stream_sig.hpp
2 // Copyright 2014-2015 Ettus Research LLC
18 #ifndef INCLUDED_LIBUHD_RFNOC_STREAMSIG_HPP
19 #define INCLUDED_LIBUHD_RFNOC_STREAMSIG_HPP
21 #include <iostream>
22 #include <uhd/config.hpp>
23
24 namespace uhd { namespace rfnoc {
25
34  public:
35  /***********************************************************************
36  * Structors
37  ***********************************************************************/
38  stream_sig_t();
39
40  /***********************************************************************
41  * The stream signature attributes
42  ***********************************************************************/
44  // to empty.
45  std::string item_type;
46
48  size_t vlen;
49
51  size_t packet_size;
52
53  bool is_bursty;
54
55  /***********************************************************************
56  * Helpers
57  ***********************************************************************/
59  std::string to_string();
61  std::string to_pp_string();
62
64  // Note: The vector length is *not* considered here.
65  //
66  // \returns Number of bytes per item or 0 if the item type is
67  // undefined.
68  // \throws uhd::key_error if the item type is invalid.
69  size_t get_bytes_per_item() const;
70
76  static bool is_compatible(const stream_sig_t &output_sig, const stream_sig_t &input_sig);
77 };
78
80 UHD_INLINE std::ostream& operator<< (std::ostream& out, stream_sig_t stream_sig) {
81  out << stream_sig.to_string().c_str();
82  return out;
83 }
84
85 }} /* namespace uhd::rfnoc */
86
87 #endif /* INCLUDED_LIBUHD_RFNOC_STREAMSIG_HPP */
88 // vim: sw=4 et:
Compact string representation.
UHD_API size_t get_bytes_per_item(const std::string &format)
Convert an item format to a size in bytes.
The data type of the individual items (e.g. &#39;sc16&#39;). If undefined, set.
Definition: stream_sig.hpp:45
size_t vlen
The vector length in multiples of items. If undefined, set to zero.
Definition: stream_sig.hpp:48
Definition: build_info.hpp:25
std::ostream & operator<<(std::ostream &out, block_id_t block_id)
Shortcut for << block_id.to_string()
Definition: block_id.hpp:203
#define UHD_RFNOC_API
Definition: config.hpp:103
#define UHD_INLINE
Definition: config.h:63
bool is_bursty
Definition: stream_sig.hpp:53
size_t packet_size
Packet size in bytes. If undefined, set to zero.
Definition: stream_sig.hpp:51
Definition: stream_sig.hpp:33
