uhd::transport::vrt::if_packet_info_t Struct Reference
#include <uhd/transport/vrt_if_packet.hpp>
enum  link_type_t { LINK_TYPE_NONE = 0x0, LINK_TYPE_CHDR = 0x1, LINK_TYPE_VRLP = 0x2 }
enum  packet_type_t {
  PACKET_TYPE_DATA = 0x0, PACKET_TYPE_IF_EXT = 0x1, PACKET_TYPE_CONTEXT = 0x2, PACKET_TYPE_FC = 0x1,
  PACKET_TYPE_ACK = 0x1, PACKET_TYPE_CMD = 0x2, PACKET_TYPE_RESP = 0x3, PACKET_TYPE_ERROR = 0x3
 if_packet_info_t (void)
Public Attributes
enum uhd::transport::vrt::if_packet_info_t::link_type_t link_type
enum uhd::transport::vrt::if_packet_info_t::packet_type_t packet_type
size_t num_payload_words32
size_t num_payload_bytes
size_t num_header_words32
size_t num_packet_words32
size_t packet_count
bool sob
 Asserted for start- or end-of-burst. More...
bool eob
bool error
 This is asserted for command responses that are errors (CHDR only) More...
bool has_sid
 Stream ID (SID). See uhd::sid_t. More...
boost::uint32_t sid
bool has_cid
 Class ID. More...
boost::uint64_t cid
bool has_tsi
 Integer timestamp. More...
boost::uint32_t tsi
bool has_tsf
 Fractional timestamp. More...
boost::uint64_t tsf
bool has_tlr
 Trailer. More...
boost::uint32_t tlr
Definition for fields that can be packed into a vrt if header. The size fields are used for input and output depending upon the operation used (ie the pack or unpack function call).
◆ link_type_t
Enumerator
LINK_TYPE_NONE
LINK_TYPE_CHDR
LINK_TYPE_VRLP
◆ packet_type_t
Enumerator
PACKET_TYPE_DATA
PACKET_TYPE_IF_EXT
PACKET_TYPE_CONTEXT
PACKET_TYPE_FC
PACKET_TYPE_ACK
PACKET_TYPE_CMD
PACKET_TYPE_RESP
PACKET_TYPE_ERROR
◆ if_packet_info_t()
UHD_INLINE uhd::transport::vrt::if_packet_info_t::if_packet_info_t ( void  )
◆ cid
boost::uint64_t uhd::transport::vrt::if_packet_info_t::cid
◆ eob
bool uhd::transport::vrt::if_packet_info_t::eob
◆ error
bool uhd::transport::vrt::if_packet_info_t::error
◆ has_cid
bool uhd::transport::vrt::if_packet_info_t::has_cid
Class ID.
◆ has_sid
bool uhd::transport::vrt::if_packet_info_t::has_sid
◆ has_tlr
bool uhd::transport::vrt::if_packet_info_t::has_tlr
Trailer.
◆ has_tsf
bool uhd::transport::vrt::if_packet_info_t::has_tsf
◆ has_tsi
bool uhd::transport::vrt::if_packet_info_t::has_tsi
Integer timestamp.
◆ link_type
enum uhd::transport::vrt::if_packet_info_t::link_type_t uhd::transport::vrt::if_packet_info_t::link_type
◆ num_header_words32
size_t uhd::transport::vrt::if_packet_info_t::num_header_words32
◆ num_packet_words32
size_t uhd::transport::vrt::if_packet_info_t::num_packet_words32
◆ num_payload_bytes
size_t uhd::transport::vrt::if_packet_info_t::num_payload_bytes
◆ num_payload_words32
size_t uhd::transport::vrt::if_packet_info_t::num_payload_words32
◆ packet_count
size_t uhd::transport::vrt::if_packet_info_t::packet_count
◆ packet_type
enum uhd::transport::vrt::if_packet_info_t::packet_type_t uhd::transport::vrt::if_packet_info_t::packet_type
◆ sid
boost::uint32_t uhd::transport::vrt::if_packet_info_t::sid
◆ sob
bool uhd::transport::vrt::if_packet_info_t::sob
◆ tlr
boost::uint32_t uhd::transport::vrt::if_packet_info_t::tlr
◆ tsf
boost::uint64_t uhd::transport::vrt::if_packet_info_t::tsf
◆ tsi
boost::uint32_t uhd::transport::vrt::if_packet_info_t::tsi
