uhd::cal::cal_container< in_type, out_type > Class Template Referenceabstract
#include <uhd/cal/container.hpp>
Inheritance diagram for uhd::cal::cal_container< in_type, out_type >:
uhd::cal::base_container
typedef std::map< in_type, out_type > container_t
typedef boost::archive::text_iarchive iarchive_type
typedef boost::archive::text_oarchive oarchive_type
- Public Types inherited from uhd::cal::base_container
typedef boost::shared_ptr< base_container > sptr
virtual out_type get (const in_type &args)=0
virtual void add (const out_type output, const in_type &args)=0
virtual void add_metadata (const metadata_t &data)=0
virtual const metadata_t & get_metadata ()=0
virtual void serialize (iarchive_type &ar, const unsigned int)=0
virtual void serialize (oarchive_type &ar, const unsigned int)=0
Friends
class boost::serialization::access
template<typename in_type, typename out_type>
class uhd::cal::cal_container< in_type, out_type >
An interface for creating and managing a generic calibration data container.
These containers are used to represent N dimensional data structures in order to accommodate a mapping from multi-variable input to a scalar value (e.g. gain, frequency, temperature -> power level [dBm]).
The container only supports inputs of the same type to be mapped.
◆ container_t
typedef std::map<in_type, out_type> uhd::cal::cal_container< in_type, out_type >::container_t
◆ iarchive_type
typedef boost::archive::text_iarchive uhd::cal::cal_container< in_type, out_type >::iarchive_type
◆ oarchive_type
typedef boost::archive::text_oarchive uhd::cal::cal_container< in_type, out_type >::oarchive_type
◆ add()
virtual void uhd::cal::cal_container< in_type, out_type >::add ( const out_type  output,
const in_type &  args
Add a data point to the container. This function records a mapping R^n -> R between an input vector and output scalar.
outputthe output of the data point mapping
argsinput values
Implemented in uhd::cal::power_container.
◆ add_metadata()
virtual void uhd::cal::cal_container< in_type, out_type >::add_metadata ( const metadata_t &  data)
Associate some metadata with the container.
dataa map of metadata (string -> string).
virtual out_type uhd::cal::cal_container< in_type, out_type >::get ( const in_type &  args)
Get the mapping from an input to an output from the calibration container.
argsinput values
the output of the mapping (a scalar value)
Exceptions
uhd::assertion_errorif the dimensions of the input args are incorrect for this container
◆ get_metadata()
virtual const metadata_t& uhd::cal::cal_container< in_type, out_type >::get_metadata ( )
Retrieve metadata from the container.
map of metadata.
◆ serialize() [1/2]
virtual void uhd::cal::cal_container< in_type, out_type >::serialize ( iarchive_type &  ar,
const unsigned  int
protectedpure virtual
◆ serialize() [2/2]
virtual void uhd::cal::cal_container< in_type, out_type >::serialize ( oarchive_type &  ar,
const unsigned  int
Friends And Related Function Documentation
◆ boost::serialization::access
friend class boost::serialization::access
friend
