UHD  003.000.001
#include <udp_simple.hpp>
◆ make_broadcast()
const std::string &  port
◆ make_connected()
◆ recv()
double  timeout = 0.1
timeoutthe timeout in seconds
◆ send()
buffsingle asio buffer
the number of bytes sent
◆ mtu
