window_block_ctrl.hpp
18 #ifndef INCLUDED_LIBUHD_RFNOC_WINDOW_BLOCK_CTRL_HPP
19 #define INCLUDED_LIBUHD_RFNOC_WINDOW_BLOCK_CTRL_HPP
23
24 namespace uhd {
25  namespace rfnoc {
26
39 {
40 public:
42
43  static const size_t MAX_COEFF_VAL = 32767;
44  static const boost::uint32_t SR_WINDOW_LEN = 131; // Note: AXI config bus uses 129 & 130
45  static const boost::uint32_t RB_MAX_WINDOW_LEN = 0;
46  static const boost::uint32_t AXIS_WINDOW_LOAD = AXIS_CONFIG_BUS+0; // 2*0+0
47  static const boost::uint32_t AXIS_WINDOW_LOAD_TLAST = AXIS_CONFIG_BUS+1; // 2*0+1
48
50  //
51  // \p coeffs size determines the window length. If it longer than
52  // the maximum window length, throws a uhd::value_error.
53  virtual void set_window(const std::vector<int> &coeffs) = 0;
54
56  virtual size_t get_max_len() const = 0;
57
59  virtual size_t get_window_len() const = 0;
60
61 }; /* class window_block_ctrl*/
62
63 }} /* namespace uhd::rfnoc */
64
65 #endif /* INCLUDED_LIBUHD_RFNOC_WINDOW_BLOCK_CTRL_HPP */
#define UHD_RFNOC_BLOCK_OBJECT(class_name)
This macro must be put in the public section of an RFNoC.
Definition: block_ctrl_base.hpp:74
Definition: sink_block_ctrl_base.hpp:36
STL namespace.
Definition: build_info.hpp:25
#define UHD_RFNOC_API
Definition: config.hpp:103
Definition: source_block_ctrl_base.hpp:35
Block controller for the standard windowing RFNoC block.
Definition: window_block_ctrl.hpp:38
