#include <uhd/rfnoc/source_block_ctrl_base.hpp>
Public Types | |
| typedef boost::shared_ptr< source_block_ctrl_base > | sptr |
Public Types inherited from uhd::rfnoc::block_ctrl_base | |
| typedef boost::shared_ptr< block_ctrl_base > | sptr |
| typedef boost::function< sptr(const make_args_t &)> | make_t |
Public Types inherited from uhd::rfnoc::node_ctrl_base | |
| typedef boost::shared_ptr< node_ctrl_base > | sptr |
| typedef boost::weak_ptr< node_ctrl_base > | wptr |
| typedef std::map< size_t, wptr > | node_map_t |
| typedef std::pair< size_t, wptr > | node_map_pair_t |
Public Types inherited from uhd::rfnoc::source_node_ctrl | |
| typedef boost::shared_ptr< source_node_ctrl > | sptr |
| typedef std::map< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_t |
| typedef std::pair< size_t, boost::weak_ptr< source_node_ctrl > > | node_map_pair_t |
| virtual void | issue_stream_cmd (const uhd::stream_cmd_t &stream_cmd, const size_t chan=0) |
| stream_sig_t | get_output_signature (size_t block_port=0) const |
| std::vector< size_t > | get_output_ports () const |
| virtual void | set_destination (boost::uint32_t next_address, size_t output_block_port=0) |
| virtual void | configure_flow_control_out (size_t buf_size_pkts, size_t block_port=0, const uhd::sid_t &sid=uhd::sid_t()) |
Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| boost::uint32_t | get_address (size_t block_port=0) |
| block_id_t | get_block_id () const |
| std::string | unique_id () const |
| std::vector< size_t > | get_ctrl_ports () const |
| void | sr_write (const boost::uint32_t reg, const boost::uint32_t data, const size_t port=0) |
| void | sr_write (const std::string ®, const boost::uint32_t data, const size_t port=0) |
| boost::uint64_t | sr_read64 (const settingsbus_reg_t reg, const size_t port=0) |
| boost::uint32_t | sr_read32 (const settingsbus_reg_t reg, const size_t port=0) |
| boost::uint64_t | user_reg_read64 (const boost::uint32_t addr, const size_t port=0) |
| boost::uint64_t | user_reg_read64 (const std::string ®, const size_t port=0) |
| boost::uint32_t | user_reg_read32 (const boost::uint32_t addr, const size_t port=0) |
| boost::uint32_t | user_reg_read32 (const std::string ®, const size_t port=0) |
| void | set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| time_spec_t | get_command_time (const size_t port=0) |
| void | set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT) |
| void | clear_command_time (const size_t port) |
| void | clear (const size_t port=0) |
| void | set_args (const uhd::device_addr_t &args, const size_t port=0) |
| void | set_arg (const std::string &key, const std::string &val, const size_t port=0) |
Set a specific block argument. val is converted to the corresponding. More... | |
| template<typename T > | |
| void | set_arg (const std::string &key, const T &val, const size_t port=0) |
| Direct access to set a block argument. More... | |
| uhd::device_addr_t | get_args (const size_t port=0) const |
| Return all block arguments as a device_addr_t. More... | |
| std::string | get_arg (const std::string &key, const size_t port=0) const |
| Return a single block argument in string format. More... | |
| T | get_arg (const std::string &key, const size_t port=0) const |
| Direct access to get a block argument. More... | |
| std::string | get_arg_type (const std::string &key, const size_t port=0) const |
Public Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| virtual void | clear () |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node () |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node () |
| template<typename T , typename value_type > | |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
Public Member Functions inherited from uhd::rfnoc::source_node_ctrl | |
| size_t | connect_downstream (node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t()) |
| virtual void | set_rx_streamer (bool active, const size_t port) |
Protected Member Functions | |
| virtual size_t | _request_output_port (const size_t suggested_port, const uhd::device_addr_t &args) const |
Protected Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| block_ctrl_base (void) | |
| virtual | ~block_ctrl_base () |
| block_ctrl_base (const make_args_t &make_args) | |
| stream_sig_t | _resolve_port_def (const blockdef::port_t &port_def) const |
| uhd::fs_path | get_arg_path (const std::string &key, size_t port=0) const |
Return the property tree path to a block argument key on port. More... | |
| wb_iface::sptr | get_ctrl_iface (const size_t block_port) |
