rate_node_ctrl.hpp
18 #ifndef INCLUDED_LIBUHD_RATE_NODE_CTRL_BASE_HPP
19 #define INCLUDED_LIBUHD_RATE_NODE_CTRL_BASE_HPP
22 #include <uhd/rfnoc/constants.hpp>
23
24 namespace uhd {
25  namespace rfnoc {
26
38 class rate_node_ctrl : virtual public node_ctrl_base
39 {
40 public:
41  /***********************************************************************
42  * Types
43  **********************************************************************/
44  typedef boost::shared_ptr<rate_node_ctrl> sptr;
46  static const double RATE_UNDEFINED;
47
48  /***********************************************************************
49  * Rate controls
50  **********************************************************************/
58  virtual double get_input_samp_rate(size_t port=ANY_PORT);
59  virtual double get_output_samp_rate(size_t port=ANY_PORT);
60
61 }; /* class rate_node_ctrl */
62
63 }} /* namespace uhd::rfnoc */
64
65 #endif /* INCLUDED_LIBUHD_RATE_NODE_CTRL_BASE_HPP */
66 // vim: sw=4 et:
67
Definition: rate_node_ctrl.hpp:38
Definition: build_info.hpp:25
#define UHD_RFNOC_API
Definition: config.hpp:103
boost::shared_ptr< rate_node_ctrl > sptr
Definition: rate_node_ctrl.hpp:44
This value is used by rate nodes that don&#39;t actually set a rate themselves.
Definition: rate_node_ctrl.hpp:46
Definition: node_ctrl_base.hpp:40
