uhd::rfnoc::stream_sig_t Class Reference
#include <uhd/rfnoc/stream_sig.hpp>
 stream_sig_t ()
std::string to_string ()
 Compact string representation. More...
std::string to_pp_string ()
 Pretty-print string representation. More...
size_t get_bytes_per_item () const
 Returns the number of bytes necessary to store one item. More...
static bool is_compatible (const stream_sig_t &output_sig, const stream_sig_t &input_sig)
Public Attributes
std::string item_type
 The data type of the individual items (e.g. 'sc16'). If undefined, set. More...
size_t vlen
 The vector length in multiples of items. If undefined, set to zero. More...
size_t packet_size
 Packet size in bytes. If undefined, set to zero. More...
bool is_bursty
Describes a stream signature for data going to or coming from RFNoC ports.
The stream signature may depend on a block's configuration. Even so, some attributes may be left undefined (e.g., a FIFO block works for any item type, so it doesn't need to set it).
◆ stream_sig_t()
uhd::rfnoc::stream_sig_t::stream_sig_t ( )
◆ get_bytes_per_item()
size_t uhd::rfnoc::stream_sig_t::get_bytes_per_item ( ) const
◆ is_compatible()
static bool uhd::rfnoc::stream_sig_t::is_compatible ( const stream_sig_t output_sig,
const stream_sig_t input_sig
Check if an output with signature output_sig could stream to an input signature input_sig.
true if streams are compatible
◆ to_pp_string()
std::string uhd::rfnoc::stream_sig_t::to_pp_string ( )
◆ to_string()
std::string uhd::rfnoc::stream_sig_t::to_string ( )
◆ is_bursty
bool uhd::rfnoc::stream_sig_t::is_bursty
◆ item_type
std::string uhd::rfnoc::stream_sig_t::item_type
◆ packet_size
size_t uhd::rfnoc::stream_sig_t::packet_size
◆ vlen
size_t uhd::rfnoc::stream_sig_t::vlen
