source_node_ctrl.hpp
18 #ifndef INCLUDED_LIBUHD_SOURCE_NODE_CTRL_BASE_HPP
19 #define INCLUDED_LIBUHD_SOURCE_NODE_CTRL_BASE_HPP
22 #include <uhd/rfnoc/constants.hpp>
23 #include <uhd/types/stream_cmd.hpp>
24 #include <boost/thread.hpp>
25
26 namespace uhd {
27  namespace rfnoc {
28
34 class source_node_ctrl : virtual public node_ctrl_base
35 {
36 public:
37  /***********************************************************************
38  * Types
39  **********************************************************************/
40  typedef boost::shared_ptr<source_node_ctrl> sptr;
41  typedef std::map< size_t, boost::weak_ptr<source_node_ctrl> > node_map_t;
42  typedef std::pair< size_t, boost::weak_ptr<source_node_ctrl> > node_map_pair_t;
43
44  /***********************************************************************
45  * Source block controls
46  **********************************************************************/
51  virtual void issue_stream_cmd(
52  const uhd::stream_cmd_t &stream_cmd,
53  const size_t chan=0
54  ) = 0;
55
70  size_t connect_downstream(
71  node_ctrl_base::sptr downstream_node,
72  size_t port=ANY_PORT,
74  );
75
82  virtual void set_rx_streamer(bool active, const size_t port);
83
84 protected:
85
93  std::map<size_t, bool> _rx_streamer_active;
94
105  virtual size_t _request_output_port(
106  const size_t suggested_port,
107  const uhd::device_addr_t &args
108  ) const;
109
110
111 private:
114  boost::mutex _output_mutex;
115
126  void _register_downstream_node(
127  node_ctrl_base::sptr downstream_node,
128  size_t port
129  );
130
131 }; /* class source_node_ctrl */
132
133 }} /* namespace uhd::rfnoc */
134
135 #endif /* INCLUDED_LIBUHD_SOURCE_NODE_CTRL_BASE_HPP */
136 // vim: sw=4 et:
Definition: stream_cmd.hpp:46
std::pair< size_t, boost::weak_ptr< source_node_ctrl > > node_map_pair_t
Definition: source_node_ctrl.hpp:42
Definition: source_node_ctrl.hpp:34
boost::shared_ptr< source_node_ctrl > sptr
Definition: source_node_ctrl.hpp:40
virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t chan=0)=0
Definition: build_info.hpp:25
boost::shared_ptr< node_ctrl_base > sptr
Definition: node_ctrl_base.hpp:46
#define UHD_RFNOC_API
Definition: config.hpp:103
virtual size_t _request_output_port(const size_t suggested_port, const uhd::device_addr_t &args) const
size_t connect_downstream(node_ctrl_base::sptr downstream_node, size_t port=ANY_PORT, const uhd::device_addr_t &args=uhd::device_addr_t())
std::map< size_t, bool > _rx_streamer_active
Definition: source_node_ctrl.hpp:93
std::map< size_t, boost::weak_ptr< source_node_ctrl > > node_map_t
Definition: source_node_ctrl.hpp:41
Definition: node_ctrl_base.hpp:40
