADIO_CTRL_HPP */
Definition: terminator_node_ctrl.hpp:40
#define UHD_RFNOC_BLOCK_OBJECT(class_name)
This macro must be put in the public section of an RFNoC.
Definition: block_ctrl_base.hpp:74
Definition: sink_block_ctrl_base.hpp:36
Definition: time_spec.hpp:39
Definition: rate_node_ctrl.hpp:38
Block controller for all RFNoC-based radio blocks.
Definition: radio_ctrl.hpp:34
Definition: build_info.hpp:25
Definition: tick_node_ctrl.hpp:35
#define UHD_RFNOC_API
Definition: config.hpp:103
Definition: source_block_ctrl_base.hpp:35
direction_t
Definition: direction.hpp:23
