003.000.001
#include <props.hpp>
| template<typename T > | |
| T | as (void) |
| Convert the key to the specified type. More... | |
| named_prop_t (const wax::obj &key, const std::string &name) | |
| static named_prop_t | extract (const wax::obj &key, const std::string &name="") |
Public Attributes | |
| const wax::obj | key |
| const std::string | name |
A named prop struct holds a key and a name. Allows properties to be sub-sectioned by name.
| uhd::named_prop_t::named_prop_t | ( | const wax::obj & | key, |
| const std::string & | name | ||
Create a new named prop from key and name.
| key | the property key |
| name | the string name |
inline |
Utility function to convert generic key into a named prop. If the key was already a named prop, the prop will be split. Otherwise, the key will be the key, and the name will be used.
| key | a reference to the prop object |
| name | a reference to the name object |
| const wax::obj uhd::named_prop_t::key |
| const std::string uhd::named_prop_t::name |
1.8.13