Get a control interface object for block port block_port. More... | |
| virtual void | _clear (const size_t port=0) |
| Override this function if your block does something else. More... | |
Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_ctrl_base (void) | |
| virtual | ~node_ctrl_base () |
| virtual void | _register_upstream_node (node_ctrl_base::sptr upstream_node, size_t port) |
Static Public Member Functions inherited from uhd::rfnoc::block_ctrl_base | |
| static void | register_block (const make_t &make, const std::string &name) |
| static sptr | make (const make_args_t &make_args, boost::uint64_t noc_id=~0) |
| Create a block controller class given a NoC-ID or a block name. More... | |
Protected Attributes inherited from uhd::rfnoc::block_ctrl_base | |
| uhd::property_tree::sptr | _tree |
| Property sub-tree. More... | |
| uhd::fs_path | _root_path |
| Root node of this block's properties. More... | |
| bool | _transport_is_big_endian |
| Endianness of underlying transport (for data transport) More... | |
| blockdef::sptr | _block_def |
| Block definition (stores info about the block such as ports) More... | |
Protected Attributes inherited from uhd::rfnoc::node_ctrl_base | |
| uhd::device_addr_t | _args |
| Stores default arguments. More... | |
| node_map_t | _upstream_nodes |
| List of upstream nodes. More... | |
| node_map_t | _downstream_nodes |
| List of downstream nodes. More... | |
Protected Attributes inherited from uhd::rfnoc::source_node_ctrl | |
| std::map< size_t, bool > | _rx_streamer_active |
| typedef boost::shared_ptr<source_block_ctrl_base> uhd::rfnoc::source_block_ctrl_base::sptr |
protectedvirtual |
Like source_node_ctrl::_request_output_port(), but also checks if the port has an output signature.
Reimplemented from uhd::rfnoc::source_node_ctrl.
virtual |
Configure flow control for outgoing streams.
In the default implementation, this just sets registers SR_FLOW_CTRL_BUF_SIZE and SR_FLOW_CTRL_ENABLE accordingly; block_port and sid are ignored.
Override this function if your block has port-specific flow control settings.
| buf_size_pkts | The size of the downstream block's input FIFO size in number of packets. Setting this to zero disables flow control. The block will then produce data as fast as it can. Warning: This can cause head-of-line blocking, and potentially lock up your device! |
| Specify | on which outgoing port this setting is valid. |
| sid | The SID for which this is valid. This is meant for cases where the outgoing block port is not sufficient to set the flow control, and as such is rarely used. |
| std::vector<size_t> uhd::rfnoc::source_block_ctrl_base::get_output_ports | ( | ) | const |
Return a list of valid output ports.
| stream_sig_t uhd::rfnoc::source_block_ctrl_base::get_output_signature | ( | size_t | block_port = 0 | ) | const |
Return the output stream signature for a given block port.
The actual signature is determined by the current configuration and the block definition file. The value returned here is calculated on-the-fly and is only valid as long as the configuration does not change.
block_port | uhd::runtime_error | if block_port is not a valid port |
virtual |
Issue a stream command for this block.
There is no guaranteed action for this command. The default implementation is to send this command to the next upstream block, or issue a warning if there is no upstream block registered.
However, implementations of block_ctrl_base might choose to do whatever seems appropriate, including throwing exceptions. This may also be true for some stream commands and not for others (i.e. STREAM_MODE_START_CONTINUOUS may be implemented, and STREAM_MODE_NUM_SAMPS_AND_DONE may be not).
This function does not check for infinite loops. Example: Say you have two blocks, which are both registered as upstream from one another. If they both use block_ctrl_base::issue_stream_cmd(), then the stream command will be passed from one block to another indefinitely. This will not happen if one the block's controller classes overrides this function and actually handles it.
See also register_upstream_block().
| stream_cmd | The stream command. |
Implements uhd::rfnoc::source_node_ctrl.
virtual |
Configures data flowing from port output_block_port to go to next_address
| next_address | Address of the downstream block |
| output_block_port | Port for which this is valid |
In the default implementation, this will write the value in next_address to register SR_NEXT_DST of this blocks settings bus. The value will also have bit 16 set to 1, since some blocks require this to respect this value.
