#include <udp_simple.hpp>
| virtual size_t | send (const boost::asio::const_buffer &buff)=0 |
| virtual size_t | recv (const boost::asio::mutable_buffer &buff, double timeout=0.1)=0 |
| static const size_t | mtu = 1500 - 20 - 8 |
| | The maximum number of bytes per udp packet. More...
◆ sptr
◆ make_broadcast()
| static sptr uhd::transport::udp_simple::make_broadcast |
const std::string & |
addr, |
port |
- Parameters
| addr | a string representing the destination address |
| port | a string representing the destination port |
◆ make_connected()
| static sptr uhd::transport::udp_simple::make_connected |
addr, |
port |
- Parameters
◆ recv()
| virtual size_t uhd::transport::udp_simple::recv |
const boost::asio::mutable_buffer & |
buff, |
double |
timeout = 0.1 |
- Parameters
| buff | a mutable buffer to receive into |
| timeout | the timeout in seconds |
- Returns
- the number of bytes received or zero on timeout
◆ send()
| virtual size_t uhd::transport::udp_simple::send |
const boost::asio::const_buffer & |
buff | ) |
- Parameters
- Returns
- the number of bytes sent
◆ mtu
| const size_t uhd::transport::udp_simple::mtu = 1500 - 20 - 8 |
