003.000.c6c4b01e0
#include <time_spec.hpp>
| time_spec_t (double secs=0) | |
| time_spec_t (time_t full_secs, double frac_secs=0) | |
| time_spec_t (time_t full_secs, long tick_count, double tick_rate) | |
| long | get_tick_count (double tick_rate) const |
| double | get_real_secs (void) const |
| time_t | get_full_secs (void) const |
| double | get_frac_secs (void) const |
| time_spec_t & | operator+= (const time_spec_t &) |
| Implement addable interface. More... | |
| time_spec_t & | operator-= (const time_spec_t &) |
| Implement subtractable interface. More... | |
| static time_spec_t | get_system_time (void) |
A time_spec_t holds a seconds and a fractional seconds time value. Depending upon usage, the time_spec_t can represent absolute times, relative times, or time differences (between absolute times).
The time_spec_t provides clock-domain independent time storage, but can convert fractional seconds to/from clock-domain specific units.
The fractional seconds are stored as double precision floating point. This gives the fractional seconds enough precision to unambiguously specify a clock-tick/sample-count up to rates of several petahertz.
| uhd::time_spec_t::time_spec_t | ( | double | secs = 0 | ) |
Create a time_spec_t from a real-valued seconds count.
| secs | the real-valued seconds count (default = 0) |
| uhd::time_spec_t::time_spec_t | ( | time_t | full_secs, |
| double | frac_secs = 0 |
Create a time_spec_t from whole and fractional seconds.
| full_secs | the whole/integer seconds count |
| frac_secs | the fractional seconds count (default = 0) |
| long | tick_count, | ||
| double | tick_rate | ||
Create a time_spec_t from whole and fractional seconds. Translation from clock-domain specific units.
| tick_count | the fractional seconds tick count |
| tick_rate | the number of ticks per second |
| double uhd::time_spec_t::get_frac_secs | ( | void | ) | const |
Get the fractional part of the time in seconds.
| time_t uhd::time_spec_t::get_full_secs | ( | void | ) | const |
Get the whole/integer part of the time in seconds.
| double uhd::time_spec_t::get_real_secs | ( | void | ) | const |
Get the time as a real-valued seconds count. Note: If this time_spec_t represents an absolute time, the precision of the fractional seconds may be lost.
Get the system time in time_spec_t format. Uses the highest precision clock available.
| long uhd::time_spec_t::get_tick_count | ( | double | tick_rate | ) | const |
Convert the fractional seconds to clock ticks. Translation into clock-domain specific units.
| time_spec_t& uhd::time_spec_t::operator+= | ( | const time_spec_t & | ) |
| time_spec_t& uhd::time_spec_t::operator-= | ( | const time_spec_t & | ) |
1.8.13
